Toolbar bug ?
Toolbar bug ?
Hola a Todos:
revisando la aplicacion de nuestro amigo Leopoldo Lugones <leopoldo_6691@yahoo.com.mx>.
el TOOLBAR con 14 BOTONES solo muestra 9 de ellos y los siguientes pierde el CAPTION.
probando varias cosas me encontre que la falla se debe a la cantidad de CONTROLES que contiene la VENTANA.
sacando algunos controles hasta que el TOOLBAR muestra la totalidad de sus BOTONES sin ningun error.
cuantos CONTROLES soporta un VENTANA alguien sabe ????
dejo las imagenes.
Translate Google:
Hi Everyone:
reviewing the application of our friend Leopoldo Lugones <leopoldo_6691@yahoo.com.mx>.
The toolbar with 14 buttons only shows 9 of them and lost following CAPTION.
testing various things I found that the failure is due to the amount of controls contained within the window.
removing some controls until the Toolbar shows all its buttons without any error.
WINDOW CONTROLS few supports anyone know????
let the images
SISTEMA DE Clientes!!!_2012-10-11_21-47-38.jpg (104.54 KiB) Viewed 5650 times
SISTEMA DE Clientes!!!_2012-10-11_21-46-17.jpg (94.94 KiB) Viewed 5650 times
SISTEMA DE Clientes!!!_2012-10-11_21-44-13.jpg (103.99 KiB) Viewed 5650 times
I can send the complete code for the failure if needed.
can ask me for MP.
Re: Toolbar bug ?
Please make a small working sample. Let us work it out.
Re: Toolbar bug ?
rathinagiri wrote:Please make a small working sample. Let us work it out.
Hi Rathinagiri :
Demo :
SISTEMA DE Clientes!!!_2012-10-11_23-16-38.jpg (94.05 KiB) Viewed 5646 times
Sis2.rar
Drag & Drop Clientes.prg Over Mibuild.bat and compile with hmg.3.0.44
or double click over Mibuild.bat y enter only name "Clientes"
(19.32 KiB) Downloaded 366 times
Re: Toolbar bug ?
Yes, I can reproduce and confirm the problem. Let me research for the solution.
May be some C Gurus help us.
Re: Toolbar bug ?
rathinagiri wrote:Yes, I can reproduce and confirm the problem. Let me research for the solution.
Gracias/ Thanks Rathi
Re: Toolbar bug ?
Hi Daniel.
I checked your example and the bug appear in Windows 7 but not in Window XP.
Claudio.
Re: Toolbar bug ?
The problem exists in Vista too.
Re: Toolbar bug ?
Sorry, I was wrong.
This is in XP, the bug is always in the button number 10.
Claudio.
Re: Toolbar bug ?
srvet_claudio wrote:Hi Daniel.
Claudio.
Gracias / Thanks Claudio and Rathi
justo la maquina que tiene Windows XP no esta operativa en estos momentos, probe la aplicacion en Windows 7 Home premiun 64 con el mismo resultado, no funciona bien el Toolbar.
just the Windows XP machine that is not ready right now, I tried the application on Windows 7 Home premium 64 with the same result, the Toolbar does not work well.
Re: Toolbar bug ?
Hola a todos :
Resolvi de manera muy tosca el defecto que tiene el Toolbar.
sobre el evento On Init de la ventana Win_clie
DEFINE WINDOW Win_Clie;
   WIDTH AnchoWin ;
   HEIGHT AltoWin ;
   TITLE 'SISTEMA DE Clientes!!!';
   BACKCOLOR NIL;
   ON INIT ( ActRegClie('Ultimo'),IIF(Lastrec()==0,NuevoClie(.T.),NuevoClie(.F.)));
   CHILD
PROCEDURE ActRegClie(cParam)
Local cRegistro
Local nCodigo := 0
Local nBusca := 0
Local nReg := 0
Win_Clie.Button_10a.Caption := 'Ultimo'
Win_Clie.Button_11a.Caption := 'Ir A'
Win_Clie.Button_12a.Caption := 'Browse'
Win_Clie.Button_13a.Caption := 'Buscar'
Win_Clie.Button_14a.Caption := 'Salir'
MiArea('Clientes',1)
por ahora esa es la solución temporaria.
SISTEMA DE Clientes!!!_2012-10-12_14-21-54.jpg (106.64 KiB) Viewed 5566 times
