HMG 3.1.0
Re: HMG 3.1.0 (Test)
Hi Algernon;
What happiness hearing you again :)
Thanks to your nice words :)
HMG is one of the best thing in my life too :)
Viva all supporters of HMG, no matter as reader and / or writer ;)
Hopefully waiting more participation by you :)
Saludos cordiales,
Algernon wrote:I apologize for taking a long time without writing, but I am always present and attentive to developments and solutions raised by all of you.
I used to work and read the forum to find solutions, sometimes I find them working hard and reading the answers and questions in this wonderfull forum, I have not words to explain what is happening in my mind. When I started with HMG I found a tool to make my aplications easy and friendly like old clipper, but now I think that it's more than a tool. First of all thanks to all the peopel around the world that is puting its molehill to make HMG one of the best thing that has happend to me.
Thanks rathinagiri, Roberto Lopez, esgici, Pablo César, srvet_claudio, mol and all members of the forum.
A thousand thanks!
Algernon : lo importante es que este leyendo y usando HMG para sus trabajos, y que este conforme con esta herramienta que nos entrega Roberto, la gente de Harbour y la contribucion de los amigos de este foro.
Translate google:
Algernon: what matters is that reading and using HMG for their work and are happy with this tool that gives us Roberto, people of Harbour and the contribution of the friends of this forum.
Steed
Post by Steed »
Hi, all
Something is happen with textbox control, randomly their value is not returned.
See next example:
1- Run prueba.exe
2- Hit Properties button
3- Hit Save Button
Save button execute the next code:
cTemp:=GetProperty('Win2','Text_1a','Value')
msgbox(alltrim(cTemp)+"x")
But in a randomly manner the value is not returned, sometimes msgbox shows: "Pruebax"
And sometimes only shows "x"
Attached please find short example
Thanks for your advices
Ed
Prueba.rar
(1.37 KiB) Downloaded 1404 times
Leopoldo Blancas
Post by Leopoldo Blancas »
Hola...
Ya lo Compile y responde bien en HMG.3.1.1
Te mando la imagen... y lo ejecute 10 veces... y todo Ok, si tienes problemas desintala el HMG y vuelvelo a instalar, revisa de virus tu compu...
Polo
Hello ...
Compile and already responds well HMG.3.1.1
I send you the picture ... and run it 10 times ... and everything Ok, if you have problems and vuelvelo Removes the HMG-install, virus checks your compu ...
Polo
Steed wrote:Hi, all
Ed
I also happen to Incomming Email application.
SetProperty ( 'Incomming' , 'cUser' , 'value' , 'danielmaximilianoherrera' )
SetProperty ( 'Incomming' , 'cPass' , 'value' , '123456' )
however this does not happen with
SetProperty ( 'Incomming', 'Title' , 'Current : ' + aServers [ Incomming.Server.value] [ 1 ] )
Textbox control fails many times, thought I had a Rootkit / Malware but I check many times and nothing.
HMG.3.1.1 also reinstall several times.
in some executions control returns the actual content.
Windows 7 Home Premiun 64
Steed
Post by Steed »
HI,
I allready download again HMG.3.1.1 file from the forum and recompile the example
bud the issue reamaind
I Have W7,
Ed
Leopoldo Blancas
Pues no veo el error, tengo win7-32 y ejecuta bien tu archivo...
Polo
Well I see the error, I have win7-32 and runs well your file ...
Polo
Leopoldo Blancas wrote:Pues no veo el error, tengo win7-32 y ejecuta bien tu archivo...
Polo
Polo
yo uso Windows 7 Home Premiun 64.
I use Windows 7 Home Premium 64.
Steed wrote:HI,
I Have W7,
Ed
Try edit C:\hmg.3.1.1\SOURCE\SET_COMPILE_HMG_UNICODE.ch
#define COMPILE_HMG_UNICODE
modify
//#define COMPILE_HMG_UNICODE
Rebuild with C:\hmg.3.1.1\buildalllib.bat
Build prueba.hbp
Steed
Post by Steed »
Thanks, Daniel I still having the same problem.
Does anyone could confirm the issue with textbox
Ed
