Harbour MiniGUI 2.7.0
- Harbour MiniGUI 2.7.0 Changelog:
English:
- New: WAIT WINDOW command.
This command shows a window with a custom message and pauses
program execution until a key is pressed or mouse is clicked.
When optional NOWAIT clause is specified program execution
continue after message is displayed. To hide the message
window WAIT CLEAR must be used.
This command must be used only after main window was activated.
Syntax (Command):
WAIT WINDOW <cMessage> [ NOWAIT ] | CLEAR
Syntax (Function):
WaitWindow ( [ cMessage , lNoWait ] )
To hide the message window (WAIT CLEAR) you must omit
both parameters.
Sample 1:
WAIT WINDOW "Press any key to continue"
Sample 2:
WAIT WINDOW "Processing" NOWAIT
WAIT CLEAR
More Samples: \hmg\samples\wait_window
- New: 'System' object. It will aloow to read (and write when possible)
various operating system properties.
The first implementation allows to access (read and write) the system
clipboard and various system settings (read only).
Clipboard functions are based upon HWGUI and WHAT32 code.
Syntax:
System.Clipboard [ := <cString> ]
System.DesktopWidth
System.DesktopHeight
System.DefaultPrinter
System.DesktopFolder
System.MyDocumentsFolder
System.ProgramFilesFolder
System.SystemFolder
System.TempFolder
System.WindowsFolder
Samples:
System.Clipboard := 'a string'
MsgInfo(System.Clipboard)
MsgInfo(Str(System.DesktopWidth))
MsgInfo(Str(System.DesktopHeight))
MsgInfo(System.DefaultPrinter)
More samples: \hmg\samples\clipboard.
- Modified: Grid Control: 'This.CellValue' is writable now, so, you can
change the value of the cell being currently edited from inside 'Valid'
cell procedure. Sample: \hmg\samples\grid_14
- Modified: EXECUTE...WAIT command supports HIDE clause now.
- Modified: ADORDD library was replaced with a prior version since the one
currently distributed with Harbour has bugs (Many Thanks to Grigory
Filatov for help on this!).
- Modified: Matteo Baccan socket library are not linked by default
anymore. It will be removed in the next release. Use HBTIP instead.
- Modified: DRAW GRAPH (pie type) accepts bigger than 7 digits values
now (Thanks to Esgici).
- Fixed: Changing grid cell content in the same row being editing, from
a valid procedure not working.
- Fixed: 'AddItem' method and 'Item' (Grid) properties problems in WIn9x
systems.
- Fixed: DRAW GRAPH (pie type) problem with low values (about 0%).
Español:
- Nuevo: comando WAIT WINDOW.
Este comando muestra una ventana con un mensaje personalizado
y pausa la ejecución del programa hasta que se pulsa cualquier
tecla o se hace clic.
Cuando la cláusula opcional nowait se especifica, la ejecución
del programa continua después de mostrar el mensaje
Para ocultar la ventana debe usarse WAIT CLEAR.
Este comando debe utilizarse sólo después de que la ventana
principal se haya activado.
Sintaxis (comando):
WAIT WINDOW <cMessage> [nowait] | CLEAR
Sintaxis (Función):
WaitWindow ([cMessage, lNoWait])
Para ocultar la ventana (WAIT CLEAR) debe omitirse
ambos parámetros.
Ejemplo 1:
Ejemplo 2:
WAIT CLEAR
Más ejemplos:\HMG\samples\wait_window
- Nuevo: Objeto 'System'. Permitirá tener acceso de lectura y escritura
a varias propiedades del sistema.
La primera implementación permitirá tener acceso de lectura y escritura
al portapapeles y acceso de lectura a varias propiedades del sistema.
Las funciones de acceso al portapapeles están basadas en código de HWGUI
y WHAT32.
Sintaxis:
System.Clipboard
System.Clipboard := <cString>
System.DesktopWidth
System.SystemFolder
System.TempFolder
Ejemplos:
- Modificado: Control Grid: 'This.CellValue' puede ser modificado.
desde el procedimiento 'ColumnValid'. Ejemplo:\HMG\samples\grid_14
- Modificado: El comando EXECUTE...WAIT soporta ahora la cláusula HIDE.
- Modificado: La librería ADORDD fue reemplazada por una versión anterior
ya que la que se distribuye actualmente con Harbour presenta bugs (Muchas
Gracias a Grigory Filatov por su ayuda!).
- Modificado: La librería 'socket' de Mateo Baccan ya no es enlazada por
defecto y será removida en el próximo release. Debe usarse HBTIP en
su lugar.
- Modificado: FRAW GRAPH (pie type) acepta ahora valores mayores a 7 digitos
(Gracias a Esgici).
- Solucionado: Problemas al cambiar el contenido de las celdas
de un control Grid, desde el procedimiento 'ColumnValid', para
la fila que se está editando.
- Solucionado: Problemas con el método 'AddItem' (Grid)
en sistemas Win9x.
- Solucionado: Problemas con DRAW GRAPH (tipo PIE) con valores bajos
(cercanos al 0%).
fchirico
Re: Harbour MiniGUI 2.7.0
Post by fchirico »
Roberto Lopez wrote:- Harbour MiniGUI 2.7.0 Changelog:
Que GRANDE !!!!
Te pasaste con lo de WAIT WINDOW....
Gracias, muchas gracias!
Saludos, Fernando Chirico.
Awesome. Thanks a lot Roberto.
It really is a bonus issue. :)
Hi Roberto
Great enhancements :D
Many many thanks.
Best Regards
As you must know, I've been a FoxPro/Visual FoxPro programmer and WAIT WINDOW is one thing that I miss a lot... so I've decide to have one at HMG :)
Roberto.
Hi Roberto
For a long time I had think on a "temporary message" and don't had find a satisfying result.
Thanks a lot again :)
BTW, do you don't sleep at weekends :?:
Best Regards
esgici wrote: BTW, do you don't sleep at weekends :?:
Well... believe it or not... programming HMG is an 'entretaining' and 'relaxing' task for me... so... this has been a nice weekend... :)
Anyway... is sunny here... so... if no serious bug appears... I'll ride my dog... he is looking at me in a way that make me feel 'guilty' :)
Roberto.
Roberto Lopez wrote: I'll ride my dog... he is looking at me in a way that make me feel 'guilty' :)
It's true... here it is :)
Roberto.
gfilatov
Post by gfilatov »
Roberto Lopez wrote:... if no serious bug appears...
Hi Roberto,
There is a small issue in the procedure _HMG_SetGridCellEditValue() at the new HMG build.
Please be so kind to replace
	ELSEIF	ValType ( arg ) == 'N'
		If IsControlDefined ( 'c' , FormName)
			SetProperty ( "_hmg_grid_inplaceedit" , "c" , "value" , arg )
		ElseIf IsControlDefined ( 's' , FormName)
			SetProperty ( "_hmg_grid_inplaceedit" , "s" , "value" , arg )
		EndIf
with
		If _IsControlDefined ( 'c' , "_hmg_grid_inplaceedit")
		ElseIf _IsControlDefined ( 's' , "_hmg_grid_inplaceedit")
		EndIf
Excuse me for disturbing :!:
Hi Roberto
You are right, he is seeming very bored and enthusiast to go out :)
Good walk :)
Best Regards
