Background color in browse or grid
radohabjan
Hello Friends,
is there any possibility to see which color is in the background of the selected item in the grid in browse command ?
Instead of color is always white text on blue background. The same problem is also in the grid command
To understand the problem please look at the attached picture.
I want to have green background.
br Rado
br Rado
- Capture.PNG (75.94 KiB) Viewed 19533 times
- esgici
Re: Background color in browse or grid
Hi Radoradohabjan wrote:Hello Friends,
br Rado
Didn't tried DYNAMICBACKCOLOR ?
Viva INTERNATIONAL HMG
radohabjan
Hello Esgici
Yes, I made green and red color with function DYNAMICBACKCOLOR, the problem is because in the selected item you
can not see the back color, because is always blue (in the attached picture is green).
br Rado
br Rado
- esgici
Could you send a SSE ( short and simple ) example ?
Leopoldo Blancas
Una pregunta radohabjan, Quieres que se pueda cambiar el color de selección del item al seleccionarlo, ya que por default se selecciona con fondo azul y letra banca?
Polo
Radohabjan questions, want to be able to change the color of the item selection when selected as default is selected with blue background and lyrics banking?
Polo
Polo
Polo
radohabjan
Hello
demo in attache file
when you start the program, you can't see that the selected field has red backcolor (it's always blue).
br Rado
br Rado
- TEST.ZIP
- (1.19 MiB) Downloaded 932 times
- esgici
Hi Rado
IMO your program work correct.
Defined colors seen verbatim for inactive rows.
Probably you are expect seeing different colors for active row; in BROWSE and GRID color of active record always is white on blue and can't change-able.
Happy HMG'ing
Happy HMG'ing
radohabjan
Hello Esgici,
I found one small workaround: put in front of field color picture.
The other will be TSBROWSE, but it's not in standard version HMG. Does anybody use TSBROWSE ?
br Rado
br Rado
- TEST1.ZIP
- (2.36 MiB) Downloaded 924 times
- Capture.PNG (41.46 KiB) Viewed 19409 times
radohabjan
Hello,
by the way I found an error in BROWSE ( perhaps is the same in GRID ):
function HEADERIMAGES uses the same parameters (pictures) as function IMAGE. So you can not use both functions together.
IMAGE {"potrdi1.bmp","white1.bmp","potrdi1.bmp","potrdi1.bmp","cancel1.bmp"} ;
HEADERIMAGES { '02.bmp' ,'03.bmp' } ;
br Rado
br Rado
- fouednoomen
Hello Esgici,
Can i display the first column in bold character and the second on in standard character.
One example please
foued
One example please
foued
