HMG 2.8.5 (Forum Test)
Here is a new test.
I've fixed double execution and problems with value property.
To install, merge the attached file with your current HMG installation (please backup first).
Please, test and report any problem.
Thanks in advance.
Roberto.
hmg285.rar
(370.48 KiB) Downloaded 335 times
Re: HMG 2.8.5 (Forum Test)
Yes. It's great.
Thanks Roberto. It is working now as expected. So nice of you.
jrendon
Post by jrendon »
Perfect i'm testing now
Roberto Lopez wrote: ... test and report any problem.
Tested.
Now everything is okay and more clear ( it's seeming to ... ;) )
Best Regards
Roberto Lopez wrote:Hi All,
Thanks to all for testing.
I'm testing too and I've found a little new problem.
If you omit value at control definition a runtime error is generated.
I've just fixed.
Anyway appears to be that there will be a 2.8.6 test :)
Thanks again.
Roberto.
fchirico
Post by fchirico »
Here is a new test.
Roberto.
Roberto, primero que nada muchas gracias.
He probado el test 2.8.5 y hasta ahora va todo bien. Solo tengo una duda:
En el sample\grid_23 dice:
DEFINE GRID Grid_1
ROW 10
COL 10
WIDTH 500
HEIGHT 322
HEADERS {'Column 1','Column 2','Column 3'}
WIDTHS {100,100,100}
ITEMS aRows
VALUE 1
ALLOWEDIT .T.
CELLNAVIGATION .T.
ONCHANGE GridChange()
VALUE { 3 , 2 }
END GRID
veo que hay dos propiedades VALUE, entonces pregunto si CELLNAVIGATION es .F. la propiedad VALUE que vale es la que no se indica por ARRAY?
Si deseo trabajar sin CELLNAVIGATION .T. la propiedad VALUE debe especificarse sin ARRAY no?
muchas gracias y seguiré probando.
Saludos, Fernando Chirico.
Here is a new test.
Roberto.
DEFINE GRID Grid_1
ROW 10
COL 10
WIDTH 500
HEIGHT 322
ITEMS aRows
VALUE 1
ALLOWEDIT .T.
CELLNAVIGATION .T.
VALUE { 3 , 2 }
END GRID
English:
It's my mistake. You must eliminate 'value 1' line.
Español:
Es mi error. Hay que eliminar la línea 'value 1'.
Gracias por reportarlo.
Saludos,
Roberto.
