Olà Pedro
Pablo César wrote:... tell me if is possible to put a visible image attached in the middle of message. It is possible ?
Yes, of course :
After image uploading process end, came a button : "Place inline". First, place cursor into message body, where you want put the image and than click that button. Placing image in the message /post body means not image itself, but a link indicate the image. After inline-placement you may change place of that link into message body wherever you like. That is all. :arrow:
I hope this help you.
esgici wrote:Olà Pedro
Ohh changed my named... hahaha :lol:
ohhh thanks amigo ! It´s helps a lot !
luisvasquezcl
Post by luisvasquezcl »
Buen aporte.
gracias Pablo,
saludos cordiales,
Luis Vasquez
Olá Pablo
Pablo César wrote:Ohh changed my named... hahaha :lol:
Sorry :(
Old age is a such thing :(
esgici wrote:Old age is a such thing
No problem my friend, these names are from good people.
Que bueno que te haya gustado Luis, espero que hagas buen provecho y estén a gusto a comentar algo a mejorar o de errado.
IMATECH
Post by IMATECH »
A tip to upgrade your project:
Embrace and Extend to HMG
http://forums.fivetechsupport.com/viewt ... =6&t=24180
M., Ronaldo
By: IMATECH
Imation Tecnologia
Wow very good job of Antonio Linares !
I think I will include Up and Down arrows just for moving fields sequences, this is missing in STRU and easy to be implemented, even that Insert filed button is working with add button.
Thanks Ronaldo to make known this app !
New version is released. It was implemented up & down buttons to change sequences of fields.
I´ve corrected some bugs when button "Salvar" was cancelled by button "Cancelar" which is not could be allowed when some fields are deleted or move sequence of fields.
I think will be not edit option be implemented. I believe this tool is just for structures demands, not for edit controls.
<Attached file removed, see last message with now release>
DBA certainly is excelent utility, for editing, indexing and modifying structure of dbfs. It´s very good to know another options already available. I never have been seen modifying options like: ^Up, ^Down, ^Ins,^Del (very good ones). The only problem found is this DBA and I also believe FiveDBU of Linares (do not sure this last, because is presenting some runtime errors) but it is not importing data. I means, if is necessary to change for diferent type field it is not importing data. I know it is a particular case each case. But the STRU, it does !.
And now I am implementing another button option which is gonna give us a chance to make "process" in runtime mode (with xBase code) of each importing data of each field. I means, when is creating or even changing a field, you can do your own routine to take the right data for each field. I shall do it from monday and I will leave available for all of you.
My intentions here, it is not to dispute with anyone, I just started on my learning HMG and I also believe this STRU could be usefull in diferent ways for who makes programs like us. It is not for final user or common users. At same time, it is going to encourage for my and also your learning of many tech utilized on it.
Amigo Esgici,
Pablo César wrote:It´s very good to know another options already available. I never have been seen modifying options like: ^Up, ^Down, ^Ins,^Del (very good ones).
First example was caused embracing and extending and the second caused to dispute !
Not for me !
I don't know why you are used this word : dispute ?
I just explaining. Because I making STRU in GUI. Let me tell some more: I have STRU in console mode (in Clipper) almost around for 18 years and since I have utilized much and help me much in my developement. And in 2011 I started in HMG which open my mind in the GUI World, thank to incredible jewel made by our good friend Roberto and I started with Stru to made in HMG. I´m very proud with it.
If you are so excited to reply my previous message, you also shall see what I wrote about tech demands and please when I said "dispute" it was because you did wrote anything explaining about yours images which I can understand that you are simply showing, just so it !
And my friend, please don't disregard, every new thing must be better since it have a chance of utilising precedents
Here in my first quoting, you will see I totally agree to know other options.
