chrisjx2002
Hello Pablo,
Thanks for improving the support of other languages to your software.
Now the N° on the screen is correct.
To improve the support of other languages, I try to modify the help screen. I modify Copie to Crée in French.lng and I got this error on the screenshot (see attached file).
- Screenshot help
- Message3.jpg (72.47 KiB) Viewed 4696 times
I see... check now.
<Attached file removed, see last message with now release>
If you make improvements in French.Lng, please share with us.I modify Copie to Crée in French.lng
There is problem with Polish characters in console mode still.
It's because console mode uses CP-852 and graphics mode uses CP-1250.
Polish ascii codes are different in both codepages.
Only one way to resolve thi problem, is to declare different language files.
- polish_console.zip
- (1.75 KiB) Downloaded 267 times
chrisjx2002
I have checked : now it is OK. That is super!!!
You will find attached an updated version of the translation in French : mostly typo errors.
chrisjx2002
With the file it is better...
- French.zip
- French translation
- (1.73 KiB) Downloaded 274 times
I am glad to know this and very thank you for yours compliments.chrisjx2002 wrote:I have checked : now it is OK. That is super!!!
Thank you for optimize French.Lng.chrisjx2002 wrote:You will find attached an updated version of the translation in French : mostly typo errors.
Let me know something else. At both modes (console and GUI), when SET CODEPAGE TO POLISH like it is happening in STRU (for example), then HMG will set CP-852 and CP-1250 according modes ? Or this is not happening, ie you need to force CP-852 or CP-1250 ?mol wrote:There is problem with Polish characters in console mode still.
Your attached polish file for console proposes, was renamed (please note) and now it is going to be used according console mode and when is also existing TLg extension file. These is going to work for other similar cases with both files.mol wrote:Only one way to resolve thi problem, is to declare different language files.
Please Marek check if it is working properly now in this new release.
The only problem I see is that in polish language, sometimes strings are so long, then you will need to enlarge windows sizes or abbreviate in you polish words.
Still no answer from Marek, but believing that it is ok now for Polish language.
Another release is ready correcting a bug when deleting fields and when also add new field. Another correction was made when there is a process file and shall delete prgs files at deleting fields and also for editing changes.
Please, I need help: I found a weird behaviour when double clicked or editing at field with caracter-type and lengh 1. In first editing spinner_1 is showing in blank not like as 1. But if cancel and returning editing then spinner_1 is showing 1. I tried to refresh spinner but it doesn´t work. Very strange. My tries was at line 1530, unsuccefully.
In the first time I went in to edit, it does not shows the value "1" in Spinner_1: When is canceled editing and returns for the second time, then yes it appears correctly: Very strange!
Languages files must be updating, now with 135 itens/lines. Please Esgici (for turkish), Marek (for polish, Lng and TLg) and chrisjx2002 (for french), you add the two new missing lines/items. Many thanks for your translations.
- esgici
Ola Pablo
I don't like this word; but this seems a bug
A second oddness is : if changed
to
problem gone away; but this modification is also wrong. You have validate spinner value to avoiding 0 though allowed by spinner.
Pablo César wrote:... a weird behaviour when double clicked or editing at field with caracter-type and lengh 1.
1063 RANGEMIN 1Code: Select all
1063 RANGEMIN 0Sorry, all .lng file you sent in .rar has 133 items/lines, no 135Languages files must be updating, now with 135 itens/lines.
Viva INTERNATIONAL HMG
Yes, your completly right: It´s a bug ! And I will post this message in HMG Bug Reports section !!esgici wrote:Pablo César wrote:... a weird behaviour when double clicked or editing at field with caracter-type and lengh 1.
Ohhh guy ! You are very clever ! Thank you very much ! I have already validate bigger than zero in Spinner_1.esgici wrote:A second oddness is : if changed
Problem gone away; but this modification is also wrong. You have validate spinner value to avoiding 0 though allowed by spinner.Code: Select all
1063 RANGEMIN 1 to 1063 RANGEMIN 0
No, no. All files are with 135 but Turkish.Lng, Polish.Lng, Polish.TLg and French.Lng are with last two lines with empties quotes and need the right translation. I could do it by Google translator, but not sure that translations would it be perfect than made by all of you. For that reason I kindly ask you to make for us, please.Esgici wrote:Sorry, all .lng file you sent in .rar has 133 items/lines, no 135Pablo César wrote:Languages files must be updating, now with 135 itens/lines.
I would like to get in italian... someone could do it for us ?
- esgici
Ola Pablo
Saudação.
Done.Languages files must be updating, now with 135 itens/lines.
Saudação.
