HMG_HPDF - Export to PDF made easy... (New Version)
Thanks Rathi
rathinagiri wrote:It is all for the betterment of the code. Isn't it? :)
No doubt it's :)
Best regards
Now I am researching how to simplify outlines, thumbnails, page labels, annotations. Let us implement one by one.
rathinagiri wrote:Now I am researching how to simplify outlines, thumbnails, page labels, annotations. Let us implement one by one.
Thanks Rathi, very good news :)
Best regards
I am uploading a new version again. :)
pdf.zip
(273.99 KiB) Downloaded 471 times
This time it is Outlines:
Outlines are like Tree control of the PDF pages. It is easy for navigation and arrangement of the whole doc.
Outlines can be achieved using the following two commands:
1. SET HPDFDOC ROOTOUTLINE TITLE <cTitle> NAME <cName> [ PARENT <cParent> ]
2 SET HPDFDOC PAGEOUTLINE TITLE <cTitle> [ NAME <cName> ] [ PARENT <cParent> ]
Command 1
- It shall be used to create a simple ROOT.
- It will not point/refer any page in the PDF doc.
- NAME clause should be used to refer the name of the root in the future.
- If you omit PARENT, the outline will be a ROOT node otherwise, it will be a sub-root of a parent root/node.
Command 2
- It shall be used to create the outline reference of the current page in the doc.
- If the PARENT clause is omitted, the current page will be placed as a root.
- Use PARENT clause to make the current page reference to be inside a root. The root can be a ROOTOUTLINE or a PAGEOUTLINE referenced by its NAME.
- If you specify NAME clause, the page reference can be used as a ROOT and can be parent of other ROOTOUTLINE or PAGEOUTLINE.
- The current page can be referred in multiple outlines also. (as in the example, Page 5 is referred in two places)
If you omit both the commands, the page will not be referenced in the outline.
See the demo:
Note: Please set character encoding before, if you want to use the character encoding in the outline titles. Please check whether the character encoding for the titles are applied properly.
Excellant
Great :o
Best Regards
rathinagiri wrote:...This time it is Outlines...
And this is demo time ;)
HMG Reference Guide in .pdf format.
Not a real Guide, only a skeleton to test / demonstrate new feature : Outline.
Building .pdf with HMG_HPDF is really easy :)
Enjoy :!:
Screen shot of HMG RG demo
HPdf_HRG.zip
Source files for HMG RG Demo
(23.06 KiB) Downloaded 491 times
Thank you, esgici
Excellent for sharing
Super Esgici. :)
Really awesome Esgici.
Now we can search any word inside the document also.
