gfilatov wrote:
Pablo César wrote:One question: Is it possible in HMG to change color of highlighted row in grid component ?
Hello Pablo,
It is possible with changing of the following internal variables:
* _HMG_SYSDATA [ 348 ] -> Grid Selected Row ForeColor (by cell navigation)
* _HMG_SYSDATA [ 349 ] -> Grid Selected Row BackColor (by cell navigation)
Hope that helps. :idea:
Following this, I want to ask if it's possible to change colors of nonfocused grid?
Marek
Hello Pablo,
Thanks Grigory for your tip, I also thought that it could it work but I am still do not finding the right way...
Mr. Grigory, now with your example I noted your indication it is for fixed color in all rows. But I needing to change color according a existing file at each row. So its could change color according each row in two diferent situations. Please see in my code source at line 1979.
Source code with my attempts for your appreciation and I wish to advise Marek to test in Polish at console now with this last version, just to see if polish codepage has been set and working properly.
Remark: Text in blue color was inserted after the first posting (message re edited)
<Attached file removed, see last message with now release>
chrisjx2002
Post by chrisjx2002 »
Hello,
Very interesting program. I'll have translated it into French.
Using it in the console mode I notice a problem : see attached file. It happens when you use first F9 and after F1. In the same way french accents (like é,è,à,...) are not displayed in the console mode.
Screenshot
Screenshot
French.zip
French translation
(1.74 KiB) Downloaded 239 times
chrisjx2002 wrote:Very interesting program. I'll have translated it into French.
Thank you. Your contribution to French language, very much appreciated, many thanks !
Have you tested your code program in console mode and compiled it by HMG before ? I believe something with codepage that is not configurable in HMG with french language. See source code line 39.
Even been at English here, do not displays these "y" caracteres. Too weird...
chrisjx2002
Very weird in fact.
I use the French language and the console mode.
The first time I use F1 it works : first screenshot. Everythink is OK even the accents
After I use F9 : I have no more accent : second screenshot
After I use F1 and I have no more accent and the yyyyy : third screenshot
Any idea???? :cry:
Second use of F1 : no accent and yyyy
Use of F9 : no accent
First use of F1
First use of F1
Hi Cris,
In the fact, here it doesn´t matter when we press F1 before F9, this doesn´t change exibitions of accents, as you could see first screen and second screen (in yellow).
Please, let me ask you something important: at this attached image, in both red circles made, do you see french acents when you are running STRU in your computer or visualization it is like my image attached ? (please confirm)
I believe that you are visualizing in correct way in french (not these strange caracters, like in image) then I suppose that Hb_AnsiToOem() could it be interfering when is french language because HMG/Minigui seems not applying HB_CDPSELECT() by SET LANGUAGE when is translated internally. Then, for french, probably doesn´t needs to use Hb_AnsiToOem(). But I need your confirmation if you are seeing correctly (in both circles) in your screen when are running STRU in console mode. Please confirm that.
If you confirm that, then I will make a way for exception use in french and any other languages which is not using codepage function.
chrisjx2002 wrote:The first time I use F1 it works : first screenshot. Everythink is OK even the accents
I have another question (please let me know): You obtained these results, was when you ran STRU which version please ? (you can see STRU version when you mouse click in "A propos" in GUI mode).
chrisjx2002
Hi Pablo,
The version is 3.8
I have the same problems with words flèches and N° : see attached file
I confirm that the first time I use F1 it works with accents, I use F1 a second time, a third time,.. it works with accents but if I use F9 and F1 there are these strange y which are appearing on the screen.
Screenshot
Screenshot
chrisjx2002 wrote:The version is 3.8
Ok, in this case I am releasing another version 3.8a and we need to test it one by one untill we let it ok. But I need your test results in your french enviroment and confirming which version was tested, because here I have no french Windows to be tested, ok ?
Now is different behaviour as you have related before. Anyway, now in this version 3.8a it is working with all french accents/caracters here. But remember, I am in portuguese enviroment, because my Windows is brazilian one, so I need you make your test there and tell us how it was.
chrisjx2002
I Pablo,
I have tested this new version. The french accents work now correctly! No more problem on the screen and when using F1 key. Thanks for this modification.
But this modification has changed the window mode : look at N° in the two versions.
Screenshot 3.8a
Screenshot 3.8a
Screenshot 3.8
Screenshot 3.8
chrisjx2002 wrote:french accents work now correctly
Very good ! I glad to know this.
I have seen that LISTAR() function was being called by console mode and GUI and not treated before being utilized. Now I think is working properly.
I shall thank you very much, for you give me your feed back which helped me to correct some treatment for language details.
Now see a new release 3.8b in attached compressed file.
