IMATECH
Post by IMATECH »
Hi Esgici !
Then it is only your opinion ( Nothing started from Harbour Management Team )
In respect to your person I will finish any reply to your posts ( here only )
M., Ronaldo
By: IMATECH
Imation Tecnologia
Chacal.GO wrote:Hi Esgici !
Do you understand English ?
Does I said anything different ?
What is meaning of only I write one "H" opinion :?:
Pablo César wrote:Mr. Grigory, now with your example I noted your indication it is for fixed color in all rows. But I needing to change color according a existing file at each row. So its could change color according each row in two diferent situations. Please see in my code source at line 1979.
Now I got It but with one particular restriction. HighLighted_Row's Color can be changed as Mr. Grigory indicated, but Grid MUST be in CELLNAVIGATION to .T.
Also very important to be mentioned: colors must be defined as CONSTANTs otherwise can not applied as simple ARRAY.
In blue color when is normal itens without any process:
In rede color when there is a process vinculated with each field. Just to call attention of users:
I would also like to change FONTCOLOR of button "Processos"... but still not found the way... :(
Thanks, Grigory !
New Release 4.2 with grig highlighted color changing by condition.
<Attached file removed, see last message with new release>
STRU - Access DBFS into SpecialFolders denied
SpecialFolder to which I refer are the folders like "C:\Documents and Settings\Pablo César\My Documents" etc.
In Stru I want to add one more option. The ContextMenu that works in Explorer. That is, by pointing and clicking with the right mouse button on a file dbf, can give one more option: Stru - List. Then the user can list the structure of dbf from within Explorer.
But today I noticed something very strange, if I have a file in dbf SpecialFolder, it does not open and gives error, aborting the program. So I started doing a series of tests to circumvent this problem. Do not know yet if it's for XP and not be for lack of rights as administrator. So the next step and attempts suppose cPath:="C:\Documents and Settings\ Pablo César\ My Documents\" :
1. I put If! File (cPath+CDBF) and even though the dbf file is there, he returns as nonexistent.
2. Funny thing, I think this is the subject of hackers ... hihi, he accepts the cPath as "C:\DOCUME~1\PABLOC~1\MEUSDO~1", ie short names in standard 8x3. Hence opens and read it normally. STRU also works in command line already positioned in the folder C:\Documents and Settings\Pablo César\My Documents.
3. Tried to get me ShortPathName and returns empty. That is, the system can not see the folder which in this case is a SpecialFolder.
4. I also tried to position myself within the folder in program execution. But nothing.
5. Neither IsDirectory() function, which always worked well.
Has anyone gone through this. From what I remember, as happened to many, but it was Clipper. And I always put Clipper into the way in short order and always worked in the same SpecialFolders. Now the user can select the file by GetFile if he select a dbf which is within the My Documents will not work. And I do not think I can copy this folder into another dbf, because there is recognized.
Can anyone give me a light?
Ola Pablo
"Special folders" is pretty complex subject :(
Has different visions between Win.Explorer and DOS (command) window.
I recently noticed that, there is "JUNCTION" term instead of DIR for "some" special folders in DOS box.
I don't know this will help you.
If you find a strong definition and usage rules for "special folders" please inform me too.
Saudação
Ohh thank you amigo Esgici, as always you are so kind !
I sent a MP to Dr. Soto, asking for any C code solution for these specialfolders cases.
Shall wait and I´ll revert to you.
Best regards
The "Setup" option now has one more item that allows access to STRU by clicking on DBF in Window Explorer:
Also operates by Context-Menu of Window Explorer:
For operating systems with UAC, will have to be run as Administrator so that all changes in the Windows REGISTRY, take effect:
With the coming of the HMG UNICODE mode, ensures the use of application in multi-languages​​. New implementations like as:
- Checks on SO is running as an administrator to change the LOG function of Windows.
- Check the build version of HMG, ensuring the implementation of new functions
- Verifies integrity of language files according the version performed
- Option STRU run in GUI mode from the command line
More tests will be needed to provide further more indications of possibles failures. I appreciate when you have this availability.
Important: Do not forget to delete the STRU.INI it now has new structure (cleaner), will also be necessary to replace the .LNG (language files) and be re-edited the ones have been converted to the UNICODE mode.
mol wrote:There is problem with Polish characters in console mode still.
It's because console mode uses CP-852 and graphics mode uses CP-1250.
Polish ascii codes are different in both codepages.
Only one way to resolve thi problem, is to declare different language files.
Hi Mr. Marek, I hope this problem have been solved with UNICODE mode at HMG. So please, could you re-edit POLISH.LNG in the new package of STRU.rar download and also please, delete Polish.TLg or rename it, just to make a test and see if is working properly. Could you do that for us please ?
Hi Dr. Soto, I have some questions regarding UNICODE adaptations in STRU.prg at function MakeLangArry, which is responsable to extract string from a language file in UNICODE format putting in ARRAY. Is presenting a diferences with first, last ans others elements of array. Please note in STRU.PRG at lines 2651 and 2653. For the last element it is needing to add an empty line at eof of language file.
It s strange these behaviour on different elementes of array (first one and last one). Probably depending to considere diferent EOF byte for recognition. What could be worng in my language files ?
