check size and resize image
jairpinho
Post by jairpinho »
hello everyone!
I need to know the size of an image and then resize the image to a lower tamnho anyone know how to do this without using any external dll only with hmg
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Re: check size and resize image
Ola Jair:
Voce tem a ver neste endereço:
http://www.hmgforum.com/viewtopic.php? ... age#p19584
jairpinho
Post by jairpinho »
Thanks daniel missing only resize the image
Jair Pinho
jairpinho wrote:Thanks daniel missing only resize the image
rescale a imagem, utilizar FreeImage exemplos estão em hb31\contrib\hbfimage\test
hb31= Harbour Nightly
Manual Freeimage : http://sourceforge.net/projects/freeima ... f/download
jairpinho
Post by jairpinho »
HMG can not compile with an example of this native lib and HMG or have to add the project libs =
Jair Pinho
jairpinho wrote:HMG can not compile with an example of this native lib and HMG or have to add the project libs =
Ola Jair:
Neste exemplo do Sr. Grigory Filatov
http://hmgforum.com/download/file.php?id=510
uso IDE HMG.3.0.40 compila perfeito, usá-lo para alterar o seu projecto
jairpinho
Post by jairpinho »
Daniel did not want to use External .dll, there is a way to make HMG.
Also need to know the file size.
Jair Pinho
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Hi Jair ;) ,
You can get the image size using Grigory´s code,
viewtopic.php?f=5&t=2267&p=19584&hilit=image#p19584
but AFAIK you can´t resize it using ONLY HMG.
Alternatively you can Release & Define this image control again.
[]´s Salamandra
