Change Size Menuitem im hmg.4
Rossine
Post by Rossine »
Hello,
Is possible change the size of "menuitem" ? See this image ?
Best Regards,
Rossine.
l3whmg
Re: Change Size Menuitem im hmg.4
Post by l3whmg »
Hi Rossine.
With my compiled library, MainMenu, MenuPop and MenuItem have the same size.... this is the code
      WITH OBJECT MainMenu():New( "MainMenu" )
         :FontSize   := 16
         WITH OBJECT MenuPopup():New( 'File',, 'File' )
            WITH OBJECT MenuItem():New( 'ItemOpen' ,, 'Open'  , { || MsgInfo( 'Open'  ) } ); END WITH
            WITH OBJECT MenuItem():New( 'ItemClose',, 'Close' , { || MsgInfo( 'Close' ) } ); END WITH
            WITH OBJECT MenuPopup():New( 'PopUp',, 'PopUp' )
               WITH OBJECT MenuItem():New( 'Item1' ,, 'Open'  , { || MsgInfo( 'Open'  ) } ); END WITH
               WITH OBJECT MenuItem():New( 'Item2',, 'Close' , { || MsgInfo( 'Close' ) } ); END WITH
            END WITH
         END WITH
      END WITH
And these are two picture, one without "FontSize" (default system size)
default
default
16 px
16 px
If I understand your request or problem.
It's not possible (I have tried some times ago...) to have different size between MainMenu, MenuPopUp or MenuItem... In other words
         :FontSize   := 16
          :FontSize   := 10
              :FontSize   := 8
           END WITH
         END WITH
      END WITH
Cheers
Luigi from Italy
www.L3W.it
Wow! Thanks Luigi.
Wow ! It´s wonderful !
Taking this chance to ask:
In HMG 3 is this possible to do ?
Luigi :
Gracias por compartir tus conocimientos.
l3whmg
Post by l3whmg »
Hi DanielMaximiliano
"De nada", but I stop here my knowledge about hispanic language ;)
Cheers
Luigi from Italy
www.L3W.it
Rossine
Post by Rossine »
Hello Luigi,
l3whmg wrote:Hi Rossine.
         :FontSize   := 16
            END WITH
         END WITH
      END WITH
         :FontSize   := 16
          :FontSize   := 10
              :FontSize   := 8
           END WITH
         END WITH
      END WITH
Cheers
This would be a request :o
Wonderful to see it all working. Thank you for sharing your knowledge with us all and also all over your precious time dedicated to this great project.
Thanks Master Luigi ;)
Rossine.
l3whmg
Post by l3whmg »
Hi friends.
Many thanks for your words :oops:
A little brief about Menu and related font problem/request.
         END WITH
      END WITH
In the previous code, the MainMenu object inherit font (size, name, etc.) from QT default.
         :FontSize := 16
         END WITH
      END WITH
In the previous code, we have changed the fontsize property for the MainMenu object.
MenuItem inherit font (size, name, etc.) from its parent. Who is its parent? MainMenu :o
So, with first example MenuItem inherit Qt default font, in the second one inherit a "changed" font.
There are 3 lines within MenuPopUp.prg (97-100): if I remove these lines, menuitem doesn't inherit font property from its parent, but what happens? If I set a font for the MainMenu, this font it is not propagate to the MenuItem (in other words, it has default font) and we must use :FontSize to align its fontsize.
Remember that all font* methods are used by many objects.
From one side we can use only one time :FontSize and all menu objects have the same size; on the other side, we can have different size, but we must use everywhere :FontSize to have the same size.
I think this can be an evolution and everyone can think a solution.
Cheers
Luigi from Italy
www.L3W.it
Rossine
Post by Rossine »
Hello Luigi,
Many thank´s for this explanation ;)
Below an example to let the possibility of using each submenu with a different size.
#include "hbqtgui.ch"
static Form_1
   HbQt_ErrorSys()
   WITH OBJECT Form_1 := MAINWINDOW():New( "Form_1" )
      :Row           := 10
      :Col           := 10
      :Width         := 1024
      :Height        := 630
      :Title         := "HMG4 demo change font menu"
      :Icon          := ":HMG_ICO"
     DEFINE TOOLBAR oToolBar1 BUTTONSIZE 120, 80 FONT "ms sans serif" SIZE 12 MOVEABLE .F.
         TOOLBUTTON oButton1 ;
            Caption 'Font Menu Main' ;
            picture 'open.png' ;
            ACTION  { || Form_1:MainMenu:FontSize ++ }
            tooltip 'Change font of <Menu Main>'
         TOOLBUTTON oButton2 ;
            Caption 'Font Menu File' ;
            ACTION  { || Form_1:MainMenu:ItemFile:FontSize ++ }
            tooltip 'Change font of Option <File>'
         TOOLBUTTON oButton3 ;
            Caption 'Font Menu Help' ;
            ACTION  { || Form_1:MainMenu:ItemHelp:FontSize ++ }
            tooltip 'Change font of Option <Help>'
      END TOOLBAR
         :FontSize  := 16
         WITH OBJECT MenuPopup():New( 'ItemFile',, 'File' )
           WITH OBJECT MenuItem():New( ,, 'Open'  , { || MsgInfo( 'Open'  ) } )
           END WITH
           WITH OBJECT MenuItem():New( ,, 'Save'  , { || MsgInfo( 'Save'  ) } )
           END WITH
         END WITH
         WITH OBJECT MenuPopup():New( 'ItemHelp',, 'Help' )
           WITH OBJECT MenuItem():New( ,, 'About'  , { || MsgInfo( 'About'  ) } )
           END WITH
         END WITH
      END WITH
END WITH
return NIL
Thanks for your help,
Rossine.
l3whmg
Post by l3whmg »
Hi Rossine.
WoW :shock: very 8-)
Many thanks
Cheers
Luigi from Italy
www.L3W.it
