[UPDATED] HMG.4 IDE Test
A new release of HMG IDE.4 test version.
It fixes some problems.
You need to download updated HMG.4 sources (at least 2011.11.20) and rebuild the library.
Besides that, you must to change the 'buildaapp.bat' file with the following:
@echo off
REM
REM $Id$
REM
IF DEFINED HMGPATH GOTO HmgPathDefined
SET HMGPATH=c:\hmg.4
SET PATH=%HMGPATH%\harbour\bin;%HMGPATH%\harbour\comp\mingw\bin;%PATH%
SET HB_WITH_QT=%HMGPATH%\harbour\include
:HmgPathDefined
if "%1"=="/3" goto compatible
HBMK2 %1 %2 %3 %4 %5 %6 %7 %8 -w3 -es2
goto end
:compatible
shift
HBMK2 %1 %2 %3 %4 %5 %6 %7 %8 -DHMG3 -i. -run
pause
:end
Do not forget to change hmg.ini file content (if required) to match your HMG.4 location.
Thanks to Francesco for tuning HMG.4 to make this possible.
Enjoy!
ide.4b.zip
(960.14 KiB) Downloaded 608 times
Re: [UPDATED] HMG.4 IDE Test
Repost of some important things about this release:
Some important things:
- The way in that HMG 3 IDE form designer generates code IS NOT the recommended way to code semi-oop in HMG.4. It reflects the status of HMG at first IDE release in 2004 (MiniGUI library at that time). That style will be supported for backwards compatibility only.
I'm talking about (specifically) of DEFINE WINDOW, DEFINE TAB, DEFINE TREE and other commands that requires that all properties (clauses) be specified in the same line.
This way of coding is considered DEPRECATED (backwards compatible only) in HMG.4.
The preferred semi-oop way is shown in this sample (one property by line):
   DEFINE MAINWINDOW MainForm
       ROW         10
       COL         10
       WIDTH       600
       HEIGHT      600
       TITLE       "CHILD window demo"
       ONINIT      MainFrmOnInit()
- This IDE.4 is only temporary, until the new IDE be finished.
Thank you very much Roberto.
rathinagiri wrote:Thank you very much Roberto.
As always, thanks to you for your invaluable help.
If you consider adequate, please, include the IDE in the next HMG.4 binary build.
TIA.
Definitely Roberto.
Actually I have to cleanup something.
rathinagiri wrote:Definitely Roberto.
Thanks!
And... if that was not already done, please, upload to the SVN the modified 'buildapp.bat' shown in the first message of this thread. Without it, the IDE will not be able to create applications.
It does not alter the previous operation. It only adds the optional '/3' parameter used by IDE to build apps.
TIA.
I've made some modifications to buildapp.bat to have a better way to look at errors.
It captures screen messages and opens the NOTEPAD after build (if errors) to comfortably take a look at the results.
This is the new file:
@echo off
REM
REM $Id$
REM
:HmgPathDefined
goto end
:compatible
shift
HBMK2 %1 %2 %3 %4 %5 %6 %7 %8 -q -DHMG3 -i. -run >build.log 2>&1
IF ERRORLEVEL 1 NOTEPAD build.log
:end
Gracias por tu trabajo Roberto.
era necesario saber como termina la compilacion; ya que el IDE no llegaba a mostrar los errores si hubo uno.
jairpinho
Post by jairpinho »
error while compiling
does not accept *.FMG attached zip attached
Main.zip
(1.73 KiB) Downloaded 486 times
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
