some issues about storing variable lenght fields...
mrduck
Post by mrduck »
In a text-mode form I have 4 lines of 78 chars. The lines are indipendent (created by 4 @ GET commands) but they contain one long text. It happens that when the user need to add a word in the first line and the text doesn't fit, it is truncated and must be repeated at the start of the next line...
Porting this form to GUI I wondering which is the best way, since I also have to limit the char number (and i think I can do it) and the space on the printed form (and this is more difficult....)
I also created 4 fields in the database, char 78, TEXT1, TEXT2, TEXT3, TEXT4 = 312 bytes. This is lower than the standard 512 bytes of DBT file... about 70000 records * (512-312) = 14 MB saved...
Since a lot of these lines are empty I was thinking about normalizing the DB, creating a new dbf with fields:
DOCURECORD N 7
LINENUMB N 1
TEXT C 78
Index on docurecord, linenumb
Saving and retrieving the lines is done on the DBF, and only for not empty fields...
are there other possible solutions I can't foresse now ?
Re: some issues about storing variable lenght fields...
I think this is rightly optimized.
Hi Francesco
mrduck wrote:This is lower than the standard 512 bytes of DBT file... about 70000 records * (512-312) = 14 MB saved...
...are there other possible solution?
Did you tried DBFFPT RDD ?
Does your method ( relating a second table ) is about first normalization ?
mrduck
Post by mrduck »
esgici wrote:Hi Francesco
No, I didn't. I'm still using plain DBFNTX...
yes and no: "yes" since I'm applying that kind of normalizazion, "no" because the fields are not used in searches.. .actually I have a relation 1:m where m < 5 and I seem to remember that normalization can't be limited in this way... but ok, faded memory...
Thanks to clarification
