Position of the toolbar
Rossine
Post by Rossine »
Hello,
How to know the position of the toolbar ?
Example: msgstop( MainForm:Toolbar1:position ) 0=Left / 1=Right / 2=Top / 3=Bottom
Rossine.
l3whmg
Re: Position of the toolbar
Post by l3whmg »
Hi Rossine,
at this moment, there isn't this ability. With HMG3, only at bottom or top you can "put"
But, when I rewrited source code I have introduced TBarPlace() method to positioning ToolBar.
....:ToolBar:TBarPlace( nPosition )
Where nPoistion can be: Qt_LeftToolBarArea, Qt_RightToolBarArea, Qt_TopToolBarArea, Qt_BottomToolBarArea
Do you think it's important to know where is? If yes, ASAP, I open the ability to know position.
Remember: you also has this properties:
....:ToolBar:AllowedAreas[:= nValue] to know or to set where can be placed (see hbqtgui.ch related with Qt_AllToolBarAreas)
....:ToolBar:MoveAble[:= lValue] to know or to set if moveable
Cheers
Luigi from Italy
www.L3W.it
Rossine
Post by Rossine »
Hi Luigi,
Yes, it would be interesting :D
I'm working on a program where I have an image that is resized with the window and when I change the toolbar place the image is not resized. By this I thought to know this property. I know the correct thing to know the free area of the window ({top, left, width, height}) and resize the image in this area. Is that possible?
Below I leave an example: Put it in the folder: "\hmg.4\svn\samples\image"
#translate CRLF => HB_OsNewLine()  // <- It would be possible to include this in "hmg.ch" or another. "Ch" ?
#include "hbqtgui.ch"
MEMVAR MainForm
FUNCTION Main
   PUBLIC MainForm
   HbQt_ErrorSys()
   WITH OBJECT MainForm := MAINWINDOW():New( "MainForm" )
      :Row    := 30
      :Col    := 10
      :Width  := 800
      :Height := 700
      :Title  := "Show bitmap usage"
      :OnInit := { || ( MainForm:Center(), RESIZE_IMG() ) }
      :Onsize := { || RESIZE_IMG() }
      WITH OBJECT MAINMENU():New( "mainmenu" )
            WITH OBJECT MENUITEM():New()
               :Caption    := "&show dim."
               :OnClick    := {|| ShowDim() }
            END WITH
      END WITH    // end PopUp
      WITH OBJECT Bitmap():New( "image1" )
         :Row        := 20
         :Col        := 10
         :Width      := 780
         :Height     := 585
         :Picture    := 'sea.jpg' // ':SEA'
         :BackColor  := { 0 , 255 , 0 }
         :Alignment  := LBL_CENTER
         :VAlignment := LBL_VCENTER
         :Stretch    := .T.
      END WITH
      MainForm:Image1:ScaledToWidth  := .T.
      MainForm:Image1:ScaledToHeight := .T.
      MainForm:Image1:stretch        := .T.
      MainForm:Image1:row            := 0
      MainForm:Image1:col            := 0
      MainForm:Image1:Smoothing      := Qt_SmoothTransformation
      MainForm:Image1:AspectRatio    := Qt_IgnoreAspectRatio
      ON KEY ALT+A OF MainForm ACTION ( eval( MainForm:oToolBar:oButton1:OnClick() ), MainForm.setfocus )
      ON KEY ALT+B OF MainForm ACTION ( eval( MainForm:oToolBar:oButton2:OnClick() ), MainForm.setfocus )
      ON KEY ALT+C OF MainForm ACTION ( eval( MainForm:oToolBar:oButton3:OnClick() ), MainForm.setfocus )
      DEFINE TOOLBAR oToolBar IMAGESIZE 80, 80 MOVEABLE .T. RIGHTTEXT TBARPLACE Qt_LeftToolBarArea
         TOOLBUTTON oButton1 ;
            Caption 'new' + CRLF + "ALT+A" ;
            picture 'hmg.png' ;
            ACTION MsgInfo( 'New!' ) ;
            tooltip 'tooltip new 2'
         TOOLBUTTON oButton2 ;
            Caption 'open' + CRLF + "ALT+B" ;
            picture 'hmg.png' ;
            ACTION  MsgInfo( 'Open!' ) ; // HMGAPP():ShowObjectsTree() ;
            tooltip 'tooltip open 2'
         TOOLBUTTON oButton3 ;
            Caption 'save' + CRLF + "ALT+C" ;
            picture 'hmg.png' ;
            ACTION MsgInfo( 'save!' ) ;
            tooltip 'tooltip save 2'
      END TOOLBAR
   END WITH
   MainForm:Activate()
   ShowDim
STATIC FUNCTION ShowDim()
   MsgStop( " W= " + hb_ValToExp( MainForm:Image1:ImageWidth() ) + " x H= " + hb_ValToExp( MainForm:Image1:ImageHeight() ) )
static function RESIZE_IMG
MainForm:Image1:Width  := MainForm:Width
MainForm:Image1:Height := MainForm:Height
MainForm:Image1:refresh()
return NIL
Free area = area marked red
It is possible to know what the dimensions of this area and not the window ?
Best Regards,
Rossine.
l3whmg
Post by l3whmg »
Hi Rossine
Rossine wrote:It is possible to know what the dimensions of this area and not the window ?
In this moment I don't have a qualified answer because this is the "centralwidget area". I must investigate with QT. Your question sounds like Ricci's question: you can try this MainForm:QtParent:Width() and MainForm:QtParent:Height(). But this dim. are stable after all widgets are painted. To know when all events are done (at this moment) it's impossible because we need to use singleshot technique...and AFAIK not possible with current HbQt.
Luigi
Luigi from Italy
www.L3W.it
l3whmg
Post by l3whmg »
Hi Rossine.
I try to find a solution about current toolbar position....but without a good answer. The only way is "oQtObjectToolbar:pos()", but this is a spatial position, not as Top, Bottom, Right, Left.
On the other hand, I can't store its value because it can be moveable and I don't found a related function.
I read about Qmainwindow:getlocation(.....) but I don't found a good Qt documentation and I don't understand if is a (real) supported function.
Cheers
Luigi from Italy
www.L3W.it
