Harbour MiniGUI 2.8.0
Re: Harbour MiniGUI 2.8.0
No problem Roberto.
fchirico
Post by fchirico »
Roberto Lopez wrote:Harbour MiniGUI 2.8.0 Changelog:
Sencillamente Buenísimo!!!
Gracias Roberto por estar cada vez mejorando el producto.
Saludos, Fernando Chirico.
sudip
Post by sudip »
Hello Roberto,
Thank you for "by cell" navigation in browse. I want it for long time :)
But I faced some problem. I installed 2.8.0 version. Then ran \samples\browse_1\browse1
I can't find the difference. May be as a new learner of HMG, I skipped something or I might have done some mistake. :(
Can anyone help me regarding this. :)
With best regards.
Sorry, I had found some bugs.
1. Navigation by cell is not enabled while in modal/child window. In the case of modal/child window grids, the cursor is shown in the main window even after the closing of modal/child window. (I think the cursor is shown in the main window instead of modal/child window!)
2. The current cursor/cell value is shown some pixels left than the actual value.
3. I had got my old project compiled in the new version and got run time error with grid. I could not reproduce the same by way of a sample. Let me give the error log. If possible I would come with a sample.
Error BASE/1068 Argument error: array access
Called from EVENTS(2337)
Called from LISTVIEW_SCROLL(0)
Called from _GETGRIDCELLDATA(4663)
4. When one column is having 0 width navigation cursor is not seen. (May be this is not a bug. But the user doesn't know about the column. ;))
I am attaching a sample with child window.
gridsample.zip
(768 Bytes) Downloaded 511 times
I would come with screenshots soon.
jparada
Post by jparada »
Translated by Google,
Hi Sudip, I think that Roberto commented:
- Navigation 'by cell' will be added to Browse control in next
versions.
Greetings
Javier
karweru
DBs Used: DBF,mysql,mariadb,postgresql,sqlite,odbc
Post by karweru »
Thank you, so so much Roberto for this feature! I can't believe my good fortune! It's barely three weeks since i posted a "cell by cell navigation" querry to this forum and now here it is!
Thank you Roberto!!
Kind regards,
Gilbert.
I'm waiting for 2.8.1 and IDE for that...
Many thanks Roberto for your excellent work...
Best regards, Marek
sudip
Post by sudip »
jparada wrote:Translated by Google,
versions.
Yes, you are correct!!! :) I missed it ;(
Regards.
sudip wrote:Hello Roberto,
With best regards.
I added 'by cell' navigation to Grid, not to Browse.
I'll do in future versions.
Roberto.
rathinagiri wrote:Sorry, I had found some bugs.
This is a very complicated code. I've expected that some problem arises.
Thanks for the report.
I'll try to fix ASAP.
Roberto.
