Just upgraded to 3.0.38, but have problem...
Re: Just upgraded to 3.0.38, but have problem...
Hi Rathinagiri,
about "hbvpdf" I found "Harbour\examples\hbvpdf". I think this can solve the problem: everyone can compile and get the new library.
On the other hand, I read about "Harbour\lib\win\mingw\libhbhpdf.a" (HaruPdf) that is considered a contrib library; I don't read a lot (f.e. differences) but if can be used....
Cheers
Cheers
Luigi from Italy
www.L3W.it
www.L3W.it
Hello,
I found Report.Advanced.<n> samples also not working.
Regarding my old project, no extra library was used. I used only advanced report generator, which Roberto created last year.
Thanks.
Thanks.
Hi Sudip,
I think Rathinagiri suggest to you to have/get hbvpdf library; I think this is not a lib distribuited with Harbour: this is an example (now, I don't know in the past).
But, HMG lib use this library within report manager and for this reason you must have. I think you should consider it as a library hidden, but required.
I hope this can help you.
Cheers
Cheers
Luigi from Italy
www.L3W.it
www.L3W.it
Hi Sudip:
demo.hbp suggests demo.prg looking at the same
Looking in C:\hb31\examples\hbvpdf you found these files.
Hbvpdf.ch is also necessary
then compiles without any error.
assumes that the library is not required libhbvpdf.a in C:\HMG3.0.38\LIB and referred directly to.
SET PROCEDURE *****.PRG
demo.hbp apunta a demo.prg mirando el mismo, me encuento esto
buscando en C:\hb31\examples\hbvpdf enconte dichos archivos. tambien es necesario hbvpdf.ch
despues compila sin ningun error.
asume que no es necesaria la libreria libhbvpdf.a ya que hace referencia directa a los .PRG con SET PROCEDURE
# include "hmg.ch"
SET PROCEDURE TO hbvpdf.prg
SET PROCEDURE TO hbvpsup.prgHbvpdf.ch is also necessary
Set procedure to hbvpdf.prg
Set procedure to hbvpsup.prgdespues compila sin ningun error.
- Report.jpg (153.81 KiB) Viewed 7565 times
Thanks a lot to all of you
I shall check your suggestions.
Samples\Report.Advanced.1 works after copying hbpdf... files
But, how can I create the lib file?
I am out of touch with HMG for some months, and I need your help / tips
Thanks.
After 10 min.
I added these prg files in my old project. It works!
Thanks a lot.
Thanks.
After 10 min.
Thanks a lot.
Nice coming back Sudip.
Hi Sudip
the most simple it's to run "hbmk2 hbvpdf.hbp" within folder "harbour\examples\hbvpdf" (I don't try but theorically must work fine). Then you can copy the lib file or put a good pointer to this folder within your project.
Cheers
Cheers
Luigi from Italy
www.L3W.it
www.L3W.it
Hi Grigory,gfilatov wrote:Hi Rathi,rathinagiri wrote:...
where can we find these functionalities?
There is a new class WIN_OLEAUTO instead of old TOleAuto() in the Harbour contrib HBWIN library.
You can uncomment also the function FreeLibrary() in the HMG source file c_winapimisc.c as belowHope that helpsCode: Select all
HB_FUNC( FREELIBRARY ) { FreeLibrary( (HMODULE) hb_parnl( 1 ) ) ; }
I tried to compile with 3.1 and had the following problems:
1. Will "WIN_OLEAUTO" just replace TOleAuto()?
2. I got errors of not finding the libraries for functions isnil, ischar, isarray
Any ideas?
Hi Rathi,rathinagiri wrote: Hi Grigory,
Any ideas?
I've prepared a working class TOleAuto (based upon WIN_OLEAUTO) below.
Please take a look for source of file hbole.prg :
* Harbour Project source code:
* Compatibility calls.
* Copyright 2009 Viktor Szakats (harbour.01 syenar.hu)
* www - http://harbour-project.org
#define HB_CLS_NOTOBJECT /* avoid definition of method: INIT */
#include "hbclass.ch"
#include "common.ch"
#include "error.ch"
#define EG_OLEEXCEPTION 1001
STATIC s_bBreak := { | oError | Break( oError ) }
STATIC PROCEDURE Throw( oError )
LOCAL lError := Eval( ErrorBlock(), oError )
IF ! ISLOGICAL( lError ) .OR. lError
__ErrInHandler()
Break( oError )
STATIC FUNCTION ThrowOpError( nSubCode, cOperator, ... )
LOCAL oError
oError := ErrorNew()
oError:Args := { ... }
oError:CanDefault := .F.
oError:CanRetry := .F.
oError:CanSubstitute := .T.
oError:Description := "argument error"
oError:GenCode := EG_ARG
oError:Operation := cOperator
oError:Severity := ES_ERROR
oError:SubCode := nSubCode
oError:SubSystem := "BASE"
RETURN Throw( oError )
CREATE CLASS TOLEAUTO FROM WIN_OLEAUTO
/* TODO: Implement compatibility to the required extent */
VAR cClassName
METHOD New( xOle, cClass )
METHOD hObj( xOle )
METHOD OleValuePlus( xArg ) OPERATOR "+"
METHOD OleValueMinus( xArg ) OPERATOR "-"
METHOD OleValueMultiply( xArg ) OPERATOR "*"
METHOD OleValueDivide( xArg ) OPERATOR "/"
METHOD OleValueModulus( xArg ) OPERATOR "%"
METHOD OleValuePower( xArg ) OPERATOR "^"
METHOD OleValueInc() OPERATOR "++"
METHOD OleValueDec() OPERATOR "--"
METHOD OleValueEqual( xArg ) OPERATOR "="
METHOD OleValueExactEqual( xArg ) OPERATOR "=="
METHOD OleValueNotEqual( xArg ) OPERATOR "!="
ENDCLASS
METHOD hObj( xOle ) CLASS TOLEAUTO
IF PCount() > 0 .AND. xOle != NIL
IF ISNUMBER( xOle )
xOle := __OLEPDISP( xOle )
IF hb_isPointer( xOle )
::__hObj := xOle
RETURN ::__hObj
METHOD New( xOle, cClass ) CLASS TOLEAUTO
LOCAL hOle
LOCAL oError
IF ISNUMBER( xOle )
::__hObj := xOle
IF ISCHARACTER( cClass )
::cClassName := cClass
::cClassName := hb_ntos( win_P2N( xOle ) )
ELSEIF ISCHARACTER( xOle )
hOle := __OleCreateObject( xOle )
IF ! Empty( hOle )
::__hObj := hOle
::cClassName := xOle
oError:Args := hb_AParams()
oError:Description := win_OleErrorText()
oError:GenCode := EG_OLEEXCEPTION
oError:Operation := ProcName()
oError:SubCode := -1
oError:SubSystem := "TOleAuto"
RETURN Self
FUNCTION CreateObject( xOle, cClass )
RETURN TOleAuto():New( xOle, cClass )
FUNCTION GetActiveObject( xOle, cClass )
LOCAL o := TOleAuto():New()
LOCAL hOle
LOCAL oError
IF ISNUMBER( xOle )
o:__hObj := xOle
o:cClassName := cClass
o:cClassName := hb_ntos( win_P2N( xOle ) )
hOle := __OleGetActiveObject( xOle )
IF ! Empty( hOle )
o:__hObj := hOle
o:cClassName := xOle
RETURN o
METHOD OleValuePlus( xArg ) CLASS TOLEAUTO
LOCAL xRet
BEGIN SEQUENCE WITH s_bBreak
xRet := ::OleValue + xArg
RECOVER
RETURN ThrowOpError( 1081, "+", Self, xArg )
END SEQUENCE
RETURN xRet
METHOD OleValueMinus( xArg ) CLASS TOLEAUTO
LOCAL xRet
xRet := ::OleValue - xArg
RECOVER
RETURN ThrowOpError( 1082, "-", Self, xArg )
END SEQUENCE
RETURN xRet
METHOD OleValueMultiply( xArg ) CLASS TOLEAUTO
LOCAL xRet
xRet := ::OleValue * xArg
RECOVER
RETURN ThrowOpError( 1083, "*", Self, xArg )
END SEQUENCE
RETURN xRet
METHOD OleValueDivide( xArg ) CLASS TOLEAUTO
LOCAL xRet
xRet := ::OleValue / xArg
RECOVER
RETURN ThrowOpError( 1084, "/", Self, xArg )
END SEQUENCE
RETURN xRet
METHOD OleValueModulus( xArg ) CLASS TOLEAUTO
LOCAL xRet
xRet := ::OleValue % xArg
RECOVER
RETURN ThrowOpError( 1085, "%", Self, xArg )
END SEQUENCE
RETURN xRet
METHOD OleValuePower( xArg ) CLASS TOLEAUTO
LOCAL xRet
xRet := ::OleValue ^ xArg
RECOVER
RETURN ThrowOpError( 1088, "^", Self, xArg )
END SEQUENCE
RETURN xRet
METHOD OleValueInc() CLASS TOLEAUTO
++::OleValue
RECOVER
RETURN ThrowOpError( 1086, "++", Self )
END SEQUENCE
RETURN Self
METHOD OleValueDec() CLASS TOLEAUTO
--::OleValue
RECOVER
RETURN ThrowOpError( 1087, "--", Self )
END SEQUENCE
RETURN Self
METHOD OleValueEqual( xArg ) CLASS TOLEAUTO
LOCAL xRet
xRet := ( ::OleValue = xArg ) /* NOTE: Intentionally using '=' operator. */
RECOVER
RETURN ThrowOpError( 1089, "=", Self, xArg )
END SEQUENCE
RETURN xRet
METHOD OleValueExactEqual( xArg ) CLASS TOLEAUTO
LOCAL xRet
xRet := ( ::OleValue == xArg )
RECOVER
RETURN ThrowOpError( 1090, "==", Self, xArg )
END SEQUENCE
RETURN xRet
METHOD OleValueNotEqual( xArg ) CLASS TOLEAUTO
LOCAL xRet
xRet := ( ::OleValue != xArg )
RECOVER
RETURN ThrowOpError( 1091, "!=", Self, xArg )
END SEQUENCE
RETURN xRet
#pragma BEGINDUMP
#include "hbapi.h"
#include "hbwinole.h"
HB_FUNC( OLE2TXTERROR )
HRESULT lOleError;
if( HB_ISNUM( 1 ) )
lOleError = hb_parnl( 1 );
lOleError = hb_oleGetError();
switch( lOleError )
case S_OK: hb_retc_const( "S_OK" ); break;
case CO_E_CLASSSTRING: hb_retc_const( "CO_E_CLASSSTRING" ); break;
case OLE_E_WRONGCOMPOBJ: hb_retc_const( "OLE_E_WRONGCOMPOBJ" ); break;
case REGDB_E_CLASSNOTREG: hb_retc_const( "REGDB_E_CLASSNOTREG" ); break;
case REGDB_E_WRITEREGDB: hb_retc_const( "REGDB_E_WRITEREGDB" ); break;
case E_OUTOFMEMORY: hb_retc_const( "E_OUTOFMEMORY" ); break;
case E_INVALIDARG: hb_retc_const( "E_INVALIDARG" ); break;
case E_UNEXPECTED: hb_retc_const( "E_UNEXPECTED" ); break;
case E_NOTIMPL: hb_retc_const( "E_NOTIMPL" ); break;
case DISP_E_UNKNOWNNAME: hb_retc_const( "DISP_E_UNKNOWNNAME" ); break;
case DISP_E_UNKNOWNLCID: hb_retc_const( "DISP_E_UNKNOWNLCID" ); break;
case DISP_E_BADPARAMCOUNT: hb_retc_const( "DISP_E_BADPARAMCOUNT" ); break;
case DISP_E_BADVARTYPE: hb_retc_const( "DISP_E_BADVARTYPE" ); break;
case DISP_E_EXCEPTION: hb_retc_const( "DISP_E_EXCEPTION" ); break;
case DISP_E_MEMBERNOTFOUND: hb_retc_const( "DISP_E_MEMBERNOTFOUND" ); break;
case DISP_E_NONAMEDARGS: hb_retc_const( "DISP_E_NONAMEDARGS" ); break;
case DISP_E_OVERFLOW: hb_retc_const( "DISP_E_OVERFLOW" ); break;
case DISP_E_PARAMNOTFOUND: hb_retc_const( "DISP_E_PARAMNOTFOUND" ); break;
case DISP_E_TYPEMISMATCH: hb_retc_const( "DISP_E_TYPEMISMATCH" ); break;
case DISP_E_UNKNOWNINTERFACE: hb_retc_const( "DISP_E_UNKNOWNINTERFACE" ); break;
case DISP_E_PARAMNOTOPTIONAL: hb_retc_const( "DISP_E_PARAMNOTOPTIONAL" ); break;
default:
char buf[ 16 ];
hb_snprintf( buf, 16, "0x%08x", ( UINT ) ( HB_PTRUINT ) lOleError );
hb_retc( buf );
HB_FUNC( __OLEPDISP )
hb_oleInit();
hb_oleItemPut( hb_param( -1, HB_IT_ANY ),
( IDispatch * ) ( HB_PTRUINT ) hb_parnint( 1 ) );
#pragma ENDDUMP
* $Id: hbwinole.h 16046 2011-01-14 07:35:19Z druzus $
* OLE library C header
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2, or (at your option)
* any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this software; see the file COPYING. If not, write to
* the Free Software Foundation, Inc., 59 Temple Place, Suite 330,
* Boston, MA 02111-1307 USA (or visit the web site http://www.gnu.org/).
* As a special exception, the Harbour Project gives permission for
* additional uses of the text contained in its release of Harbour.
* The exception is that, if you link the Harbour libraries with other
* files to produce an executable, this does not by itself cause the
* resulting executable to be covered by the GNU General Public License.
* Your use of that executable is in no way restricted on account of
* linking the Harbour library code into it.
* This exception does not however invalidate any other reasons why
* the executable file might be covered by the GNU General Public License.
* This exception applies only to the code released by the Harbour
* Project under the name Harbour. If you copy code from other
* Harbour Project or Free Software Foundation releases into a copy of
* Harbour, as the General Public License permits, the exception does
* not apply to the code that you add in this way. To avoid misleading
* anyone as to the status of such modified files, you must delete
* this exception notice from them.
* If you write modifications of your own for Harbour, it is your choice
* whether to permit this exception to apply to your modifications.
* If you do not wish that, delete this exception notice.
#ifndef __HBWINOLE_H
#define __HBWINOLE_H
#include "hbapi.h"
#include "hbapiitm.h"
#include "hbapicls.h"
#include "hbapierr.h"
#include "hbvm.h"
#include "hbstack.h"
#include "hbdate.h"
#if defined( HB_OS_WIN )
/* This option can resolve compilation problems in C++ mode for some
* compilers like OpenWatcom but not for all, f.e. it will not help
* BCC when used with -P (C++ mode) switch.
#if defined( __cplusplus ) && !defined( CINTERFACE )
#define CINTERFACE 1
#endif
/* This code uses named union so this declaration is necessary for
* compilers where nameless unions are default
#if defined( __BORLANDC__ ) || \
( defined( __WATCOMC__ ) && !defined( __cplusplus ) )
# if !defined( NONAMELESSUNION )
# define NONAMELESSUNION
# endif
#endif
#include <windows.h>
#include <ole2.h>
#include <ocidl.h>
/* MinGW is lacking a number of variant accessors
#if defined( __MINGW32__ )
# if !defined( V_I1REF )
# define V_I1REF( x ) V_UNION( x, pcVal )
# endif
# if !defined( V_UI2REF )
# define V_UI2REF( x ) V_UNION( x, puiVal )
# endif
# if !defined( V_INT )
# define V_INT( x ) V_UNION( x, intVal )
# endif
# if !defined( V_INTREF )
# define V_INTREF( x ) V_UNION( x, pintVal )
# endif
# if !defined( V_UINT )
# define V_UINT( x ) V_UNION( x, uintVal )
# endif
# if !defined( V_UINTREF )
# define V_UINTREF( x ) V_UNION( x, puintVal )
# endif
#endif
#if defined( NONAMELESSUNION )
# define HB_WIN_U1( x, y ) ( x )->n1.y
# define HB_WIN_U2( x, y ) ( x )->n1.n2.y
# define HB_WIN_U3( x, y ) ( x )->n1.n2.n3.y
#else
# define HB_WIN_U1( x, y ) ( x )->y
# define HB_WIN_U2( x, y ) ( x )->y
# define HB_WIN_U3( x, y ) ( x )->y
#endif
/* macros used to hide type of interface: C or C++
#if defined( __cplusplus ) && !defined( CINTERFACE ) && \
( defined( __BORLANDC__ ) || \
defined( __DMC__ ) || \
defined( _MSC_VER ) || \
defined( __MINGW32__ ) || \
( defined( __WATCOMC__ ) && ( __WATCOMC__ >= 1270 ) ) )
# define HB_ID_REF( id ) ( id )
# define HB_VTBL( pSelf ) ( pSelf )
# define HB_THIS( pSelf )
# define HB_THIS_( pSelf )
#else
# define HB_OLE_C_API 1
# define HB_ID_REF( id ) ( &id )
# define HB_VTBL( pSelf ) ( pSelf )->lpVtbl
# define HB_THIS( pSelf ) ( pSelf )
# define HB_THIS_( pSelf ) ( pSelf ),
#endif
HB_EXTERN_BEGIN
typedef HB_BOOL ( * HB_OLEOBJ_FUNC )( VARIANT*, PHB_ITEM );
typedef void ( * HB_OLE_DESTRUCTOR_FUNC )( void * );
extern HB_EXPORT HB_BOOL hb_oleInit( void );
extern HB_EXPORT HRESULT hb_oleGetError( void );
extern HB_EXPORT void hb_oleSetError( HRESULT lOleError );
extern HB_EXPORT void hb_oleDispatchToItem( PHB_ITEM pItem, IDispatch* pdispVal, HB_USHORT uiClass );
extern HB_EXPORT IDispatch* hb_oleItemGetDispatch( PHB_ITEM pItem );
extern HB_EXPORT void hb_oleVariantToItem( PHB_ITEM pItem, VARIANT * pVariant );
extern HB_EXPORT void hb_oleVariantToItemEx( PHB_ITEM pItem, VARIANT* pVariant, HB_USHORT uiClass );
extern HB_EXPORT void hb_oleItemToVariant( VARIANT * pVariant, PHB_ITEM pItem );
extern HB_EXPORT void hb_oleItemToVariantEx( VARIANT* pVariant, PHB_ITEM pItem, HB_OLEOBJ_FUNC pObjFunc );
extern HB_EXPORT void hb_oleVariantUpdate( VARIANT * pVariant, PHB_ITEM pItem, HB_OLEOBJ_FUNC pObjFunc );
extern HB_EXPORT IDispatch* hb_oleParam( int iParam );
extern HB_EXPORT IDispatch* hb_oleItemGet( PHB_ITEM pItem );
extern HB_EXPORT PHB_ITEM hb_oleItemPut( PHB_ITEM pItem, IDispatch * pDisp );
extern HB_EXPORT PHB_ITEM hb_oleItemGetCallBack( PHB_ITEM pItem );
extern HB_EXPORT void hb_oleItemSetCallBack( PHB_ITEM pItem, PHB_ITEM * pCallBack );
extern HB_EXPORT HB_BOOL hb_oleDispInvoke( PHB_SYMB pSym, PHB_ITEM pObject, PHB_ITEM pParam,
DISPPARAMS * pParams, VARIANT* pVarResult,
HB_OLEOBJ_FUNC pObjFunc, HB_USHORT uiClass );
extern HB_EXPORT void hb_oleItemSetDestructor( PHB_ITEM pItem, HB_OLE_DESTRUCTOR_FUNC pFunc, void * cargo );
/* activex control */
extern HB_EXPORT HB_BOOL hb_oleAxInit( void );
extern HB_EXPORT PHB_ITEM hb_oleAxControlNew( PHB_ITEM pItem, HWND hWnd );
HB_EXTERN_END
#endif
#endif /* __HBWINOLE_H */
- IS*() -> HB_IS*()
Hope that helps
