HMG 3.0.43
HMG 3.0.43
Hi all,
I am so happy to upload the new test version HMG 3.0.43.
It can be downloaded from site (37.21 MB)
Alternatively you can download from sourceforge.net too.
- HMG 3.0.43 (Test) 2012/08/30 Changelog:
   - Updated to Harbour 3.2 Nightly Build (18042 2012-08-29)
   - Fixed OnPaint (Thanks to Claudio Soto)
     (HMG can now set a background image in a window with the ON_PAINT event.)
   - New Sample Wallpaper (Thanks to Claudio Soto)
Re: HMG 3.0.43
Thanks a lot Diamond Rathinagiri and Dr. Claudio Soto :)
Best regards
Re: HMG 3.0.43
Gracias Rathi:
como siempre tengo que descargar desde :
http://sourceforge.net/projects/hmg/fil ... irror=ufpr
algo debe suceder en mi maquina o mi ISP (Speedy - Telefonica.com.ar)
Re: HMG 3.0.43
Yes, for somebody download from HMGForum site is not complete because of unknown reasons. That's why I have uploaded in SourceForge.net also.
Re: HMG 3.0.43
Thanks Rathi.
Claudio.
IMATECH
HMG 3.0.43 - Problems HMG messages/translations
Post by IMATECH »
Hi Rathinagiri !
Problems on HMG messages/translations persist...
Because now in Harbour 3.2x When select Languages we can use any codepage...
Set_Language Return value as: "language.codepage" (and HMG need to code for correc language and CP Messages Show )
*** Return expected for HMG is only "Language" ( ES, PT, EN, Etc...)
Samples for Portuguese Language ( I spect a value of: "pt.PT850" ):
REQUEST HB_LANG_PT
REQUEST HB_CODEPAGE_PT850
HB_LANGSELECT( 'PT', "PT850" ) // Result is: pt.PT850
HB_LANGSELECT( 'pt-BR', "PT850" ) // Result is: pt.PT850
HB_LANGSELECT( hb_UserLang(), "PT850" ) // Result is: pt.PT850
Use of hb_UserLang() is the reccomended way :)
files to fix:
i_lang.ch
* Sample
Line(51): #translate SET LANGUAGE TO PORTUGUESE => _HMG_SYSDATA \[ 211 \] := '  ' ; REQUEST HB_LANG_PT ; HB_LANGSELECT( "PT" ) ; InitMessages()
need  change to
Line(51): #translate SET LANGUAGE TO PORTUGUESE => _HMG_SYSDATA \[ 211 \] := '  ' ; REQUEST HB_LANG_PT ; HB_LANGSELECT( hb_UserLang(), "PT850" ) ; InitMessages()
h_controlmisc.prg
* Sample
Line(5585)     case cLang == "PT"
need  change to
Line(5585)     case cLang == "pt.PT850"
h_init.prg
* Sample
Line(2278)     case cLang == "PT"
need  change to
Line(2278)     case cLang == "pt.PT850"
h_windows.prg
HFCL\Source\gridprint.prg
* Sample
Line(3114)     case cLang == "PT"
need  change to
Line(3114)     case cLang == "pt.PT850"
Best regards
M., Ronaldo
By: IMATECH
Imation Tecnologia
Re: HMG 3.0.43
Hi Rathi
rathinagiri wrote:Hi all,
Again, thanks to this new release :)
By the way, downloaded from HMG site with no problem.
Hi Claudio
Special thanks to you; first you made us free from two (old) problems: regarding your sample, now we can change back-ground image of a form and overlap any control over the image; this is important improvement; thanks again :)
By the way, "sami" is name of your cute cat ? (this is frequently used name in my country) :)
Re: HMG 3.0.43
esgici wrote:Hi Claudio
Thanks Esgici for your words.
Yes, Sami is the name of my cat.
Claudio.
IMATECH
Re: HMG 3.0.43
Post by IMATECH »
Hi Rathi :)
Any comment about my previous post !
and
Why exist this deprecated, unnecessary and problematic command on end of file: H_REPORT.PRG ( line 814 ) ?
#include "tprint.prg"
Please: remove it from source ( H_REPORT.PRG line 814 )
Best Regards
M., Ronaldo
By: IMATECH
Imation Tecnologia
Re: HMG 3.0.43
Best Regards
Olá Ronaldo :
Algunos entornos de desarollo tienen herramientas de refactoria, la cual si eliminas un methodo, variables o otro elemento del proyectos este tambien cambia.
puede quedar a pesar que uno lee y repasa el codigo y desaparece a simple vista.
Alguns ambientes de desenvolvimento têm ferramentas de refatoração, que se você remover um elemento, metodo variável ou outra desse projeto também muda.
pode ser, apesar de ler e revisar o código e desaparece a olho nu.
