BOS TAURUS: Questions and Suggestions
- srvet_claudio
Hi all.
As suggested by Daniel Maximiliano, I created here a topic for questions and suggestions on Bos Taurus (graphic library for HMG).
Best Regards,
Claudio Soto.
Best Regards,
Claudio Soto.
Re: BOS TAURUS: Questions and Suggestions
First of all I wish the best for this graphics library.
For me HMG is just the sweet wrapper of clipper/harbour over the bitter c/c++. Roberto's design of hiding the inner parts of the logic which the user need not know about is very successful. A person who starts using HMG doesn't need to know about Device Context for example.
So, my humble suggestion is having wrapper functions or an alternate syntax like the below:
DEFINE GRAPHICSAREA of Form1
DRAW LINE FROM nRow, nCol TO nRow, Col COLOR { nR, nG, nB }
DRAW CIRCLE AT nRow, nCol RADIUS nRadius
DRAW IMAGE cPicture AT nRow, nCol
END GRAPHICSAREA
CLEAR GRAPHICS AREA OF Form1 FROM nRow, nCol TO nRow, nCol
- srvet_claudio
Thanks Rathi, very good and very wise suggestion.rathinagiri wrote:So, my humble suggestion is having wrapper functions or an alternate syntax like the below:
Code:
END GRAPHICSAREA
- srvet_claudio
Hi Marek,mol wrote:I have a question - I've read documentation of Bos Taurus, and it looks it is possible to create image file with this library. Am I right?
If yes, can you place a little sample presenting creating images?
I'm working on a little label maker and I want to build preview of label - it could be easy with BT...
Here leave you an example, I hope you find useful.
Claudio
- create_logo.rar
- (44.6 KiB) Downloaded 1400 times
As wonderful as simple!
It will be great supplement for label generator, which I built-in my billing application.
I'll try to prepare standalone working sample.
I found and used BT_BitmapSaveFile(hBitmap, cFileName)
Working fine, but, how to output generated image to png/jpg file?
Is it possible?
Second question: Is there a method to set horizontal and vertical DPI parameter?
Many thanks, Claudio!
Is it possible?
- srvet_claudio
Hi Marek.mol wrote:It will be great supplement for label generator, which I built-in my billing application.
I'm glad you find it useful.
Please post here to see it.mol wrote:I'll try to prepare standalone working sample.
Very easy.mol wrote:One question: how to output generated image to png/jpg or bmp file?
BT_BitmapSaveFile (hBitmap, cFileName)
Save an image in format BMP (24 bpp) in the disk.
hBitmap: is a handle to the bitmap image.
cFileName: is the name of the file to save.
Best Regards,
Claudio.
- srvet_claudio
No, BT only saves images in BMP format (24 bpp), you would have to convert the final image into Windows Paint, etc.mol wrote: I found and used BT_BitmapSaveFile(hBitmap, cFileName)
Is it possible?
Again the answer is nomol wrote: Second question: Is there a method to set horizontal and vertical DPI parameter?
Regars,
Claudio.
THX again!
I'll try to find solution...
Marek
Marek
Hi Marek,
I think you can use hbfimage library.
http://freeimage.sourceforge.net/features.html
These are the features.
I worry I'm not familiar with C language too ehough to use such a library
