about contrib xhb in hmg.3.0.36
jparada
Post by jparada »
With version hmg.3.0.36, I'm trying to use the TXMLDocument of contrib xhb, and does not work.
The question is whether this contrib was included in the version of hmg, and if that is not included, if possible inclusion?.
I appreciate any help.
Thank you very much.
Best Regards,
Javier
l3whmg
Re: about contrib xhb in hmg.3.0.36
Post by l3whmg »
Hi Javier,
xhb it's a Harbour contrib library, not a Hmg contrib.
Rathinagiri download Harbour package and include it in Hmg distribution for our convenience ;)
I think if xhb don't work you/we must send a message to Harbour mailing list :idea:
Cheers
Luigi from Italy
www.L3W.it
Hi Javier,
Can you run the test programs in contrib directory?
jparada
Post by jparada »
Hi Rathinagiri,
Thanks for answering,
I'm sorry, I have problems with my PC, and I can not perform any test at this time.
Best Regards,
Javier
Today I needed it, TXMLDocument of contrib xhb. And I have included xHB lib and it worked ok.
See my code example:
// Compile with xHB
Function Main(cArquivo)
SetMode(25,80)
If cArquivo=NIL
   RetornaConteudoXml("Arqxml.xml")
Else
   RetornaConteudoXml(cArquivo)
Endif
Function RetornaConteudoXml(cFileName)
LOCAL hFile, cXml
LOCAL xmlDoc, xmlIter , xmlNode, cNode, cAttrib, cValue, oCampo, oConteudo
if !file(cFileName)
   Alert("Arquivo "+cFileName+" nao encontrado !")
   Return nil
end
cNode := NIL
cAttrib := NIL
cValue := NIL
hFile := FOpen( cFileName )
xmlDoc := TXmlDocument():New( hFile )
IF xmlDoc:nStatus != 1
   Alert("erro ao ler XML ")
xmlIter := TXmlIterator():New( xmlDoc:oRoot )
xmlNode := xmlIter:Find()
DO WHILE xmlNode != NIL
   if !empty(xmlNode:cData)
      if subs(xmlNode:cData,1,1) # "<"
         oCampo :=xmlNode:cName
         oConteudo:=xmlNode:cData
	  oConteudo:=""
   alert( Padr("Campo...: "+oCampo,70)+";"+;
          Padr("Conteudo: "+oConteudo,70))
   xmlNode := xmlIter:Next()                        // joga pro proximo campo
ENDDO
Return nil
And this is XML file example (Arqxml.xml):
<webservicecep>
<resultado>1</resultado>
<resultado_txt>sucesso - cep completo</resultado_txt>
<uf>RS</uf>
<cidade>Porto Alegre</cidade>
<bairro>Passo D'Areia</bairro>
<tipo_logradouro>Avenida</tipo_logradouro>
<logradouro>Assis Brasil</logradouro>
</webservicecep>
I hope to be usefull for someone alse.
