Uppercase in textbox (HMG4)
pctoledo
Post by pctoledo »
Hi Friends, how to convert characters to uppercase in textbox?
Toledo
Clipper On Line
pctoledo
Re: Uppercase in textbox (HMG4)
Post by pctoledo »
Friends, to decide the problem with CaseConvert and MaxLength, I modified the file textbox.prg:
// Internal Data
   DATA nMaxLength                                INIT   0
METHOD MaxLength( nValue ) CLASS TEXTBOX
   IF PCOUNT() == 0
      RETURN ::nValue
   ELSEIF PCOUNT() == 1
      ::nMaxLength := nValue
METHOD CASEConvert( nValue ) CLASS TEXTBOX
   IF PCOUNT() == 0
      RETURN ::nValue
      ::nCaseConvert := nValue
METHOD ProcessTextChange( cText ) CLASS TEXTBOX
   LOCAL icp, InBufferLeft, InBufferRight
   HB_SYMBOL_UNUSED( cText )
   IF ::lDateTextBoxActive
      ::lDateTextBoxActive := .F.
      icp := ::oQTObject:cursorPosition()
      IF ::nCaseConvert>0
       cText := IF(::nCaseConvert==1,UPPER(cText),LOWER(cText))
       ::oQTObject:setText( cText )
       ::oQTObject:setCursorPosition( icp )
      IF ::nMaxLength>0
         IF Len( cText ) > ::nMaxLength
            InBufferLeft := Left( cText , icp )
            InBufferRight := Right( cText , Len( cText ) - icp - 1 )
            ::oQTObject:setText( LEFT(InBufferLeft + InBufferRight,::nMaxLength) )
      IF Len( ::cInputMask ) > 0
         IF ::cTextBoxType == 'MASKEDTEXT'
            IF ::lMaskedFlag == .T.
               Self:ProcessCharmask( .t. )
            IF ValType( ::bOnChange ) != 'U'
               Eval( ::bOnChange )
         ELSEIF ::cTextBoxType == 'CHARMASKTEXT'
            Self:ProcessCharMask()
               Eval( ::bOnChange )
         IF ::cTextBoxType == 'NUMTEXT'
            Self:ProcessNumText()
            Eval( ::bOnChange )
I do not know if it is the best solution, but it gave certain!
Samples:
      With Object oFriend := TextBox():New( "oFriend" )
         :Row            := 85
         :Col            := 15
         :Width          := 485
         :Height         := 20
         :ToolTip        := 'Name of the Friend'
         :MaxLength      := 50
         :OnEnter        := { || InsertTab() }
         :CaseConvert    := 1
      End With
Toledo
Clipper On Line
pctoledo
Post by pctoledo »
It gives error with accented letters (ÁÉÃÕÇ) :oops: :cry:
Toledo
Clipper On Line
pctoledo
Post by pctoledo »
Hi Friends, problem resolved:
   LOCAL icp, InBufferLeft, InBufferRight, InBuffer
      IF ::nCaseConvert>0
       InBuffer := ::oQTObject:text()
       InBuffer := IF(::nCaseConvert==1,UPPER(InBuffer),LOWER(InBuffer))
       ::oQTObject:setText( InBuffer )
      IF ::nMaxLength>0
         IF Len( InBuffer ) > ::nMaxLength
            InBufferLeft := Left( InBuffer , icp )
            InBufferRight := Right( InBuffer , Len( InBuffer ) - icp - 1 )
               Eval( ::bOnChange )
               Eval( ::bOnChange )
            Eval( ::bOnChange )
Toledo
Clipper On Line
Nice work
mrduck
Post by mrduck »
   IF PCOUNT() == 0
      RETURN ::nValue
   IF PCOUNT() == 0
      RETURN ::nValue
Sorry, but this code has an error in the RETURN ::nValue...
pctoledo
Post by pctoledo »
Correct, it is true:
   IF PCOUNT() == 0
      RETURN ::nCaseConvert
   IF PCOUNT() == 0
      RETURN ::nMaxLength
Sorry!
Toledo
Clipper On Line
mrduck
Post by mrduck »
Patch commited to svn
please check
pctoledo
Post by pctoledo »
mrduck, need only change:
Thanks!
Toledo
Clipper On Line
mrduck
Post by mrduck »
pctoledo wrote:mrduck, need only change:
Thanks!
done, sorry
