HbMk2 at prompt command
Harbour, MingW related news.
HbMk2 using like as dBase
Have anyone seen HbMk2 as utility in Harbour (of course) using like as the old dBase III plus ??
So recently in another forum was presented HbMk2 for this propose by Mr. Alexandre ( alxsts ).
At Prompt Command (DOS screen, let say) you only need to type:
HbMk2 . (with space and one point)
Then it will display a screen like this:
Well the rest of commands, you should know !!!
You can type:
USE CLIENTS
BROWSE()
This is a good information, whom still misses the old dBase...
I hope all enjoy, and also you can run HbMk2.exe from C:\hmg.3.1.1\HARBOUR\bin
Re: HbMk2 using like as dBase in dot commad
Hola Pablo
Pablo César wrote:Have anyone seen HbMk2 as utility in Harbour (of course) using like as the old dBase III plus ??
Is this different to hbrun :?:
ohhh seems same. I did not know it, yet. I also saw in your website with many other examples. Thanks Esgici for clarifying !
Remark: Please also note using DIR can be used like in OS command. For example:
DIR \FOLDER\*.PRG then its will be listed all prg files. DIR command will not used for dbf only.
HbMk2 using to know any function/command at Harbour exists
I wish to share with you what Hazael (Qatan) has mentioned in other forum.
Very useful when we want to know about any function or any command at Harbour exists. Thanks to Viktor.
Just type at line command:
hbmk2 –find printer
Will bring all functions list with printer in it. It's accepting wildcard (*) too.
I still use dbase3 for quick browsing or testing set filters to..
You did not understand. It's a tip:
But sometimes it does not work. Only works after typing: hbmk2 -comp=mingw -find printer
ROBROS
Re: HbMk2 at prompt command
Post by ROBROS »
Hi friends,
I have installed hmg.3.4.4. Hbrun.exe is on board, but starting it gives me the error that libgcc_s_sjlj-1.dll is missing. Where do I get the dll from?
DBA is working, but dbase dot prompt is very familiar to me: copy stru to// ,sum field to var ...//count field to var for...// disp all for and so on.
I have dBase for Dos 5.0 installed in DOSBOX, but I would prefer the prompt. Also dBase for Dos has a limitation of records.
Thx Robert
ROBROS
Post by ROBROS »
I made a search on my PC, it was in the folder where "Gimp" is installed, just copied it in the Harbour\bin folder, now I can start hbrun.
Robert
