DBF Viewer 2012
MigSoft
DBs Used: DBF, MySQL, MariaDB, SQLite, PostgreSQL, FireBird
DBF Viewer 2012
Post by MigSoft »
DBView latest version. (Index Manager, Import a file) :D
dbview.zip
(1.26 MiB) Downloaded 2082 times
Re: DBF Viewer 2012
MigSoft :
Gracias por esfuerzo y dedicacion.
Re: DBF Viewer 2012
Many thanks.
Re: DBF Viewer 2012
Hi MigSoft,
The latest version is very nice. I think it is useful to many.
A small suggestion from me:
1. In the 'New DBF creation' window, when we double click in the grid to modify the details of a field, it is better to disable the grid also (like insert and delete button) since, somebody might click unintentionally to any other row and click modify. In that case, instead of the original row, the new row will get modified.
2. In the record view window, all the controls are disabled for the existing records. It can be made readonly for better viewing.
Re: DBF Viewer 2012
MigSoft wrote:DBView latest version. (Index Manager, Import a file) :D
Thanks a lot Miguel :D
MigSoft
Re: DBF Viewer 2012
Post by MigSoft »
Hi all,
Thank you for your comments and suggestions, I will adapt the program until you fill all our expectations. or at least try. ;)
I appreciate the suggestions that are details that often go unnoticed by me.
luisvasquezcl
Re: DBF Viewer 2012
Post by luisvasquezcl »
Hola Miguel,
Excelente aplicación.
Gracias por compartirla.
Saludos cordiales,
Luis Vasquez
Dilip Patel
Re: DBF Viewer 2012
Post by Dilip Patel »
Hi Miguel,
Thanks for the utility.
I use it often
Dilip
Re: DBF Viewer 2012
MigSoft wrote:Hi all,
Hola Migsoft:
el dia de hoy intente utilizar su aplicacion para modificar la estructura de una tabla, la misma tiene 142.000 registros y necesitaba modificar un campo de 5 caracteres, numerico. cambie tu tamaño a 6 caracteres numerico y quedo mas de 30 minutos y hasta que cerre la aplicacion mediante el Administrador de tareas.
utilize dbf viewer 2000 trial para hacer la misma tarea y tardo un poco mas de 5 minutos para la misma operacion.
Dbfviewer genera un ProgressBar para mostrar el Porcentaje de copia/modificacion de la tabla, puede ud. hacer lo mismo?, de esa forma poder saber si la aplicación esta estancada o esta progresando.
DBF Viewer.jpg (64.41 KiB) Viewed 7564 times
seria de muy bueno este agregado es su aplicacion.
MigSoft
Re: DBF Viewer 2012
Post by MigSoft »
Hi all again,
Thank you for your kind words.
I can add a progress bar, but the change in the structure requires further review to speed up the process in databases with large volumes of data.
I think there are several possible solutions, the current process takes a tour of the entire database to replace the data.
Has anyone solved this problem? :D
