HMG_HPDF - Export to PDF made easy... (New Version)
Thank you Esgici.
Hello to everybody.
Please check the following. When I use the CP1253, I do get the correct language but the spacing betwwen the characters in the pdf print is wrong. It is too small, so the characters in a word are placed almost on top of each other. See the example.
It shows the definition of the code page and how it is printed.
Any help will be appreciated.
Nikos
Nikos
- SnapCrab_NoName_2012-10-27_13-27-13_No-00.png (23.16 KiB) Viewed 7166 times
- SnapCrab_NoName_2012-10-27_12-34-3_No-00.png (6.5 KiB) Viewed 7166 times
- SnapCrab_NoName_2012-10-27_12-32-39_No-00.png (12.12 KiB) Viewed 7166 times
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Nikos.
Hi
Thanks for reporting. Please upload the sample prg after zipping. Or send to my email id srgiri@dataone.in
FYI Character spacing feature can be added.
Hi,Rathinagiri
here it is the ''prg'' that you asked.
Thank you for the immidiate response.
Nikos.
Nikos.
- Main.rar
- (2.07 KiB) Downloaded 419 times
Best Regards,
Nikos.
Nikos.
This is how I have received. But your version in the picture is different. Can you please give the exact one as in your picture above?
@ 10, 60 HPDFPRINT 'ÃÅÉÁ ÓÁÓ ÖÉËÏÉ' // My intervention
@ 15, 20 HPDFPRINT 'ÃÅÉÁ ÓÁÓ ÐÁÉÄÉÁ' color { 255, 0, 0 } // My intervention
@ 15, 100 HPDFPRINT 'ÁÕÔÏ ÅÉÍÁÉ Ýíá ðáñÜäåéãìá' font 'Times-Italic' size 14 // My intervention
The version is the same.
In your Notepad++ at menu “Enconing in “-> “character set”, select Greek-> windows -1253, maybe this resolve the problem.
Nikos
Nikos
Best Regards,
Nikos.
Nikos.
Hi rathinagiri
This is in photo, part of the code with Greek characters
and the same code with Notepad++
- SnapCrab_NoName_2012-10-28_0-26-59_No-00.png (43.19 KiB) Viewed 7143 times
Best Regards,
Nikos.
Nikos.
and the code...
Best Regards,
Nikos.
Nikos.
and the code...again...
sorry... new to uploand files...
- Part_of_Main.rar
- (807 Bytes) Downloaded 394 times
Best Regards,
Nikos.
Nikos.
Hi Rathinagiri,
Did you manage to view the Greek characters? I could send it to you into PDF format, so to export it into an editor if you prefer.
Best Regards,
Nikos
Best Regards,
Nikos
Best Regards,
Nikos.
Nikos.
