CardReader
Re: CardReader
If you send me the part (ej. eIDNative.prg) that is implemented with eIDNative gridding pair and between the characters
/ * you want to do * /
so that way see the steps you are doing well and correct their mistakes.
the steps are.
1 - bring readers online x list.
2 - to Seed reader x name.
3 - initialize the card.
3 - is eIDcard?
4 - first of all bring a missing data for the next step.
5 - now if. ReadAddress ()
Re: CardReader
Serge :
una pregunta, ¿ sabe trabajas con Classes ?
de esa forma sería trabajar mejor con eID library.
Serge:
a question, do you know working with Classes?
that way it would work better with eID library.
Re: CardReader
Daniel,
I have done all the steps succesfully, except the ReadAddress function.
This because of the CLASSes which I'm not familiar with.
Thx,
Re: CardReader
serge_girard wrote:Daniel,
Thx,
Hello Serge. I've just come home.
I can tell you ReadAddress need to send a data to return the value you need (callback). so I need to know with a simple example of what you are sending to the eIDReader.dll to understand that you are missing.
that way it will be easier for me.
this is because here we do not use that kind of reader identity.
the class you need is EIDIdentity, this would return the values
Visual Basic Example :
Type EIDIdentity
      CardNumber As String * EID_MAX_CARD_NUMBER_LEN
      chipNumber As String * EID_MAX_CHIP_NUMBER_LEN
      ValidityDateBegin As String * EID_MAX_DATE_BEGIN_LEN
      ValidityDateEnd As String * EID_MAX_DATE_END_LEN
      municipality As String * EID_MAX_DELIVERY_MUNICIPALITY_LEN
      nationalNumber As String * EID_MAX_NATIONAL_NUMBER_LEN
      Name As String * EID_MAX_NAME_LEN
      firstName1 As String * EID_MAX_FIRST_NAME1_LEN
      firstName2 As String * EID_MAX_FIRST_NAME2_LEN
      nationality As String * EID_MAX_NATIONALITY_LEN
      birthLocation As String * EID_MAX_BIRTHPLACE_LEN
      BirthDate As String * EID_MAX_BIRTHDATE_LEN
      Sex As String * EID_MAX_SEX_LEN
      nobleCondition As String * EID_MAX_NOBLE_CONDITION_LEN
      documentType As Long
      whiteCane As Boolean
      yellowCane As Boolean
      extendedMinority As Boolean
End Type
Function ReadIDData Lib "EIDReader.dll" (ByRef Data As EIDIdentity) As Boolean
this is sent &EIDIdentity and returns all values ​​in the.
Type EIDAddress
      street As String * EID_MAX_STREET_LEN
      zip As String * EID_MAX_ZIP_LEN
      municipality As String * EID_MAX_MUNICIPALITY_LEN
End Type
sends EIDAddress and returns the result in the.
Function ReadAddress Lib "EIDReader.dll" (ByRef pData As EIDAddress) As Boolean
of course this must be done in Harbour so I need the font that is building in this way to prevent this issue extends far.
Re: CardReader
Daniel,
This the program is as it is now:
ReadAddress is the problem and so is GetReadersList (always 0)
#Include "hmg.ch"
Function main()
Local cSelectName := ''
Local cFunction   := ''
Local aNames      := {}
Local nLenNames   := 0
n = 0
CallDll32( 'InitReader' , 'EIDReader.dll', n )
cGetReaderName			:= space(20)
nReaderNameLen			:= 20
nIndexReaderNameLen	:= 0
CallDll32( 'GetReaderName' , 'EIDReader.dll', nIndexReaderNameLen, cGetReaderName, nReaderNameLen )
msginfo(cGetReaderName , 'GetReaderName')		// ok --> OMNIKEY CardMan 3x21 --> Correct!
lc = CallDll32('GetReadersList', 'EIDReader.dll', aNames, nLenNames )
msginfo(VALTYPE(lc)  , '1-VALTYPE-lc')		// Numeric
msginfo(str(lc,11,2) , '1-STR-lc')			// 2289604		??
nLenNames  = len(aNames)
If nLenNames = 0
   MsgInfo( ' No GetReadersList ' , ' Message Information ' )		// always 0, so this message
Endif
for a = 1 to nLenNames	// zero, so nothing
   MsgInfo( aNames[a] , ' Message Information ' )
next a
cSelectName := alltrim(cGetReaderName)
cFunction   := 'SelectReader(0)'
msginfo(cFunction , 'cFunction')
CallDll32( cFunction , 'EIDReader.dll' )
LC = CallDll32( 'ReaderConnectedToCard' , 'EIDReader.dll' )
IF LC == -1
	msginfo('ReaderConnectedToCard : CARD present' , 'OK')		// Correct: this one is OK
   msginfo('ReaderConnectedToCard : NO CARD present' , 'NOK')
LC = CallDll32( 'IsEIDCard' , 'EIDReader.dll' )
IF LC == -1
   msginfo('IsEIDCard' , 'OK')											// Correct: this one is OK
   msginfo('NO IsEIDCard' , 'NOK')
LC = CallDll32( 'IsSISCard' , 'EIDReader.dll' )
IF LC == -1
   msginfo('IsSISCard' , 'OK')
   msginfo('NO IsSISCard' , 'NOK')										// Correct: this one is OK
LC = CallDll32( 'GetReadersCount' , 'EIDReader.dll' )
msginfo(str(lc,3,0) + ' GetReadersCount' , 'OK')					// Correct: this one: 1
x		:= {'','',''}
cFunction   := 'ReadAddress("' + x[1] + '")'
lc := CallDll32(cFunction, 'EIDReader.dll', n )
msginfo(VALTYPE(lc), 'VALTYPE-lc')					// Numeric
msginfo(VALTYPE(n) , 'VALTYPE-n')					// Numeric
msginfo(VALTYPE(x) , 'VALTYPE-x')					// a
msginfo(str(Len( x ),11,2) , 'STR(len)-x')		// 3 which is normal
msginfo(x[1] , 'x[1]')									// nothing
CallDll32("DoneReader", "EIDReader.dll")			// ok
msginfo('DoneReader' , 'ok')
Thanks for helping!
S
Re: CardReader
Hi Serge:
eIDReader arm to wrap it in the papers has to work.
eIDReader.prg is the main program
eIDNative.prg is where functions and classes to connect with EIDReader.dll it fail and some features that are operated only thing to do is improve eIDNative.prg
I hope it works and will serve
eIDReader.rar
(142.96 KiB) Downloaded 392 times
Re: CardReader
danielmaximiliano wrote:Hi Serge:
eIDReader.rar
Serge:
if you have problems try to remove the "&" and try again
Guys, if anyone has worked with classes and can review the code if it's okay I would appreciate.
Re: CardReader
Hola a Todos / Hi Everyone:
Agregando la interfaz grafica me encuentro que una parte del programa falla.
Adding the GUI I find that part of the program fails.
el manual de referencia dice / reference manual says :
eID Native Library C++ edition_2012-12-11_02-05-48.jpg (37.12 KiB) Viewed 7188 times
el codigo que genera ese error es este / the code that generates the error is this
Procedure ReadDataCard()
 Local lLogical := ReadIDDataCard(  oeIDIdentity )
  msginfo( VALTYPE( lLogical )  , 'lLogical')
    If lLogical
       eIDReader.cReadData.Value := 'Read identity information from Belgian eID card is OK'
       /*oeIDIdentity
       eIDReader.cName.Value := oeIDIdentity:cName
       SavePhotoAsJpegCard( 'image' )
	   eIDReader.eIDImage.Picture := 'image.jpg'
       msginfo('Read identity information from Belgian eID card' , 'False')
la funcion es esta. / function is this.
Function ReadIDDataCard( DATA )
' Name:    Function ReadIDData
' Input:
' ByRef Data As EIDIdentity - EID Identity information
' Output:
' TRUE when information is successfully received from the card;
' otherwise returns FALSE
' Purpose:
' Read identity information from Belgian eID card
' Remarks: None
Return ( CallDll32( 'ReadIDData' , cDll , DATA ) )
aqui la imagen del error. / Here the image of the error.
eIDnative Library to access the Belgian Electronic Id and SIS Card.jpg (71.39 KiB) Viewed 7188 times
tengo una variable NUMERICA antes que un variable LOGICA, no encuentro el error, algunas de las funciones retornan valores correctos y eso me hace perder y dudar que estoy haciendo mal.
esta es la aplicacion completa
eIDReader.rar
(188.39 KiB) Downloaded 381 times
gracias por la ayuda.
I have a numeric variable rather than a logical variable, can not find the error, some of the functions return correct values ​​and that makes me doubt lose and I'm doing wrong.
This is the complete application
[attachment = 0] eIDReader.rar [/ attachment]
thanks for the help.
Re: CardReader
Code:
' Input:
' Output:
' Purpose:
' Remarks: None
Hola Daniel.
No se si será de ayuda pero la función CallDll32() no permite el paso de parámetros por referencia.
Un abrazo,
Claudio.
Re: CardReader
srvet_claudio wrote: Hola Daniel.
Un abrazo,
Claudio.
Hola Claudio:
Como decia anteriormente, "Algunas funciones trabajan nomarmelte"
Procedure ReaderName()
    CallDll32( 'GetReaderName' , cDll , nReaderConnect - 1 , cGetReaderName , nReaderNameLen )
    If  ( nReaderConnect == 1 .or.  nReaderConnect = 1 )
    eIDReader.cReaderName.Value := 'Reader Name : ' + cGetReaderName
              // ok --> OMNIKEY CardMan 3x21 --> ¡¡ Correct !!
    SelectReaderCardbyNumber( nReaderConnect - 1 )
    Endif
Procedure ReaderListCard()
lei un poco de c++ ayer para empaparme , sin embargo no comprendo esto
"4.- Paso de parámetros por valor y por referencia" , PDF
en Pascal trabajo comodamente pero en c++ se me complica un poco a pesar de ser estructurado los 2 no llego a comprenderlo
