HMG_HPDF - Export to PDF made easy... (New Version)
esgici wrote:Hi Dave
bpd2000 wrote:...following commands...
Apparently you are a good researcher :arrow:
So you can build a good documentation ( user guide ) for HMG_HPDF, I think ;)
Wait, I will do it after completion of pdf lib
esgici wrote:Hi
IMHO it's time to introduce national characters subject ;)
You're right.
Polish national characters work bad in the sample :(
bpd2000 wrote:... I will do it after completion of pdf lib
Thanks Dave :)
mol wrote:...Polish national characters work bad in the sample :(
Ours too :(
Instead of viewing PDF file, you can print PDF file directly to default printer
Replace following command
"execute file 'sample.pdf'"
with
"SHELLEXECUTE( 0, "print" ,'sample.pdf')"
Enjoy
Thanks for the help!
Will it print to the default printer?
I am uploading with the new version:
pdf.zip
(1.61 MiB) Downloaded 445 times
In this version we can encode the pdf with different character encodings:
The command is:
SET HPDFDOC ENCODING TO <cEncoding>
Example: SET HPDFDOC ENCODING TO "CP1254"
These are all the possible encoding options: (from the LibHaru Documentation)
Kindly check and tell as I am not well versed with these encodings.
rathinagiri wrote:...Kindly check and tell as I am not well versed with these encodings.
Checked for my own language; result is perfect as always :)
Test result  of HPDFDOC SET ENCODING command
My test code is:
Test code for HPDFDOC SET ENCODING command
Thanks a lot Mr. Diamond :D
By the way, my friend Rathi, if you offended by my 3 Oct dated post ( about exception error ), please excuse me, at that time I was in a deep panic :(
Thanks again for your invaluable efforts for us :)
Best regards
It's really super news!
Thanks Rathi for your excellent work!
No way I will get offended Esgici. It is all for the betterment of the code. Isn't it? :)
