How I can to send a varieble to LABEL?
Jairo Maia
Post by Jairo Maia »
There are a way for me to send a variable in LABEL? E.g.:
Label_Definition := "Label_Name"
@ 10,10 LABEL Label_Definition	;
		            VALUE 'Name'		;
		            WIDTH 140		;
		            HEIGHT 30		;
	                          FONT 'Arial' SIZE 09		;
	                          BACKCOLOR WHITE	;
	                          FONTCOLOR BLUE BOLD
If I change file i_label.ch that is way:
   _DefineLabel (      ;
   <"name">  ;
for this way:
   _DefineLabel (      ;
   <name>  ;
it work. So, only if i send the label definition by varieble. Is possible to change for to use the both situations?
Re: How I can to send a varieble to LABEL?
Ola Jairo
Jairo Maia wrote:There are a way for me to send a variable in LABEL? ...
I guess this will run:
@ 10,10 LABEL &Label_Definition ;
VALUE 'Name' ;
WIDTH 140 ;
HEIGHT 30 ;
BACKCOLOR WHITE ;
FONTCOLOR BLUE BOLD
( Not tested :( but remembering something like this )
Desculpem cavalheiros, não sei se já resolveu com a indicação que colega Esgici fez. Mas eu não entendi direito, Jairo: você quer mudar o nome da label ? Ou deixar variável o conteúdo do label ?
Excuse me gentlemen, I do not know now if was solved with the indication from our colleague Esgici. But I did not get it right, Jairo, you want to change the label name ? Or to leave variable the label content ?
Jairo Maia
Hello Esgici,
esgici wrote:I guess this will run:
I tried it, end I get the error: Sintax Error
Olá Pablo,
Pablo César wrote:você quer mudar o nome da label ? Ou deixar variável o conteúdo do label ?
I want to pass the Label definition by variable.
How I said above, I want to know if there are a way for change the file i_label.ch where I can pass the Label definition in both modes:
By Varieble:
By Default mode:
@ 10,10 LABEL Label_Name
Best Regards
Jairo Maia wrote:Hello Esgici,
Hi Jairo.
Probably you defined the LABEL outside of the DEFINE WINDOWS adds PARENT Form_XX
@ 10,10 LABEL &Label_Definition PARENT Form_XX VALUE 'Name' WIDTH 140 HEIGHT 30 FONT 'Arial' SIZE 09 BACKCOLOR WHITE FONTCOLOR BLUE BOLD
Claudio.
Jairo Maia wrote:...I tried it, end I get the error: Sintax Error
Olá Jairo
I haven't any idea how you acquire this error :?
But this sample worked nice for me :
PROC Main()
   DEFINE WINDOW frmMILCName ;
      AT        0,0 ;
      WIDTH     400 ;
      HEIGHT    200 ;
      MAIN          ;
      TITLE     "Using macro substitution in Label Control Name"
      ON KEY ESCAPE ACTION frmMILCName.Release
      @  10, 10 LABEL &Label_Definition ;
                VALUE 'Name'	 ;
                WIDTH 140	 ;
                HEIGHT 30	 ;
                FONT "Arial" SIZE 09 ;
                BACKCOLOR WHITE ;
                FONTCOLOR BLUE BOLD ;
                ACTION { || MsgBox( This.Name ) }
   frmMILCName.Center
   frmMILCName.Activate
RETU // Main()
In addition in an old sample this macro substitution used for other controls too ( Caution : direct download link for .zip file )
Jairo Maia wrote:I want to pass the Label definition by variable.
Assumed you have intended "control name" with "Label definition". If you want mean another thing, please explain more precisely.
Jairo Maia
esgici wrote:Olá Jairo
Hello Esgici, you're right.
As you know, I am a beginner in HMG. So, in recent months I was studying and altering a series of tests in the SAMPLES folder and changing multiple files.
I do not know when and even where I changed something that detracted my work with HMG.
I did not can compile your example, so I decided to uninstall and reinstall my HMG.
Now everything is working properly.
Thanks to colleagues Pablo and Claudio for to have dedicated time to help me too.
Jairo Maia wrote:...Now everything is working properly.
Alright Jairo,
