HMG 3.0.40
Tristan
Re: HMG 3.0.40
Post by Tristan »
I found an error when compile demo.prg in folder C:\hmg\SAMPLES\REPORT.ADVANCED.1
Harbour 3.1.0dev (Rev. 17111)
Cannot open hbvpdf.prg, assumed external
Cannot open hbvpsup.prg, assumed external
C:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x1a8): undefined reference to `HB_FUN_PDFINIT'
C:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x1c8): undefined reference to `HB_FUN_PDFOPEN'
C:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x2f8): undefined reference to `HB_FUN_PDFNEWPAGE'
C:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x3a8): undefined reference to `HB_FUN_PDFCLOSE'
C:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x478): undefined reference to `HB_FUN_PDFSETFONT'
C:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x488): undefined reference to `HB_FUN_PDFATSAY'
C:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x498): undefined reference to `HB_FUN_PDFTEXTWIDTH'
C:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x4c8): undefined reference to `HB_FUN_PDFIMAGE'
C:/hmg/lib/libhmg.a(h_rptgen.o):h_rptgen.c:(.data+0x4e8): undefined reference to `HB_FUN_PDFBOX'
gcc.exe C:/DOCUME~1/Julian/LOCALS~1/Temp/hbmk_d2bs0i.dir/demo.o C:/DOCUME~1/Julian/LOCALS~1/Temp/hbmk_d2bs0i.dir/hbmk_vexc5l.o C:/hmg/SAMPLES/REPORT.ADVANCED.1/_temp.o -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lhfcl -lini -lreport -lmsvfw32 -lvfw32 -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbmysql -lmysql -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbfimage -lhbpgsql -lhbnetio -lhbextern -lhbdebug -lhbvm -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -odemo.exe -LC:/hmg/harbour/lib/win/mingw -LC:/hmg/harbour/bin -LC:/hmg/lib
Thanks & Regards,
Tristan
HMG 3.0.40
Tristan wrote:I found an error when compile demo.prg in folder C:\hmg\SAMPLES\REPORT.ADVANCED.1
Please be kind to read this: http://hmgforum.com/viewtopic.php?f=2&t=2075&start=10
jairpinho
Re: HMG 3.0.40
Post by jairpinho »
Hello everyone I'm having problems since the 3.0.38, 3.039, 3.040 hmg with a return of function after enabling a code follows the form:
Function Form_Progres()
IF !IsWindowDefined(Form_Progresso)
Load Window Form_Progresso
lAtivo:= .T.
Form_Progresso.Center
Form_Progresso.Activate
Else
Form_Progresso.Restore
lAtivo:= .T.
EndIF
Return(lAtivo) --->>not returning the value
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
HMG 3.0.40
I have noted that diferent FONTCOLOR (than color default) when assigned is not working in
Frames in HMG version 3.0.40. Backcolor is OK but fontcolor: NOT.
Re: HMG 3.0.40
rathinagiri wrote:Hi all,
I am happy to upload the new version HMG 3.0.40.
It can be downloaded from site (24.67 MB)
- HMG 3.0.40 (Test) 2011/11/13 Changelog:
- Updated to Harbour 3.1 Nightly Build (17111 2011-11-10)
- New : SET CELLNAVIGATIONMODE EXCEL | STANDARD (by Roberto Lopez) To have an option to navigate cells in a grid downwards while in-place editing. Please see samples\grid.39 sample folder.
Enjoy!
I found
phrase very useful, but after editing last row grid should leave edit mode, I think.
And, everything works fine, when you enter edit mode by pressing ENTER key. If you double click your mouse, pointer doesn't move down...
Regards, Marek
Re: HMG 3.0.40 ( Re-building lib )
Hi All
I can't re-build HMG lib via buildlib.bat :(
C:\hmg>buildlib
Compiling 'source\ErrorSys.prg'...
source\ErrorSys.prg(48) Error F0029 Can't open #include file 'hmg.ch'
hbmk2: Error: Running Harbour compiler (embedded). 1
(C:\hmg\harbour\bin\harbour.exe) -n2 source\ErrorSys.prg source\h_browse.prg sou
rce\h_button.prg source\h_checkbox.prg source\h_combo.prg source\h_controlmisc.prg
\ -iC:\hmg\harbour\include
In fact I need no re-build HMG, but my own lib; attempting re-build HMG was for learning new way to build a lib.
Any help will be appreciated.
Re: HMG 3.0.40
Hi Esgici:
recien compile hmg.hbp mediante el batch que modifique para construir mis programas y no encontre ningun error.
puede ud. modificar la ruta donde se encuentre su instalacion hmg.
Translate google:
recently compiled by the batch hmg.hbp to modify to build my programs and found no error.
can you. change the path where the installation is hmg.
@echo off
cls
Title New HMG -- Build.bat --
@echo
if "%1"=="" goto Input
if not EXIST %1 Goto Noexist
:Build
@Echo Compiling %*
call %HMGPATH%build.bat %*
@echo.
goto Finish
:Noexist
echo  El archivo %1  no existe,  revise el nombre
@echo
Goto Finish
:Input
SET HMGPATH=e:\hmg.3.0.40\
Color 04
@echo ********************************************************************************
@echo   Este Batch pasa informacion a hbmk2 para un compilacion facil y limpia
@echo   se distribuye como esta y no garantiza que este libre de errores
@echo   si encuentra una puede escribirme a danielmaximiliano@yahoo.com.ar
@echo   Basado un Build.bat distribuido en el Proyecto HMG de Roberto Lopez
@echo.
@echo Entre el nombre del proyecto a compilar, asume la extension .HBP si este existe
@echo en la carpeta del proyecto, sino compila el .PRG
@echo.
@echo "<Enter>" sale del Batch
@echo.
color 07
Set /p Filename=Nombre de la Aplicacion:=
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
if {%Filename%}=={} goto :Finish
if EXIST %Filename%.hbp (Set Extension=.hbp&&Goto Enterparameters)
if EXIST %Filename%.prg (Set Extension=.prg&&Goto Enterparameters)
goto Cleanvar
:EnterParameters
@echo  Parametros Extras para compilar %Filename%%extension%
@echo.
@echo                           /n	No EJECUTAR desdepues de compilar
@echo                           /d	Habilita DEBUG
@echo                           /c	Modo CONSOLA DOS
@echo.
@echo Nota: " Con un <Enter> ningun parametro es pasado "
@echo.
Set /p Parameter=Parametros :=
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
@echo.
If "%Parameter%"== "" goto Continue
If /I "%Parameter%"=="/n" Goto Withparameters
If /I "%Parameter%"=="/d" Goto Withparameters
If /I "%Parameter%"=="/c" Goto Withparameters
cls
Goto EnterParameters
:Withparameters
@echo compilando con parametros
if EXIST %Filename%.hbp Goto HBPParameters
if EXIST %Filename%.prg Goto PRGParameters
goto Cleanvar
:HBPParameters
@Echo Compilando %Filename%.hbp %Parameter%
call %HMGPATH%build.bat  %filename%.hbp %Parameter%
goto Cleanvar
:PRGParameters
Echo Compilando %Filename%.PRG %Parameter%
call %HMGPATH%build.bat %filename%.prg %Parameter%
goto Cleanvar
:Continue
@echo no parameters compilation
:HBP
@Echo Compile %Filename%.hbp
goto Cleanvar
:PRG
@Echo Compile %Filename%.prg
goto Cleanvar
:CleanVar
@echo Cleaning variable´s
(SET HMGPATH=)
(SET Filename=)
(SET Parameter=)
Goto Input
:Finish
set "bar="
set "percent=0"
set "count=0"
for /l %%i in (1,1,20) do set "bar=!bar!±"
:loop
set /p "= %bar:~0,20% %percent%%%"<nul
ping -n 1 -w 1 localhost>nul
for /l %%i in (1,1,26) do set /p "="<nul
set "bar=Û%bar%"
set /a "count+=1"
set /a "percent+=5"
if %count% leq 20 goto:loop
echo.
echo.
(SET HMGPATH=)
(SET Filename=)
(SET Parameter=)
(set bar=)
(set percent=)
(set count=)
Re: HMG 3.0.40
Hola Daniel
Thanks to your interest :)
But my problem is with buildlib.bat, no build.bat :(
Re: HMG 3.0.40
Hi Esgici,
It is working fine for me. Can you please upload/enter your buildlib.bat?
Re: HMG 3.0.40
Hi Rathi
rathinagiri wrote:It is working fine for me.
This is very good news :)
My buildlib.bat is :
@echo off
REM
REM $Id: buildlib.bat 438 2010-10-19 02:37:12Z roblez $
REM
SET HMGPATH=%~dp0
hbmk2 hmg.hbp
