Hi everyone,
Anyone knows how to extract a file creation date? Kindly assist me.
File Creation Date
- karweru
- DBs Used: DBF,mysql,mariadb,postgresql,sqlite,odbc
File Creation Date
Kind regards,
Gilbert.
Gilbert.
Re: File Creation Date
Hello Kaweru:
This exists in Harbour and is:
? FILEDATE("C:\TEXT\TEXT.TXT") // The date
Show the date of a particular file.
Hope this helps.
Walter
Hope this helps.
Walter
Nada se pierde. Todo se transforma. (Lavoussier)
Nothing is lost. Everything changes.
- karweru
Thanks Walter. The function however seems to return the date the file was last changed, not created.
Kind regards,
Gilbert.
Gilbert.
I think we have to use Win32 API function calls for this.
http://support.microsoft.com/kb/188977
This article (for FoxPro) may help.
Have you tried the function FileStats() from harbour contrib library xHbkarweru wrote:Thanks Walter. The function however seems to return the date the file was last changed, not created.
PROCEDURE ShowStats( cFile )
LOCAL cAttrib, nSize, dCDate, nCTime, dMDate, nMTime
LOCAL cColor
IF FileStats( cFile, @cAttrib, @nSize, @dCDate, @nCTime, @dMDate, @nMTime )
@10,2 SAY "File name: " + cFile
@11,2 SAY "Attributes: '" + cAttrib + "'"
@12,2 SAY "File size: " + Alltrim( Str( nSize ) )
@13,2 SAY "Created: " + DtoC( dCDate ) + " " + TimeOfDay( nCTime )
@14,2 SAY "Modified: " + DtoC( dMDate ) + " " + TimeOfDay( nMTime )
cColor = SetColor( "r+/b" )
@10,2 SAY "NOT FOUND: " + cFile
SetColor( cColor )
RETURNKind Regards,
Thanks Grigory.
"Ohh, quien podra salvarme"
Yoooo el chapulin colorado!!!
Grigory, gracias por el dato, siempre contamos con su ayuda.
Translata Google:
"Ohh, who can be saved"
I´the chapulin colorado!!!
Grigory, thanks for the tip, always have your help.
Translata Google:
- Chapulin+Colorado[1].jpg (14.96 KiB) Viewed 4955 times
