HOWTO extend a class using inheritance
Ricci
Post by Ricci »
As I described in this example ( viewtopic.php?f=32&t=2121 ) HMG4 is based on full OOP and it is not difficult to use this for your own extensions without touching the source code.
A simple example: Let us extend the bitmap class so it will react on a double click.
Usually we define a simple click to call a function in BITMAP:
#include "hbqtgui.ch"
FUNCTION Main()
	LOCAL oForm1
	HbQt_ErrorSys()
   DEFINE MAINWINDOW oForm1
				ROW  10
				COL  10
				WIDTH	300
				HEIGHT 200
				FONT "ARIAL"; SIZE 09
		DEFINE IMAGE oBitmap
					ROW 10; COL 10
					WIDTH 200; HEIGHT  200
					PICTURE "mypicture.png"
					ONCLICK { || msginfo( "Click" ) }
		END IMAGE
	END Window
	ACTIVATE WINDOW oForm1
RETURN Nil
Using ONDBLCLICK instead of ONCLICK will not work because the BITMAP class didn´t know about the double click.
Let´s extend the BITMAP class:
1. We define the new CLASS MYIMAGE based on IMAGE:
CLASS MYIMAGE FROM BITMAP
ENDCLASS
2. Now we add the method for the doubleclick. To make it easy for us we look through the source codes and find classes that still react on double click. We take the code from them:
   METHOD OnDblClick                      SETGET
ENDCLASS
METHOD OnDblClick( bValue ) CLASS MYIMAGE
   IF PCOUNT() == 0
      RETURN ::bOnDblClick
   ELSEIF PCOUNT() == 1
      IF hb_IsBlock( bValue ) == .T.
         ::bOnDblClick := bValue
         ::oQtObject:connect( QEvent_MouseButtonDblClick, bValue )
      ELSEIF hb_IsNil( bValue ) == .T.
         ::bOnDblClick := NIL
         ::oQtObject:disconnect( QEvent_MouseButtonDblClick )
RETURN Self
Because we use CLASS commands we need to include "hbclass.ch" !
3. We change our program code to define a MYIMAGE instead of IMAGE:
		DEFINE MYIMAGE oBitmap
					ROW 10; COL 10
					ONDBLCLICK { || msginfo( "Click" ) }
		END MYIMAGE
4. We now get a compiler error, because the preprocessor didn´t find "DEFINE MYIMAGE" in HMG.CH.
Since we are using oneliners in our define, we only have to change the translate command for the first line. We search for the translate commands of IMAGE in HMG.CH, copy the lines, put them into the head of our program and change IMAGE TO MYIMAGE (we don´t need to understand the rest of #xcommand ;) ):
#xcommand DEFINE MYIMAGE <tagreference>[ <dummy1: OF, PARENT> <oParent> ] [ TOVAR <varname> ] => ;
With Object [<varname> :=] MYIMAGE():New( <"tagreference">[, <oParent> ] )
#xcommand END MYIMAGE => End With
That´s it. Here is the whole program, the image will now react on double click instead of a click.
And the best thing is that we didn´t change anything of the source codes so any update will not influence our work.
#include "hbclass.ch"
FUNCTION Main()
	LOCAL oForm1
	HbQt_ErrorSys()
				ROW  10
				COL  10
				WIDTH	300
				HEIGHT 200
					ROW 10; COL 10
		END IMAGE
	END Window
RETURN Nil
   MYIMAGE class
// Methods
ENDCLASS
   OnDblClick
   IF PCOUNT() == 0
RETURN Self
Ricci
mrduck
Re: HOWTO extend a class using inheritance
Post by mrduck »
Great post Ricci,
it's exactly one of the reasons HMG4 is so powerfull !
Ricci wrote: 4. We now get a compiler error, because the preprocessor didn´t find "DEFINE MYIMAGE" in HMG.CH.
So if you use pure oop syntax, you don't ever need to create the xcommands !
Exactly, pure inheritance at work !
Please keep up with these posts... I'd like one on the pop-up graph... :-)
Hola Ricci:
English term or phrase: clear as day
Spanish translation : más claro que el agua (por todo el mundo)
Spanish Argentina : más claro hechale agua.
Gracias por compartir / thanks for sharing
Nice explanation Ricci. Thanks a lot.
Ricci
Post by Ricci »
mrduck wrote: So if you use pure oop syntax, you don't ever need to create the xcommands !
I know, but HMG code is more readable. :D
mrduck
Post by mrduck »
I was saying this to all the readers, not you... I know that you and Luigi know... ;-)
