HMG_HPDF - Export to PDF made easy... (New Version)
- esgici
Hi Nikos
Did you tried "Symbol" ( Base 14) font ?
Viva INTERNATIONAL HMG
Hi Esgici,
This is the result of using SYMBOL. As you can see it does not work
Rgrds
Nikos
Rgrds
Nikos
- SnapCrab_NoName_2012-10-30_11-6-13_No-00.png (4.79 KiB) Viewed 7210 times
- SnapCrab_NoName_2012-10-30_11-5-41_No-00.png (7.4 KiB) Viewed 7210 times
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Nikos.
- esgici
Hi Nikosquartz565 wrote:This is the result of using SYMBOL. As you can see it does not work
In .pdf produced in this thread viewtopic.php?f=9&t=2497&start=80#p22288 I see Greek letters.
Perhaps you need use Latin letters instead of Greeks.
I know, this isn't a good way
I'm working in this concept; I'll notice when found a solution.
Regards.
- Greek Letters in Base14 Symbol fonts
- GreekLetters.PNG (6.33 KiB) Viewed 7208 times
Dear Nikos,
It seems that the problem is with the LibHaru library. When I had searched for solutions, I found this discussion. Hope it is useful for you.
https://groups.google.com/forum/?fromgr ... isacjpIVZo
Hi Antony,
Sorry to bug you, but I have tried all the encodings for single byte but still couldn't get it done.
I also tried multibyte encoding, but only the combination: "MS-Gothic" / " MS-Mincyo" - "90ms-RKSJ-H" works. It won't work for Helvetica or TTF's. By the way, is multibyte encoding supported for Helvetica/Times/Courier?
2008/5/27 Antony Dovgal
- esgici
Hi All
Another sample for HMG_HPDF : Fonts and Code pages.
I can't achieve applying "national" character sets
Any support appreciated.
Hi Esgici,
latin instead of greek is not the best solution for outside use.
i'm looking forward to your news when you find a solution to the concept that you work on.
thank you very much
hi Rathinagiri,
I saw the whole conversation, but I don't know how this is gonna help me.
which window's fonts can i use for tests in the program?
thanks for your help
thank you very much
hi Rathinagiri,
Best Regards,
Nikos.
Nikos.
- esgici
Hi Rathi
I don't know if you have some plans to develop some high level approach for loading TTF file
If so, please don't care about my humble work.
- Roberto Lopez
- HMG Founder
VERY VERY IMPRESSIVE!rathinagiri wrote:Here I am uploading again a NEW version of HMG_HPDF:
This version includes the following new commands/enhancements:
In the sample, I have tried to draw a Rounded Rectangle using Lines and Curves. So, my next enhancement will be RoundedRectangle of user given parameters.
Enjoy!
I'm just going to add pdf reporting capabilities to my hmgscript project and this will be a great solution for it.
It is simple, easy an inline with the HMG philosophy... it is PERFECT!
A BIG THANKS!
- Roberto Lopez
- HMG Founder
And... IMHO, it should be an integral part of HMG.Roberto Lopez wrote: It is simple, easy an inline with the HMG philosophy... it is PERFECT!
Perhaps, we should found some mechanism to make possible to use a syntax more like standard HMG print system.
I mean, instead @ <Row> , <Col> HPDFPRINT, use @ <Row> , <Col> PRINT.
I guess that could be done using a #define and then an #ifdef, so, we could have similar commands as standard print system.
From now, I'll base all my new developments printing on HPDF.
Thanks again.
