HMG 3.1.2
- dhaine_adp
Re: HMG 3.1.2 (Test)
After rebuilding my app using HMG 3.1.2 the windows title becomes like the attached file but it should read as "Nuestra Señora". The character "ñ" is substituted. There is no extra processing done on the win title, just a simple assignment only. e.g. wMainForm.Title := "Nuestra Señora".
Is this from harbour or from HMG? It looks like that it becomes unicode. Is there any switch or options to force ANSI on the apps or shall I fallback to HMG 3.0.46 in this regards?
I use to build the app using HB-IDE and the -w2 option mentioned in one of the Unicode threads can it be set through HB-IDE or I needed a customized batch file to do that?
Regards & TIA,
Danny
Regards & TIA,
Danny
- unicode.JPG (9.83 KiB) Viewed 9702 times
Danny
Manila, Philippines
Danny
Manila, Philippines
Hola Claudio y Rathi :
descargue la nueva version al leer el comentario de dhaine_adp me puse hacer un pequeño ejemplo, trabajo con Crimson editor
ajusto 'Document', 'Encoding Type = UTF8 w/o BOM' y escribo el Main.Prg
con el IDE creo el formulario que contiene un text y un boton.
este boton cambia el titulo del formulario, caption del boton y valor del label .
al hacer click la funcion cambia estas propiedades y se muestra correctamente las 'ñ?
Translate google
Hello Claudio and Rathi:
Download the new version to read the comments of dhaine_adp do I set a small example, work with Crimson editor
I set 'Document', 'Encoding Type = UTF8 w / o BOM' and write the Main.prg
with IDE created the form that contains a text and a button.
This button changes the title of the form, the button caption label and value.
Clicking these properties changes the function and display correctly the 'ñ'
Translate google
Function ChangeTitle()
Setproperty( 'Unicode' , 'Title' , 'Felicidades por su cumpleaños' )
Setproperty( 'Unicode' , 'Button_1', 'Caption' , 'Años' )
Setproperty( 'Unicode' , 'Label_1' , 'Value' , 'Feliz Cumpleaños' )
Return*´¨)
- dhaine_adp
Here's from HB source stable build (<Hb Dir>\doc\en\lang.txt)
and this code produces an error:
hbmk2: Warning: Non-portable output filename: '-otst.exe'. Delete '.exe' extension.
Harbour 3.2.0dev (r1303181903)
Copyright (c) 1999-2013, http://harbour-project.org/
Danny
I test it on XP SP2 English. The function HB_cdpSelect() returns UTF8 (it seems it is the default). I tried setting the codepage to ESWIN and ITISO to get ISO-8859-1 char set but it gave error Base/1302 Argument error: HB_CDPSELECT() {perhaps I have to use REQUEST command first but I am not changing the laguage set}. Also I tried it with "EN" but it seems EN is OEM (DOS). Right now I don't have an idea if this problem is from Harbour or HMG but a quick test using the code below results as follows:* Language Codepage <cNewLang>
* Bulgarian 866 BG866
* Bulgarian ISO-8859-5 BGISO
* Bulgarian MIK BGMIK
* Bulgarian Windows-1251 BGWIN
* Croatian 437 HR437
* Croatian 852 HR852
* Croatian Windows-1250 HR1250
* Czech 852 CS852
* Czech ISO-8859-2 CSISO
* Czech KAM CSKAM
* Czech Windoes-1250 CSWIN
* English 437 EN
* French 850 FR
* German 850 DE
* German ISO-8859-1 DEWIN
* Greek 737 EL
* Greek Windows-1253 ELWIN
* Hungarian (ntxhu852) 852 HU852
* Hungarian (sixhu852) 852 HU852S
* Hungarian (ntxhu852) ISO-8859-2 HUISO
* Hungarian (sixhu852) ISO-8859-2 HUISOS
* Hungarian (ntxhu852) Windows-1250 HUWIN
* Hungarian (sixhu852) Windows-1250 HUWINS
* Italian 437 IT437
* Italian 850 IT850
* Italian ISO-8859-1b ITISB
* Italian ISO-8859-1 ITISO
* Lithuanian Windows-1257 LT
* Polish 852 PL852
* Polish ISO-8859-2 PLISO
* Polish Mazowia PLMAZ
* Polish Windows-1250 PLWIN
* Portuguese 850 PT850
* Portuguese ISO-8859-1 PTISO
* Russian 866 RU866
* Russian KOI-8 RUKOI8
* Russian Windows-1251 RU1251
* Serbian Windows-1251 SRWIN
* Slovak 852 SK852
* Slovak ISO-8859-2 SKISO
* Slovak Kamenicky SKKAM
* Slovak Windows-1250 SKWIN
* Slovenian 437 SL437
* Slovenian 852 SL852
* Slovenian ISO-8859-2 SLISO
* Slovenian Windows-1250 SLWIN
* Spanish 850 ES
* Spanish ISO-8859-1 ESWIN
* Spanish Modern ISO-8859-1 ESMWIN
* Swedish 850 SV850
* Swedish (Clipper) 437 SVCLIP
* Swedish ISO-8859-1 SVWIN
* Turkish 857 TR857
* Turkish Windows-1254 TRWIN
* Ukrainian 866 UA866
* Ukrainian KOI-8U UAKOI8
* Ukrainian Windows-1251 UA1251
include <hmg.ch>
function main
msginfo( hb_cdpselect(), "test" )
return nil
// result UTF8
function main
? hb_cdpselect()
return nil
Danny
Danny
Manila, Philippines
Danny
Manila, Philippines
Thanks for all the bug reports. We will resolve one by one.
Leopoldo Blancas
Gracias por el trabajo realizado... Siempre estare agradecido.
Polo
Polo
Many thanks Rathinagiri and Dr. Claudio Soto for this new version !!
Nikos
Nikos
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Nikos.
- dhaine_adp
Hi Rathi and all,
I've already resolved my problem. The problem is from my source code editor setting. I switch the encoding type to UTF-8 w/o BOM, then from windows charmap I set the encoding type to "Unicode" and copy paste the character "ñ" to the source on Crimson Editor to overwrite the old encoding. Now it's working fine.
Well sometimes common sense is not so common.
because I used ASCII encoding on Crimson Editor before and this version is UTF-8.
See attached:
Moving app to UTF-8 is a good start, but I don't know yet if it would affect the dbf file encoding. Now, how can we detect the encoding type of character streams assuming we have no idea?
Danny
Danny
- unicode.JPG (7.1 KiB) Viewed 9592 times
Danny
Manila, Philippines
Danny
Manila, Philippines
- srvet_claudio
Hi Ed.Steed wrote:Frist at all,I have to say many thanks.
Bud I have to report that the issue with the textbox control remained
Ed
Can you post a small example and describe the bug ?
Claudio
- srvet_claudio
Hi Foued.fouednoomen wrote:BROWSE is not working in this hmg version. same than 3.1.1
It displays empty table always.
Problem with grid ,we can't write in grid
foued
I tested and work fine (viewtopic.php?p=22962#p22962).
Claudio.
I've found some problems with hmg 3.1.2 and context and main menu:
When you open one modal window from another, error occures:
or
Besides - context menu is not defined in line 33:
SZYBKATABELATOWAROW(33)
but, in FMG file loaded by function SZYBKATABELATOWAROW()
(piece of FMG file below)
All this code works perfect with hmg 3.0.46
Main Menu already defined in Window: OknoHistoriaKontrahenta. Program Terminated
Called from _DEFINEMAINMENU(61)
Error BASE/1070 Illegal argument: ==
Called from OBSLBLEDU(952)
Called from (b)MAIN(447)
Called from ISCONTEXTMENUDEFINED(638)
Called from _DEFINECONTEXTMENU(496)
Called from SZYBKATABELATOWAROW(33)
DEFINE CONTEXT MENU
MENUITEM "Popraw Towar" ACTION PoprawDodajTowar(.f.) NAME PoprawDodajTowar
MENUITEM "Drukuj etykietę na regał" ACTION ZaznaczTowarDoDrukuEtykiety(0,towary->towar, cEtykietaNaRegal,1) NAME ZaznaczTowarDoDrukuEtykiety
MENUITEM "Drukuj etykietę na towar" ACTION ZaznaczTowarDoDrukuEtykiety(1,towary->towar, cEtykietaNaTowar,-1,towary->Ilosc) NAME cEtykietaNaRegal
END MENU
