Little DBU-GUI-Tool with HPDF-Export in HMG 3.0.44
Source code related resources
klauskugel
Post by klauskugel »
I just want to show my interest in HMG and hope my little
Alpha-Version is not to buggy for sincere use.
HMG-Greetings :D
KlausKugel
mydbu.zip
GUI-DBU-Tool with HPDF-Export and
Encryption.
(480.78 KiB) Downloaded 675 times
Re: Little DBU-GUI-Tool with HPDF-Export in HMG 3.0.44
It is sure a nice utility. Happy to see HMG running well in Wine too.
Hi Klaus
klauskugel wrote:I just want to show my interest in HMG and hope my little
Alpha-Version is not to buggy for sincere use....
Your DBU tested; congrats, good application, nice sharing :)
Appereantly you aren't new in neither programming nor HMG world ;)
We could wait more samples / utilities from you :)
Screen shoot of Klaus DBU
Good Utility
Thank you Mr. klauskugel
fouednoomen
Post by fouednoomen »
I couldn't build this program under HMG 3.0.46
Could you please send me the exe File
Many thanks in advance
Foued
Hi Foued.
I tested with HMG 3.0.46 and work fine.
It's probably a problem with the HFCL library.
See the post:viewtopic.php?p=22569&f=2#p22569
Best Regards,
Claudio Soto.
fouednoomen
thanks for your prompt replay but i could not understanding the problem
fouednoomen wrote: i could not understanding the problem
If the problem is the HFCL library you have to re-compile:
1) eliminate the incremental directive (-inc) in line 2 of the file: C:\hmg.3.0.46\HFCL\Source\hfcl.hbp
2) and re-build the HFCL library (execute C:\hmg.3.0.46\hfcl\Source\buildlib.bat).
Hi Foued
fouednoomen wrote:I couldn't build this program under HMG 3.0.46...
Me and many other friends built and run this program without problem.
And without knowing cause of "not build" we can't help you.
I hope my way to build will help you:
- Open "mydbu.zip" to a <dir> named "mydbu".
- open mydbu\hbhpdf\tests\dbu3_hmg3044.hbp project file by HMG-IDE
- click "run" button or select Project\Run ( F5 )
That's all :arrow:
If any problem or error occurs please notice at least error message to us.
fouednoomen
Please find in this attached file
the error when i build the program
