HMG 3.1.1
Re: HMG 3.1.1
Mario Mansilla wrote:But I get several errors among others related to "TCHAR".
Now the library doing buildlib.bat as distributed while establishing lib gives an error message about "HB_LISTVIEW".
Hi Mario.
You could set the compiler messages?
I tested and not give me problem.
Claudio
PS: These two compiler warnings are "normal".
Mario Mansilla
Re: HMG 3.1.1
Post by Mario Mansilla »
Hola claudio :
Disculpas el error se produce porque en lugar de colocar " // " como comentario coloque " * " como si fuera clipper .
Saludos .
Mario
Re: HMG 3.1.1
Mario Mansilla wrote:Hola claudio :
Saludos .
Mario
Ok, no hay problema.
Saludos,
Claudio.
Re: HMG 3.1.1
the source code of BROWSE of the HMG.3.1.0 was remained in ANSI, I was not converted to UNICODE
Ahhh sorry I did not checked this situation.
Dr. Claudio, no habria una forma de implementar una excepción al invés de tener que rehacer la biblioteca ? Es decir, colocar una directiva negativa para no usar el UNICODE ?
Dr. Claudio, there would be no way to implement an exception in place of having to redo the library? I means, to put a negative declaration saying for not using UNICODE ?
Re: HMG 3.1.1
Have you see ListView_SetUnicodeFormat function ?
Re: HMG 3.1.1
Pablo César wrote:Dr. Claudio, there would be no way to implement an exception in place of having to redo the library? I means, to put a negative declaration saying for not using UNICODE ?
You can not change at runtime from Unicode to ANSI and vice versa.
The only way is to have two different libraries (HMG-ANSI and HMG-UNICODE) but in practice it means have two HMG at same time.
To have functions ANSI and Unicode at runtime you must make a library with two sets of functions that must necessarily have different names as in Windows, with all the complexity that entails, eg. MsgInfoA (ANSI) and MsgInfoW (Unicode).
Re: HMG 3.1.1
Pablo César wrote:Have you see ListView_SetUnicodeFormat function ?
Interesting, very interesting...
Re: HMG 3.1.1
Exist in C:
Header_SetUnicodeFormat
MonthCal_SetUnicodeFormat
TabCtrl_SetUnicodeFormat
TreeView_SetUnicodeFormat
Header_GetUnicodeFormat
MonthCal_GetUnicodeFormat
ListView_GetUnicodeFormat
TabCtrl_GetUnicodeFormat
TreeView_GetUnicodeFormat
Functions interesting that must to be tested.
Re: HMG 3.1.1
That is very nice then.
Re: HMG 3.1.1
Dear All,
Entry can be made using Google Language Input Tools
See sample
