CardReader
CardReader
Hello again,
Anybody any idea how to read the contence of a (Belgian) ID-card from a cardreader.
(eID-viewer --> beid35gui.exe).
I need to capture name, address and ID.
Thx in advance for showing the way !
Re: CardReader
Hola Serge :
aqui le encontre la solución, tiene todo lo necesario para trabajar con EID Library.
Hi Serge:
I found the solution here, has everything you need to work with EID Library.
http://sourceforge.net/projects/eidnative/?source=dlp
if you need other help just tell
desde/ From Buenos Aires Argentina.
Re: CardReader
Hello,
danielmaximiliano thx, I will take a look tonite!
S
Re: CardReader
serge_girard wrote:Hello,
S
Install Library EID. Use CallDll32
Re: CardReader
Daniel,
I installed EID lib.
How do I tell HMG Ide to use EIDReader.lib?
Then I do something like: CallDll32("InitReader", "EIDReader.dll", parameters...) ?
Thanks for helping!
Re: CardReader
serge_girard wrote:Daniel,
Thanks for helping!
Hi Serge:
in C:\Program Files (x86)\EIDNative Library\Documentation
Several aid .CHM containing various functions , can make calls as indicated CallDll32 mendiante you or treat it as COM object (ActiveX), I have a device; such as that used to help better.
Read C:\Program Files (x86)\EIDNative Library\EID VB6\EIDNative.bas to better interpret the functions
Re: CardReader
Daniel,
This is all new to me and to tell the truth: I don't quite well understand it.
The EIdReader.DLL is in the windows directory.
What about EIDReader.LIB ??
When I do:
par = 0
A = CallDll32("InitReader", "EIDReader.dll", par)
A will get the value 257
Can you give a small example on how some of the function are to be called?
Thx !
Re: CardReader
When I do:
par = 0
Thx !
Hello Serge :
before initializing the first eID reader would bring a list of names connected readers.
after that connect the reader who would like to use.
try using the eID readers name, the same can be uploaded to the control COMBO and thus select from there.
so I have no idea if you use handler a third parameter as the library eID
#include 'hmg.ch'
Local aNames      := {}
Local cSelectName := ''
Local cFunction   := ''
aNames := CallDll32('GetReadersList', 'EIDReader.dll' )
If Len( aNames ) = 0
   MsgInfo( ' Not CardReader Installed ' , ' Message Information ' )
   Exit
Endif
cSelectName := aNames [ 1 ]
cFunction   := 'SelectReaderByName( ' + cSelectName + ' ) '
CallDll32( cFunction , 'EIDReader.dll' )
/*** Init ***/
CallDll32( 'InitReaderEx' , 'EIDReader.dll' )
/*** or Init ***/
CallDll32( 'InitReader' , 'EIDReader.dll' )
/* You code here. */
might have to make some modifications to the code, as I said before I have not a reader like to help you better.
Re: CardReader
Thx Daniel,
I'm sure this will help a lot.
When it's functioning I will suggest it to the SAMPLES !
Bye,
Re: CardReader
Hi Daniel,
I'm on my way but a few things are stille strange to me.
I can retrieve the name of the card-reader, check if a card is inserted and check if correct-card is inserted.
But when it comes to retrieving card-data: nothing.
I think the problem is the parameters:
Declare Function ReadAddress Lib "EIDReader.dll" (ByRef pData As EIDAddress) As Boolean
Type EIDAddress
street As String * EID_MAX_STREET_LEN
zip As String * EID_MAX_ZIP_LEN
municipality As String * EID_MAX_MUNICIPALITY_LEN
End Type
// EID address information, stored on the card
EID_Address =
record
// Street name
street : array[0..EID_MAX_STREET_LEN] of AnsiChar;
// ZIP code
zip : array[0..EID_MAX_ZIP_LEN] of AnsiChar;
// Municipality
municipality : array[0..EID_MAX_MUNICIPALITY_LEN] of AnsiChar;
end;
Now I do: (which is working fine)
var = CallDll32( 'IsEIDCard' , 'EIDReader.dll' ) // this work OK
IF var == -1
msginfo('IsEIDCard' , 'OK')
msginfo('NO IsEIDCard' , 'NOK')
num_readers = CallDll32( 'GetReadersCount' , 'EIDReader.dll' ) // this work OK
msginfo(str(num_readers,3,0) + ' CountReaders' , 'OK')
But for ADDRESS I trief similar manners but none works.
Any idea how to construct the parameterslist?
Greetings from Belgium,
