HBtip good news
HBtip good news
Hola a todos / Hi all :
despues de mucho renegar con Gmail y la libreria HBTIP pude compilar el ejemplo Gmail y enviarme un Email a mi cuenta de Yahoo mail.
after much renege with Gmail and HBTIP library could compile the example Gmail and email me at my Yahoo mail.
Pasos / Steps :
1) Download Harbour sources https://harbour-project.svn.sourceforge ... nk/harbour
2) Download Harbour Nightly http://sourceforge.net/projects/harbour ... irror=ufpr
3) Modify gmail.prg modify their email data.
 * $Id: gmail.prg 18289 2012-10-11 16:16:32Z vszakats $
 * Copyright 2009 Viktor Szakats (harbour syenar.net)
 * www - http://harbour-project.org
#require "hbtip"
#include "simpleio.ch"
PROCEDURE Main( cFrom, cPassword, cTo )
   hb_default( @cFrom    , "danielmaximilianoherrera@gmail.com" )
   hb_default( @cPassword, "12348567890" )
   hb_default( @cTo      , "danielmaximiliano@yahoo.com.ar" )
   ? hb_SendMail( "smtp.gmail.com",;
                  465,;
                  cFrom,;
                  cTo,;
                  NIL /* CC */,;
                  {} /* BCC */,;
                  "test: body",;
                  "test: subject",;
                  NIL /* attachment */,;
                  cFrom,;
                  cPassword,;
                  NIL /* nPriority */,;
                  NIL /* lRead */,;
                  .T. /* lTrace */,;
                  .F.,;
                  NIL /* lNoAuth */,;
                  NIL /* nTimeOut */,;
                  NIL /* cReplyTo */,;
                  .T. )
4) go to the folder C:\Harbour\contrib\hbtip\tests open a command window.
5) from the command line , Then run gmail
c:\hb32\bin\hbmk2 -lhbtipssl -lhbssl -llibeay32 -lssleay32 -env:HB_TIP_OPENSSL=yes gmail.prg
Administrador Cwindowssystem32cmd.jpg (107.29 KiB) Viewed 9546 times
6) Gmail runs and answer with true on success
.T.
7) check your account alternative or gmail to verify the correct operation.
(2 no leídos) - danielmaximiliano - Yahoo! Mail - Mozilla Firefox_2012-10-17_21-30-16.jpg
(2 no leídos) - danielmaximiliano - Yahoo! Mail - Mozilla Firefox_2012-10-17_21-30-16.jpg (81.26 KiB) Viewed 9546 times
Now we have two tools to work with our Email from Harbour
HBTIP and CDOSYS, two different flavors!
enjoy
post data : I'll see you needed to use HBTIP in HMG.3.0.44
IMATECH
Re: HBtip good news
Post by IMATECH »
Thanks Daniel !
Will be very usefull...
Best regards...
M., Ronaldo
By: IMATECH
Imation Tecnologia
Re: HBtip good news
That is it!
Thanks a lot!
Re: HBtip good news
rathinagiri wrote:That is it!
Thanks a lot!
easy but gave many headaches, Tiptest works wonders.
Now to figure out how to read email from Gmail.
Dedo OK.jpeg (31.81 KiB) Viewed 9527 times
Re: HBtip good news
Thanks a lot!
Problema resuelto por el amigo Alex Gustow / Problem solved by friend Alex Gustow
How to get attachment(s) from mail? : http://hmgforum.com/viewtopic.php?f=5&t=967
Re: HBtip good news
Yesterday 04/11/2012 there was an updated HBtip, included a batch file to compile the example Gmail.prg
Thanks Viktor Szakats to improve Harbour every day, many users will be grateful for improving the compilation of this library with SSL support.
batch file in C:\hb32\contrib\hbtip\tests\Gmail.bat
@echo off
set HB_WITH_OPENSSL=c:\openssl\include\openssl
set HB_STATIC_OPENSSL=yes
set backup=%path%
set path=%backup%;c:\hb32\bin
set path=%backup%
paimar
Re: HBtip good news
Post by paimar »
Hi. Any sample for reading gmail mail for dummies (excuse my horrible english)
Hola. Algun ejemplo de leer el correo de gmail para dummies?
thanks/gracias
Gipuzkoa - ESPAÑA
Re: HBtip good news
paimar wrote:Hi. Any sample for reading gmail mail for dummies (excuse my horrible english)
thanks/gracias
Hola Paimar:
estoy armando el ejemplo para leer los corres de Gmail, mire todas las funcions que contiene la Libreria HB_tip y apenas tenga algo desarrollado lo publico.
no uso Gmail en mis aplicaciones ni nada que sea Email; pero a muchos amigos de Harbour tienen ese inconveniente.
Re: HBtip good news
thanks/gracias
http://hmgforum.com/viewtopic.php?f=9&t=2559
ahi tenes lo que pedias, falta un poco mas pero creo que te ayudara.
cualquier cosa lo sigo mejorando.
