HMG_HPDF - Export to PDF made easy... (New Version)
Hi All !
Project to use hbHPdf and hbZebra in any Harbour app ( Lib/OS agnostic )...
Sources at:
http://www.pctoledo.com.br/forum/viewto ... =4&t=13571
Best regards...
Sources at:
Best regards...
- A real documment using hbHPdf and hbZebra...
- Capturar.PNG (115.88 KiB) Viewed 5833 times
M., Ronaldo
By: IMATECH
Imation Tecnologia
By: IMATECH
Imation Tecnologia
HMG_HPDF with a small feature once again.
This time it is SET HPDFPAGE LINESPACING TO nSpacing.
This is useful to alter the linespacing between the lines printed using @..HPDFPRINT..TO command.
I have created a small documentation for HMG_HPDF using HMG_HPDF.
It will be acting as a better sample for HMG_HPDF since it almost uses all the commands of HMG_HPDF.
Hope this will be useful.
- esgici
Superrathinagiri wrote:I have created a small documentation for HMG_HPDF using HMG_HPDF.
Thanks
TIA
Viva INTERNATIONAL HMG
Oh, you have replied so soon! I have changed the file to a newer version. Please download the latest one.
Thank you. I think it will be very useful.Chacal.GO wrote:Hi All !
Sources at:
Best regards...
- esgici
I'm confusedrathinagiri wrote:HMG_HPDF with a small feature once again.
Does line-spacing determined by <nRow> value of @ ... command ?
If we have 'print' without @ ... command; between such commands :
HPDF_PRINT BEGIN TEXT
HPDF_PRINT PRINT ...
HPDF_PRINT END TEXT
this will be super
Best regards
Thanks Rathi...
M., Ronaldo
By: IMATECH
Imation Tecnologia
By: IMATECH
Imation Tecnologia
Thank you Rathi for providing HMG_HPDF Manual using HMG_HPDF library, Excellantrathinagiri wrote:HMG_HPDF with a small feature once again.
[/attachment]
Is it possible to set liespacing in normal printing?rathinagiri wrote:HMG_HPDF with a small feature once again.
Marek
IMHO, it is. Since all the printing is done using @ row, col we can fix the line spacing as we require. Isn't it?Is it possible to set liespacing in normal printing?
Please consider this:
nLineSpacing := 5 // line spacing is 5 mm
nFirstRow := 10 // first row starts at 10 mm
nLastRow := 280 // last row is set at 280 mm
nCurrentRow := nFirstRow
lReportContinue := .t.
do while lReportContinue
@ nCurrentRow, 10 HPDFPRINT cData
nCurrentRow := nCurrentRow + nLineSpacing
cData := CurrentRecord()
if LastRecord()
lReportContinue := .f.
if nCurrentRow > nLastRow
END HPDFPAGE
START HPDFPAGE
enddo
Hi Esgici,Does line-spacing determined by <nRow> value of @ ... command ?
HPDF_PRINT END TEXT
I can't fully understand your proposition. Can you please explain using a small sample/template program as to how do you want?
