Does "+" fields are replaceable ?
FYI :
PROC Main()
  DBCREATE( "AInsTest", { { "FLD1", "+", 4, 0 } },,.T. )
  FOR nRec := 1 TO 3
      DBAPPEND()
  GO 2
  REPL FLD1 WITH 10
RETU
martingz
Re: Does "+" fields are replaceable ?
Post by martingz »
Esgici , I tested some time ago and gave me data type error
DBFCDX/1020
cant' be replaceable
Yes Martin
In Harbour exactly this is.
Thanks
Hi amigo Esgici,
This field "+" Autoincrement type, I never used before and I do not fully know how to use it (I means, if you delete a record should restores a value deleted for next use). This field type, seems is for FoxPro RDD not Clipper/Dbase. See tests I made:
Local cRDD:="Clipper"
// "Harbour/FPT"
// DBCREATE( "AInsTest", { { "FLD1"+"+", 4, 0 } },"",.T. )
cToRDD:=If(cRDD="Harbour/FPT",'DBFCDX','DBFNTX')
If !File("AInsTest.Dbf")
   DbCreate("AInsTest",{ { "FLD1", "+", 4, 0 } },cToRDD)
Endif
Use AInsTest
FOR nRec := 1 TO 3
    DBAPPEND()
GO Bottom
// REPLACE FLD1 WITH +10
MsgInfo(Str(FLD1))
It´s seems you can not make data replacement in this type of field. This is automatic increment value.
I make some implements in you code/example just to put in evidence that this field works automatically.
Probably value of autoincrement Step, can be changed in the 23rd Byte offset in Header Structure of dbf.
Read this:
http://www.dbf2002.com/dbf-file-format.html
and this:
http://www.jpmartel.com/bu02auto.htm
I also noted when I try to edit this dbf with autoincrement field, it is displaying an Error DBFNTX/1020 Data type error thru DBA.exe (for example). And in DBFView of Grigory Filatov, also can not edit but displaying a message "Edit of this field is not supported." but when try to see table´s properties, it´s interrupt with an error of array´s lenght.
Some weeks ago,Przemek Czerpak wrote about autoincrement fields on the harbour mailing list:
El 18/06/2012 15:31, Przemysław Czerpak escribió:
> Hi Juan,
> We do not have and fieldinfo actions which can be used to control
> autoincrement values (counter and step).
> I'll try to remember about it and them in the future.
> best regards,
> Przemek
> On Mon, 18 Jun 2012, Juan Gálvez wrote:
>> Any comments ?
>> El 23/05/2012 16:49, Juan Gálvez escribió:
>>> Hi all, Przemek,
>>> Is there any DbFieldInfo() to set/get the counter and step values of
>>> autoinc fields (+) ?
>>> Many thanks
>>> Juan
So, Ithink, once created autoinc field cannot be set by user.
Marek
Hi
Martin, Marek and Pablo probably understood that I had asked this question for learn the answer. By putting a special word FYI ( For Your Information ) at beginning of post I want say :
"NO ! as you see below sample, auto increment fields doesn't replaceable in Harbour".
Sorry for my weak English :(
Ola Pablo
Thanks to additional info :)
But; does my sample not evident to show how auto increment type fields work ?
Please look at see here for a sample for all extended field types added to Clipper implementation by Harbour.
And, as you know, since default RDD in Harbour is DBFNTX,
is equal to
DBCREATE( "AInsTest", { { "FLD1"+"+", 4, 0 } },"DBFNTX",.T. )
Apparently you had tested under both ( DBFNTX,DBFCDX ) RDD and seen that auto increment field is implemented both ( most probably all ) RDD.
In this case which result we will expect by changing 3rd byte of table structure, please let me know.
DBA doesn't support (for now) extended field types, because this concept is newer than DBA.
Please also look at here (if you are wondering) :
Moderator of Clipper Online forum says frequently :
"Please search through forum posts before writing on any subject."
Sorry for this long ( and mostly unnecessary ) speech. I like "chatting" with you ;)
Cumprimentos :D
martingz
Post by martingz »
For info only
ourXdbu - version 1.7.0.2
by: Miguel Angel Marchuet Frutos
support autoinc fields
Regrads
Hazael
Post by Hazael »
AFAIK you can change the counter with
DbFieldInfo( DBS_COUNTER, 1, 10 )
DbAppend()
#include "DBINFO.CH"
Use AInsTest
DbFieldInfo( DBS_COUNTER, 1, 10) // Reset count from number 10
DbFieldInfo( DBS_STEP, 1, 5) // Change counter from 5 to 5
FOR nRec := 1 TO 3
DBAPPEND()
Qatan wrote:AFAIK you can change the counter with
DbAppend()
Pablo César wrote:#include "DBINFO.CH"
Use AInsTest
FOR nRec := 1 TO 3
DBAPPEND()
For prevent anyone to misunderstand :
In Harbour, changing and /or resetting counter of auto-increment process, doesn't change un-replaceable property of those fields.
FYI only.
