Hi from Serbia
Hi from Serbia
Hello, I am from Serbia, have tons of Clipper code that need conversion. I have been trying, for months now, to convert my old Clipper apps into 32bit GUI apps. Have been able to make them 32bit console apps using HMG, but that is where I`m stuck right now. So any help would be appreciated.
- esgici
Re: Hi from Serbia
Welcome aboard
Here you may find some useful info :
http://vivaclipper.wordpress.com/2012/1 ... -i-can-do/
Happy HMG'ing
Happy HMG'ing
Viva INTERNATIONAL HMG
Re: Hi from Serbia
Bienvenido Bobypoz :
Ya el amigo Esgici lo invito a leer una ayuda para que usted pueda convertir su aplicacion Clipper a HMG, espero que le sea de mucha ayuda.
igualmente aqui puede exponer sus consultas sobre ese mismo tema creando un nuevo topico
puede usted utilizar el siguiente enlace http://hmgforum.com/viewforum.php?f=24 para ello.
encontrara en HMG un monton de amigo que gustosos ayudaran a ser posible ese traspaso de su aplicacion.
Saludos grande Serbia desde Buenos Aires, Argentina
Welcome Bobypoz:
Already Esgici friend invited him to read a help for you to convert your Clipper application to HMG, I hope will be of much help.
here can also expose your inquiries on the same subject by creating a new topic.
You can use the following link [url] http://hmgforum.com/viewforum.php?f=24 [/ url] to it.
find in HMG a lot of friend who will gladly help if possible the transfer of its application.
Greetings from Buenos Aires, Argentina
Welcome Bobypoz:
Re: Hi from Serbia
Welcome and best wishes from India.
Leopoldo Blancas
Re: Hi from Serbia
Bienvenido a bordo.... es el lugar perfecto...
Polo
Welcome aboard .... is the perfect place ...
Polo
Polo
Polo
Re: Hi from Serbia
Hi from Croatia
I translated all my programs from Clipper without any problems and everything works perfectly(DBF databas).
Now all switched to SQLite database and no problem, but if you want in (MySQL, Firebird, Postgress ..) you can do it.
You can all this be done as a console and GUI application, I recommend Gui.
Otherwise you can use the code from Clipper with little modification, if it is function.
the only thing you'll do to create a new screen, but for that you have IDE to help in the programing screen form.
Nadam se da sam pomogao.
Lijepi pozdrav,
Miraš Ćirović
Lijepi pozdrav,
Miraš Ćirović
Re: Hi from Serbia
Welcome from Ukraine
Oleksandr Antypenko
xHarbour 1.2.3 , Harbour 3.x + Mingw 4.x (HMG, minigui)
https://bitbucket.org/aantypenko
https://github.com/aantypenko
Oleksandr Antypenko
Re: Hi from Serbia
Hi esgici
It's not me it is the nature.
Oleksandr Antypenko
Oleksandr Antypenko
