Dear all:
I try setproperty(Window's name,Control's name,Property's name,value) and failed.
Is that possible to do that ?
Best Regards
chen min
Is possible to change widths of GRID after definiation?
huangchenmin
Re: Is possible to change widths og GRID after definiation?
Hi Che:huangchenmin wrote:Dear all:
Best Regards
chen min
post an example to avoid errors of interpretation
Properties Available For OnDblClick Procedure:danielmaximiliano wrote:Hi Che:huangchenmin wrote:Dear all:
Best Regards
chen min
- This.CellRowIndex
- This.CellColIndex
- This.CellRow
- This.CellCol
- This.CellWidth
- This.CellHeight
- Note: These properties are not available when OnDblClick procedure
is fired by <Enter> key pressing.
file:///C:/hmg.3.0.40/doc/data/index.htm
Dear Che:
if you want to change widths of columns, it is possible only in this way:
you can release grid control and rebuild it with new definition.
"Widths" is available at control definition only
Marek
Marek
huangchenmin
Dear danielmaximiliano:danielmaximiliano wrote:danielmaximiliano wrote:Hi Che:huangchenmin wrote:Dear all:
Best Regards
chen min
As HMG reference mentions about, those properties is be got in certain conditions.
Thanks for replying to me.
Best Regards
chen min
huangchenmin
Dear mol:mol wrote:Dear Che:
Marek
That is really a good ideal.
Best Regards
chen min
Hi
If you just want to auto adjust the column width to fit the contents that is possible.
Just see here.
http://hmgforum.com/viewtopic.php?f=5&t=2010
Just see here.
THX for reminding this solution!
best regards, Marek
best regards, Marek
