hello everyone!
I need to know the size of an image and then resize the image to a lower tamnho anyone know how to do this without using any external dll only with hmg
check size and resize image
Re: check size and resize image
Thanks daniel missing only resize the image
rescale a imagem, utilizar FreeImage exemplos estão em hb31\contrib\hbfimage\testjairpinho wrote:Thanks daniel missing only resize the image
hb31= Harbour Nightly
Manual Freeimage : http://sourceforge.net/projects/freeima ... f/download
HMG can not compile with an example of this native lib and HMG or have to add the project libs =
danielmaximiliano wrote:rescale a imagem, utilizar FreeImage exemplos estão em hb31\contrib\hbfimage\testjairpinho wrote:Thanks daniel missing only resize the image
Ola Jair:jairpinho wrote:HMG can not compile with an example of this native lib and HMG or have to add the project libs =
Neste exemplo do Sr. Grigory Filatov
http://hmgforum.com/download/file.php?id=510
uso IDE HMG.3.0.40 compila perfeito, usá-lo para alterar o seu projecto
Daniel did not want to use External .dll, there is a way to make HMG.
Also need to know the file size.
- salamandra
- DBs Used: DBF, MySQL, SQL
Hi Jair
You can get the image size using Grigory´s code,
viewtopic.php?f=5&t=2267&p=19584&hilit=image#p19584
but AFAIK you can´t resize it using ONLY HMG.
Alternatively you can Release & Define this image control again.
[]´s Salamandra
[]´s Salamandra
