Editbox and Tab key
Editbox and Tab key
Hi everyone,
Is it possible to use the tab key in an Editbox control ?
When my user presses the tab key it changes the focus to the next control on the form ...
I'd like the user to be able to set up columns of data within the edit box, which he can only do by using the spacebar to format the text.
Carlos Britos
Re: Editbox and Tab key
HIspelman wrote:Hi everyone,
Try with oEditBox TABSTOP = .F.
Carlos
No. Tabstop will pass on the editbox and you can't enter into the editbox in natural tab order.
For your problem, you can capture the tab key (using 'on key tab') and verify whether editbox is in focus. If it is, you can manually add the required spaces in the caret position. If the edit box is not is focus you can again simulate the tab key.
Hi Rathi,
Thanks very much for the reply - that should do the trick !
Steve
Steve
- esgici
Hi Steve
When you complete, could you share your code with us ?
Viva INTERNATIONAL HMG
Prototype:
Credits: Hathinagiri
DEFINE WINDOW F_SAMPLE...
ON KEY TAB ACTION F_RM_On_Key_Tab()
*F_RM_On_Key_Tab()
Function F_RM_On_Key_Tab()
local i := 0
* Form/Window Name
local cFrmName := ThisWindow.Name()
* active control: name
local cCtrlName := ThisWindow.FocusedControl()
* Check if sender is a "Editbox"
IF GetControlType( cCtrlName, cFrmName ) == "EDITBOX"
* ADD two spaces to replace key TAB
FOR i := 1 TO 2
_PushKey( VK_SPACE )
* Next Control
InsertTab()
Return( Nil )
M., Ronaldo
By: IMATECH
Imation Tecnologia
By: IMATECH
Imation Tecnologia
Nice prototype. However just inserttab() again to simulate the tab key. Please see below:
* Form/Window Name
? Do anything...
inserttab()
Return( Nil )
* Form/Window Name
? Do anything...
inserttab()
Return( Nil )
Thanks Hathinagiri !
Sample prototype updated above...
Best regards...
Best regards...
M., Ronaldo
By: IMATECH
Imation Tecnologia
By: IMATECH
Imation Tecnologia
