Dear All,
Is it possible thru HMG ? any samples ?
I know it is possible thru passing parameters to MysqlDump.exe, but can we do it thru HMG without Mysqldump.exe.
Warm regards,
Jayadev
Backup and Restore MySQL Databases from HMG
Re: Backup and Restore MySQL Databases from HMG
By backup if you mean to create .sql file, yes, we can do manually. I had done that. For detailed code please see MySQL to SQLite converter.
This is the link for MySQL2SQLite Converter.
http://hmgforum.com/viewtopic.php?f=15&t=857
The idea is, you can use 'SHOW CREATE TABLE' command to find out the exact create statement for all the tables.
Then use select * for all the tables, and create a text file with insert command for each row in the table.
Save the file with extension .sql.
Dear Rathinagiri,
Many thanks for your reply. Helpful as always.
What libraries have to be linked to compile this application ?
Warm regards,
Jayadev
Warm regards,
Jayadev
No extra library is required to be included. You can just compile it.
In this converter I have created a sql text file for the whole mysql database selected.
