Change a Grid Readonly On the fly
sudip
Post by sudip »
How can I change the Readonly property of a grid on the fly?
I used
frmCompound.grdCompoundrm.readonly := .t.
But it doesn't work.
TIA.
With best regards.
Re: Change a Grid Readonly On the fly
Hi Sudip
Are you sure that GRID control has ReadOnly property ?
gfilatov
Post by gfilatov »
sudip wrote:Hi,
I used
Hi Sudip,
Try
_HMG_SYSDATA [ 40 ] [ GetControlIndex ( 'grdCompoundrm' , 'frmCompound' ) ] [ 1 ] := .F.
I hope that helps :idea:
sudip
Post by sudip »
Hi Esgici,
Actually I am not sure. ;) I can't find Readonly for Grid in Help. But, my code doesn't show any error!!!
Hi Grigory,
Thank you very much. This will be very helpful to me.
Before seeing your code, I tried something with COLUMNWHEN property and it works!!!
		@ 96, 220 GRID grdCompoundRm ;
			WIDTH 300 ;
			HEIGHT 250 ;
			HEADERS { 'Raw Material', 'Qty', '%' } ;
			WIDTHS { 150, 75, 55 } ;
			COLUMNCONTROLS { { 'COMBOBOX', aRmnm }, ;
			               { 'TEXTBOX', 'NUMERIC', '9999.999' }, ;
			               { 'TEXTBOX', 'NUMERIC', '999.99%' }} ;
			edit ;
			justify { 0, 1, 1 } ;
			on lostfocus CalcTot() ;
			COLUMNWHEN { { || frmCompound.cmdSave.enabled }, ;
				{ || frmCompound.cmdSave.enabled }, { || .f. } }
With best regards.
sudip
Post by sudip »
Hello Grigory,
Thank you very much for your tip!!! It works!!! :D
But, I have to remember the line ...
BTW, is there any documentation for _HMG_SYSDATA?
With best regards.
gfilatov
Post by gfilatov »
sudip wrote:Hello Grigory,
Sudip,
Take a look for h_init.prg at your folder hmg\SOURCE. :arrow:
* _HMG_SYSDATA Reference ;)
* _HMG_SYSDATA [ 1 ] -> Control Data
* _HMG_SYSDATA [ 2 ] -> Control Data
* _HMG_SYSDATA [ 3 ] -> Control Data
* _HMG_SYSDATA [ 4 ] -> Control Data
* _HMG_SYSDATA [ 5 ] -> Control Data
* _HMG_SYSDATA [ 6 ] -> Control Data
* _HMG_SYSDATA [ 7 ] -> Control Data
* _HMG_SYSDATA [ 8 ] -> Control Data
* _HMG_SYSDATA [ 9 ] -> Control Data
* _HMG_SYSDATA [ 10 ] -> Control Data
* _HMG_SYSDATA [ 11 ] -> Control Data
* _HMG_SYSDATA [ 12 ] -> Control Data
* _HMG_SYSDATA [ 13 ] -> Control Data
* _HMG_SYSDATA [ 14 ] -> Control Data
* _HMG_SYSDATA [ 15 ] -> Control Data
* _HMG_SYSDATA [ 16 ] -> Control Data
* _HMG_SYSDATA [ 17 ] -> Control Data
* _HMG_SYSDATA [ 18 ] -> Control Data
* _HMG_SYSDATA [ 19 ] -> Control Data
* _HMG_SYSDATA [ 20 ] -> Control Data
* _HMG_SYSDATA [ 21 ] -> Control Data
* _HMG_SYSDATA [ 22 ] -> Control Data
* _HMG_SYSDATA [ 23 ] -> Control Data
* _HMG_SYSDATA [ 24 ] -> Control Data
* _HMG_SYSDATA [ 25 ] -> Control Data
* _HMG_SYSDATA [ 26 ] -> Control Data
* _HMG_SYSDATA [ 27 ] -> Control Data
* _HMG_SYSDATA [ 28 ] -> Control Data
* _HMG_SYSDATA [ 29 ] -> Control Data
* _HMG_SYSDATA [ 30 ] -> Control Data
* _HMG_SYSDATA [ 31 ] -> Control Data
* _HMG_SYSDATA [ 32 ] -> Control Data
* _HMG_SYSDATA [ 33 ] -> Control Data
* _HMG_SYSDATA [ 34 ] -> Control Data
* _HMG_SYSDATA [ 35 ] -> Control Data
* _HMG_SYSDATA [ 36 ] -> Control Data
* _HMG_SYSDATA [ 37 ] -> Control Data
* _HMG_SYSDATA [ 38 ] -> Control Data
* _HMG_SYSDATA [ 39 ] -> Control Data
* _HMG_SYSDATA [ 40 ] -> Control Data
sudip
Post by sudip »
Hi Grigory,
Thank you sooooo much :)
Now, I have another problem. I want to autocaluclate some total amount from grid. What event shall I use?
1) On change
2) COLUMNVALID
3) LostFocus
Previously I used On Change, but I found that it works only if Row or Col value is changed.
TIA.
With best regards.
gfilatov
Post by gfilatov »
sudip wrote:Hi Grigory,
1) On change
2) COLUMNVALID
3) LostFocus
Hi Sudip,
I vote for 2) COLUMNVALID ;)
* MiniGUI Virtual Column Grid Demo
* (c) 2006-2009 Grigory Filatov
#include "minigui.ch"
PROCEDURE Main
Local aRows [20] [6]
		WIDTH 640 ;
		HEIGHT 420 ;
		TITLE 'Virtual Column Grid Test' ;
		DEFINE MAIN MENU
			DEFINE POPUP 'File'
				MENUITEM 'Set Item'	ACTION SetItem()
				MENUITEM 'Get Item'	ACTION GetItem()
				SEPARATOR
				MENUITEM 'Exit'	ACTION ThisWindow.Release
			END POPUP
		END MENU
		aRows [1]	:= {'01','Simpson','Homer',5,10,5*10}
		aRows [2]	:= {'02','Mulder','Fox',24,32,24*32}
		aRows [3]	:= {'03','Smart','Max',43,58,43*58}
		aRows [4]	:= {'04','Grillo','Pepe',89,23,89*23}
		aRows [5]	:= {'05','Kirk','James',34,73,34*73}
		aRows [6]	:= {'06','Barriga','Carlos',39,54,39*54}
		aRows [7]	:= {'07','Flanders','Ned',43,11,43*11}
		aRows [8]	:= {'08','Smith','John',12,34,12*34}
		aRows [9]	:= {'09','Pedemonti','Flavio',10,100,10*100}
		aRows [10]	:= {'10','Gomez','Juan',58,32,58*32}
		aRows [11]	:= {'11','Fernandez','Raul',32,43,32*43}
		aRows [12]	:= {'12','Borges','Javier',26,30,26*30}
		aRows [13]	:= {'13','Alvarez','Alberto',54,98,54*98}
		aRows [14]	:= {'14','Gonzalez','Ambo',43,73,43*73}
		aRows [15]	:= {'15','Batistuta','Gol',48,28,48*28}
		aRows [16]	:= {'16','Vinazzi','Amigo',39,83,39*83}
		aRows [17]	:= {'17','Pedemonti','Flavio',53,84,53*84}
		aRows [18]	:= {'18','Samarbide','Armando',54,73,54*73}
		aRows [19]	:= {'19','Pradon','Alejandra',12,45,12*45}
		aRows [20]	:= {'20','Reyes','Monica',32,36,32*36}
		@ 10,10 GRID Grid_1 ;
			WIDTH 612 ;
			HEIGHT 344 ;
			HEADERS { 'Code', 'Last Name', 'First Name', 'Quantity', 'Price', 'Cost' } ;
			WIDTHS {60,100,100,80,80,100} ;
			ITEMS aRows ;
			EDIT ;
			COLUMNCONTROLS  { ;
					{'TEXTBOX','CHARACTER', '999' } , ;
					{'TEXTBOX','CHARACTER', } , ;
					{'TEXTBOX','NUMERIC', '9,999' } , ;
					{'TEXTBOX','NUMERIC', '999.99' } , ;
					{'TEXTBOX','NUMERIC', '9,999,999.99' } ;
			COLUMNWHEN { ;
					{ || Empty ( This.CellValue ) } , ;
					{ || This.CellValue >= 'M' } , ;
					{ || This.CellValue >= 'C' } , ;
					{ || ! Empty ( This.CellValue ) }, ;
					{ || Empty ( This.CellValue ) } ;
			COLUMNVALID { , , , ;
					{ || SETVIRTUALITEM() } , ;
			JUSTIFY { GRID_JTFY_RIGHT,;
				GRID_JTFY_LEFT,;
				GRID_JTFY_LEFT,;
				GRID_JTFY_RIGHT,;
				GRID_JTFY_RIGHT,;
				GRID_JTFY_RIGHT }
	CENTER WINDOW Form_1
Function SETVIRTUALITEM()
local nVal := This.CellValue
local nCol := This.CellColIndex
local nRow := This.CellRowIndex
if nCol == 4
	Form_1.Grid_1.Cell( nRow , 6 ) := nVal * Form_1.Grid_1.Cell( nRow , 5 )
elseif nCol == 5
	Form_1.Grid_1.Cell( nRow , 6 ) := Form_1.Grid_1.Cell( nRow , 4 ) * nVal
RETURN .T.
PROCEDURE SETITEM()
	Form_1.Grid_1.Item (2) := { '02', 'Gomez', 'Juan' , Form_1.Grid_1.Cell( 1 , 4 ), Form_1.Grid_1.Cell( 1 , 5 ), Form_1.Grid_1.Cell( 1 , 4 ) * Form_1.Grid_1.Cell( 1 , 5 ) }
PROCEDURE GETITEM()
local a
	a := Form_1.Grid_1.Item (2)
	aEval( a, {|x,i| msginfo ( if(valtype(x)=="C", x, str(x)), ltrim( str ( i ) ) )} )
sudip
Post by sudip »
Hello Grigory,
Thanks a lot! Now, I understand. :)
With best regards.
