Mr. Esgici, you always are very kind and a gentleman ! Thank you !
Hi Pablo!
I want to report some problems/bugs with Polish.
When opening in text mode, you should use commands:
SET LANGUAGE TO POLISH
HB_CDPSELECT("PL852")
You should set as below in graphics mode:
HB_CDPSELECT("PLWIN")
I've modified stru.prg in this way:
Case Upper(IDIOMA)="POLISH"
SET CODEPAGE TO POLISH
everything looks good both in text and graphics mode.
I'm attaching polish.lng and polish.tln in zip file
polish.zip
(3.54 KiB) Downloaded 401 times
IMATECH
Post by IMATECH »
Hi All !
I think the better solution will bet set unicode support to this app...
A first step to do this: below ( if works: then delete any other reference like Language or Codepage )
.lng files need to be saved as unicode for corrrect screen show
// M., Ronaldo: 2012/10/09
// Class: Unicode support to Harbour app´s
STATIC PROCEDURE MR_Set_Lang_and_CP()
   /* Terminal and OS codepage */
   hb_SetTermCP( hb_cdpTerm() )
   Set( _SET_OSCODEPAGE, hb_cdpOS() )
   /* Set language for Gui */
   hb_langSelect( hb_UserLang(), "UTF8EX" )
   hb_cdpSelect( "UTF8EX" )
   ? hb_langname()
Best regards
M., Ronaldo
By: IMATECH
Imation Tecnologia
I have tried but unsuccessfully. It is compiling without error, error only happening at runtime displaying:
I suppose that need to add #include "hbapilng.h" but another errors is coming by this include: C:\hmg.3.0.44\harbour\include\hbdefs.h(56) Error F0029 Can't open #include file 'stdarg.h'
So, I need to know what I am doing wrong... :roll:
IMATECH
Post by IMATECH »
Are you using HMG 3.0.44 ?
If Yes: Try this code:
// PROCEDURE MAIN( ... )
* HMG MESSAGES - PT_BR ( uncomment for test purposes )
// SET LANGUAGE TO PORTUGUESE
// SET CODEPAGE TO PORTUGUESE
* UNICODE SUPPORT
// HB_GTSYS()
PROCEDURE HB_GTSYS()
REQUEST HB_LANG_PT
REQUEST HB_CODEPAGE_PT850
M., Ronaldo
By: IMATECH
Imation Tecnologia
Chacal.GO wrote:Are you using HMG 3.0.44 ?
Yes
I have tested by your tow indications, taking off (making like comments) like as:
then
But the result is not correct displayed when STRU is in console mode. Even using:
cText_to_be_displayed := hb_translate( cStr, "PT850", "UTF8")
The strange is when I try to use by this way:
cText_to_be_displayed := hb_translate( cStr, hb_UserLang(), "UTF8") // this is with error when try to compile.
Anyway seems is not going to work properly even lng files been in Unicode.
IMATECH
Post by IMATECH »
Hi Pablo !
Why are you using hb_translate ?
Just use sources and .lng files saved as Unicode...
Any modern editor support this feature...
cText_to_be_displayed := cStr
Alert( cText_to_be_displayed )
M., Ronaldo
By: IMATECH
Imation Tecnologia
Chacal.GO wrote:Why are you using hb_translate ?
Because my files is still in Ansi mode. This function should not translate to Unicode ?
I made your sugestion. I saved portuguese.lng in UTF-8 format. But now is with another kind of error. Does not recognize "&"... see error:
IMATECH
Post by IMATECH »
Hi Pablo !
I have downloaded your project for case study....
When understand core logic will make some tests, and give a new reply...
regards...
M., Ronaldo
By: IMATECH
Imation Tecnologia
IMATECH
Post by IMATECH »
Hi Pablo !
My 1st choice was not to use HB_TRANSLATE(), but whithout this I can't make this sample work correctly
Below a minimal sample for correct use of Ansi Files to UTF8
// HBMK2 file.prg -gtwin -gui
REQUEST HB_LANG_PT
REQUEST HB_CODEPAGE_UTF8
PROCEDURE Main()
   LOCAL cFile
   LOCAL cText
   /* Set language for Screen */
   // hb_SetTermCP( "UTF8EX" )
   SETMODE( 62, 164 )
   CLS
   cFile := 'English.Lng'
   cText := MemoRead( cFile )
   alert( cFile + ';;' + HB_TRANSLATE(  cText ,"EN", "UTF8" ) )
   cFile := 'French.Lng'
   alert( cFile + ';;' + HB_TRANSLATE(  cText ,"FRISO", "UTF8" ) )
   cFile := 'Italian.Lng'
   alert( cFile + ';;' + HB_TRANSLATE(  cText ,"ITISO", "UTF8" ) )
   cFile := 'Polish.lng'
   alert( cFile + ';;' + HB_TRANSLATE(  cText ,"PLWIN", "UTF8" ) )
   cFile := 'Portuguese.Lng'
   alert( cFile + ';;' + HB_TRANSLATE(  cText ,"PTISO", "UTF8" ) )
   cFile := 'Spanish.Lng'
   alert( cFile + ';;' + HB_TRANSLATE(  cText ,"ESISO", "UTF8" ) )
   cFile := 'Turkish.Lng'
   alert( cFile + ';;' + HB_TRANSLATE(  cText ,"TRWIN", "UTF8" ) )
M., Ronaldo
By: IMATECH
Imation Tecnologia
