I have .c files. I use that files with my application. How to compile .c files with hmg?
Thanks,
Tristan
Compile HMG
Re: Compile HMG
Do you call that 'c' functions inside HMG application?
You can compile using the MingW compiler provided along with HMG distribution.
Re: Compile HMG
Hello Tristan:
can look here for a better understanding on how to use function calls in c.
Hola Tristan :
puede mirar aqui para una mejor comprension sobre como utilizar llamadas a funciones en .c
Error in modifying the color of the main menu : http://hmgforum.com/viewtopic.php?f=24&t=2330
Hola Tristan :
