HMG_HPDF - Export to PDF made easy... (New Version)
IMATECH
Post by IMATECH »
Hi All !
Project to use hbHPdf and hbZebra in any Harbour app ( Lib/OS agnostic )...
Sources at:
http://www.pctoledo.com.br/forum/viewto ... =4&t=13571
Best regards...
A real documment using hbHPdf and hbZebra...
M., Ronaldo
By: IMATECH
Imation Tecnologia
HMG_HPDF with a small feature once again.
This time it is SET HPDFPAGE LINESPACING TO nSpacing.
This is useful to alter the linespacing between the lines printed using @..HPDFPRINT..TO command.
I have created a small documentation for HMG_HPDF using HMG_HPDF. :)
It will be acting as a better sample for HMG_HPDF since it almost uses all the commands of HMG_HPDF.
Hope this will be useful.
HMGHPDFDOC.zip
(202.11 KiB) Downloaded 418 times
rathinagiri wrote:I have created a small documentation for HMG_HPDF using HMG_HPDF.
Super :!:
TIA
Oh, you have replied so soon! I have changed the file to a newer version. Please download the latest one.
Chacal.GO wrote:Hi All !
Sources at:
Best regards...
Thank you. I think it will be very useful.
rathinagiri wrote:HMG_HPDF with a small feature once again.
I'm confused :?
Does line-spacing determined by <nRow> value of @ ... command ?
If we have 'print' without @ ... command; between such commands :
HPDF_PRINT BEGIN TEXT
HPDF_PRINT PRINT ...
HPDF_PRINT END TEXT
this will be super :!:
Best regards
IMATECH
Post by IMATECH »
Thanks Rathi... :)
M., Ronaldo
By: IMATECH
Imation Tecnologia
[/attachment]
Thank you Rathi for providing HMG_HPDF Manual using HMG_HPDF library, Excellant
Is it possible to set liespacing in normal printing?
Marek
IMHO, it is. Since all the printing is done using @ row, col we can fix the line spacing as we require. Isn't it?
Please consider this:
nLineSpacing := 5 // line spacing is 5 mm
nFirstRow := 10 // first row starts at 10 mm
nLastRow := 280 // last row is set at 280 mm
nCurrentRow := nFirstRow
lReportContinue := .t.
do while lReportContinue
   @ nCurrentRow, 10 HPDFPRINT cData
   nCurrentRow := nCurrentRow + nLineSpacing
   cData := CurrentRecord()
   if LastRecord()
      lReportContinue := .f.
   if nCurrentRow > nLastRow
      END HPDFPAGE
      START HPDFPAGE
enddo
HPDF_PRINT END TEXT
Hi Esgici,
I can't fully understand your proposition. Can you please explain using a small sample/template program as to how do you want?
