HMG 3.0.46
IMATECH
Re: HMG 3.0.46
Post by IMATECH »
Thanks Rathi and Claudio
Nice upgrade ;)
M., Ronaldo
By: IMATECH
Imation Tecnologia
fouednoomen
Re: HMG 3.0.46
Post by fouednoomen »
Congratulations
Foued
Re: HMG 3.0.46
Gracias Rathinagiri :
estoy utilizando para generar la aplicacion Incomming Gmail/yahoo/Hotmail y funciona sin ningún problema.
gracias por su tiempo y esfuerzo ..
Google Translate
Thanks Rathinagiri:
I am using to build the application Incomming Gmail / Yahoo / Hotmail and works without any problem.
Thanks for your time and effort ..
Gmail Incomming Mail Server _2012-11-06_18-55-46.jpg (69.25 KiB) Viewed 20838 times
Re: HMG 3.0.46
Thank you Rathinagiri and Claudio ! You are so great !
Really very good improvements in HMG lib !
Congratulations !
Re: HMG 3.0.46
I've tried to compile DEMO10 of HCFL Bos Taurus and errors occured with multiple definitions of functions.
How can I resolve it?
Re: HMG 3.0.46
mol wrote:I've tried to compile DEMO10 of HCFL Bos Taurus and errors occured with multiple definitions of functions.
Hi Marek,
this is the solution:
srvet_claudio wrote:Hi all.
Error when compiling examples of HFCL.
SOLUTION: eliminate the incremental directive (-inc) in line 2 of the file:
C:\hmg.3.0.46\HFCL\Source\hfcl.hbp
and re-build the HFCL library
(execute C:\hmg.3.0.46\hfcl\Source\buildlib.bat).
Best Regards,
Claudio Soto.
Claudio
StarGazer2112
Re: HMG 3.0.46
Post by StarGazer2112 »
Waaaay to goooooo !!!! :D :D :D :D
Thanks !
danielcrocciari
DBs Used: DBF, MySQL, SQLite
Re: HMG 3.0.46
Post by danielcrocciari »
Everything perfect in the installation, I found the problem to compile all my projects.
Thank you.
Daniel Crocciari
Brasil - Japan
Projetos HMGLights
HMGLights Site
Canal do YouTube
http://www.youtube.com/hmglights
Céu Azul Tecnologia & Software
http://www.ceuazul.net
Re: HMG 3.0.46
Hi :
C:\hmg.3.0.46\SAMPLES\USER.COMPONENTS\demo.prg Not Work.
Harbour 3.2.0dev (Rev. 18443)
C:\hmg.3.0.46\SAMPLES\USER.COMPONENTS\demo.prg(22) Error E0030 Syntax error "syntax error at '.'"
C:\hmg.3.0.46\SAMPLES\USER.COMPONENTS\demo.prg(23) Error E0030 Syntax error "syntax error at '.'"
C:\hmg.3.0.46\SAMPLES\USER.COMPONENTS\demo.prg(24) Error E0030 Syntax error "syntax error at '.'"
C:\hmg.3.0.46\SAMPLES\USER.COMPONENTS\demo.prg(25) Error E0030 Syntax error "syntax error at '.'"
C:\hmg.3.0.46\SAMPLES\USER.COMPONENTS\demo.prg(34) Error E0030 Syntax error "syntax error at '@'"
5 errors
4 errors
