HMG4: start, quit, resource, localized
Hi friends.
I've found the way to introduce usage of QLocale: this can be useful to internationalize applications.
Also, I thought it best to manage start end (I'm referring to QApplication) in a different way: centralized.
I will expose later, but before I want fix some things:
- I want change from "s_qApp" to "s_oQtApp"
- I want change from "s_qRes" to "s_oQtRes"
- I want change from "oDefaultParent" to "s_oDefaultParent"
- I want change from "nObjectCounter" to "s_nObjectCounter"
- I want change from "oMainWindow" to "s_oMainWindow"
- I want change from "lGridCellFlag" to "s_lGridCellFlag"
- I want change from "application.prg" to "globshared.prg"
Why these changes?
First: these are all shared variables. Prefixing with "s_" we can catch immediatly in our sources; on the other hand look at the first two rows: when HMG4 start someone use it.
Second: I need to introduce other vars (ie bOnStartUp, bOnShutDown, etc. see the explanation below). With "s_" we can catch immediatly
Third: first two rows from "s_q..." to "s_oQt..." (there are other vars in sources... ie oFont). These are real QT object. I think: for every real Qt object we must use "oQt".
Fourth: because "application" can be misunderstood.
Tell me your opinion. If you are in agreement: I will do.
Well and now the other job.
I want create a HMGAPP class, source file hmgapp.prg OR APPLICATION class, source file application.prg; with this class we can:
1) start and stop Q... in a centralized way. examples: HMGAPP():Start() and HMGAPP():Quit()
2) test if Qt already started or not (adding "s_lQtStarted"). example: IF ::s_lQtStarted == .F. ; HMGAPP():Start() ; ENDIF (note this must/can be inserted in every New method)
3) have a startup procedure (adding "s_bOnStartUp") and/or a shutdown procedure (adding "s_bOnShutDown" ). example (inside Start method): IF hb_IsBlock( ::s_onStartUp ) == .T. ; EVAL( ::s_OnStartUp ) ; ENDIF
4) register resource without start Qapplication: this is a little trick. I preserve "RegisterResource" but this command need QApplication started
5) tell where are the Qt plugins (adding "s_cPlugInDir)
6) set localization. Warning. QT doc say (somewhere): you must set localization before starting GUI application.
Bingo: now HMG4 can do with a centralized starter (adding "s_nLanguage" and "s_nCountry")
FAQ:
A) when Qapplication is started? If we call HMGAPP():Start() or in any HMG object (obviously window.prg) with point 2)
B) when Qapplication end? We have two options:
- connecting the "QEvent_Close" event of the Main Window
ie ::oQTObject:connect( QEvent_Close, {|| HMGAPP():Quit() } ) )
OR
- calling HMG():Quit() inside main program
IMHO the last one it's better, why? Because WND_MAIN can not be the last window!
Best regards
Why these changes?
FAQ:
OR
Best regards
Luigi from Italy
www.L3W.it
www.L3W.it
Re: HMG4: start, quit, resource, localized
Great going Luigi. I desperately require unicode implementation. I think what you are suggesting is for good only. Please go ahead.
Hi guys.
Today I do a commit, his number is 652. Here the changelog.
But it's most important that I know and understand this comment from window.prg
Who write but why "Must be an empty block"?
I need to change code inside window.prg:
- into Create method I must add some lines
I can't introduce my mod. because bOnRelease it's always a Block, but why can't be NIL? Where is the problem?
- into OnRelease method only a little change without problem
Inside Changelog I don't find any comment about "Must be an empty block". Please give me a answer.
Best regards
This is the first piece of my job. Now I wiil try to introduce the other part.2011-07-11 15:30 UTC+0100 Luigi Ferraris ( <luigi at l3w.it> ) ! source/globshared.prg
! source/checkbox.prg
! source/combobox.prg
! source/control.prg
! source/datepicker.prg
! source/grid.prg
! source/ipaddress.prg
! source/printer.prg
! source/resource.prg
! source/spinner.prg
! source/textbox.prg
! source/virtualgrid.prg
! source/window.prg
! source/windowgroup.prg
! change shared var name from "s_qApp" to "s_oQtApp"
! change shared var name from "s_qRes" to "s_oQtRes"
! change shared var name from "oDefaultParent" to "s_oDefalutParent"
! change shared var name from "nObjectCounter" to "s_nObjectCounter"
! change shared var name from "oMainWindow" to "s_oMainWindow"
! change shared var name from "lGridCellFlag" to "s_lGridCellFlag"
! source/basic.prg
! change class name from "APPLICATION" to "GLOBSHARED"
! hmg.hbp
! change from "source/application.prg" to "source/globshared.prg"
+ source/globshared.prg
- source/application.prg
* changed source name to prevent misunderstood for the future
DATA bOnRelease INIT {|| .T. } // Must be an empty block.I need to change code inside window.prg:
// Nothing To Do
ELSEIF ::nType == WND_MAIN // Main
IF VALTYPE( ::bOnRelease ) <> "B" <====
::oQTObject:connect( QEvent_Close, {|| HMGAPP():quit() } ) <====
ENDIF <====
ELSEIF ::nType == WND_CHILD // Child
::oQTObject:connect( QEvent_Close, {|| ( EVAL( ::bOnRelease ), HMGAPP():quit() ) } )
ELSEIF ::nType == WND_MODAL
Best regards
Luigi from Italy
www.L3W.it
www.L3W.it
Hi, I've notice the same problem into the Create method for Modal window:
I think it's better to add these lines, but bOnrelease it's an empty block!
Best regards
ELSEIF ::nType == WND_MODAL // Modal
::oQTObject:SetWindowModality( 2 )
IF VALTYPE( ::bOnRelease ) <> "B" <=====
::oQTObject:connect( QEvent_Close, {|| ::oEventLoop:Exit( 0 ) } ) <=====
ENDIF <=====
Best regards
Luigi from Italy
www.L3W.it
www.L3W.it
Because it is called somewhere without the need to check if it's NUL or a codeblock.l3whmg wrote: But it's most important that I know and understand this comment from window.prgWho write but why "Must be an empty block"?Code: Select all
I was talking with Mauricio about this piece of code a couple of days ago. We were modifying this code snippet to intercept when a window is closed clicking on the X.
Hello All,
This my first post. Excuse me if I'm posting in the wrong place
I'm starting with hmg.4 here and did a FIX.
In window.prg I changed to evaluate a block in the output form:
Is this correct or is how this work better?
Sorry, I use google translator
Best Regards,
Rossine.
// Events
METHOD OnReleaseProcess SETGET && Rossine 29/06/11
METHOD OnRelease( bValue ) CLASS WINDOW
IF Pcount() == 0
RETURN ::bOnRelease
ELSEIF Pcount() == 1
IF .NOT. ::oQTObject:connect( QEvent_Close, { |oEvent| iif( ::OnReleaseProcess( QEvent_Close, oEvent, bValue ), ::s_qApp:Quit(), NIL ) } ) && Rossine 29/06/11
::oQTObject:disconnect( QEvent_Close )
IF .NOT. ::oQTObject:connect( QEvent_Close , { |oEvent|iif( ::OnReleaseProcess( QEvent_Close, oEvent, bValue ), ::s_qApp:Quit(), NIL ) } ) && Rossine 29/06/11
// Error
IF .NOT. ::oQTObject:connect( QEvent_Close , { |oEvent| iif( ::OnReleaseProcess( QEvent_Close, oEvent, bValue ), ::oEventLoop:Exit( 0 ), NIL ) } ) && Rossine 29/06/11
// Error
IF .NOT. ::oQTObject:connect( QEvent_Close , { ||( Eval( bValue ) ) } )
// Error
::bOnRelease := bValue
METHOD OnReleaseProcess( nEvent, oEvent, bValue ) CLASS WINDOW && Rossine 29/06/11
local lReturnValue := .T.
do case
case nEvent == QEvent_Close
lReturnValue := Eval( bValue )
if ValType( lReturnValue ) == 'L'
if lReturnValue
oEvent:accept()
oEvent:ignore()
oEvent:accept()
endcase
return lReturnValue
Best Regards,
Rossine.
Hi Rossine, please to meet you!
I read your code and some a few days ago I write of this with MrDuck.
IMHO, I think it's not a good idea - inside HMG4 library - check returned value of a block.
Why? Because in your program you want check .T. or .F. (accepted or rejected) or other value (accepted), but in my program I want check "1" or "2" (accepted or rejected) or other value (accepted). This is an example. Someone can add other pow.
What do you think about this example?
Best regards
Best regards
Luigi from Italy
www.L3W.it
www.L3W.it
Hi MrDuck.
I understand your answer, but I can figure out where bOnRelease must be an empty block. I find all "connect" where is OnClose but nothing.
Well, I can do a little trick but I must add a var.
lOnReleaseBlock set to .F. by default, inside OnRelease method lOnReleaseBlock set to .T. I can use this var to bypass my problem, but I don't like very much.
Luigi from Italy
www.L3W.it
www.L3W.it
Hi Rossine
I'm in talks with concentra about this matter, correct handling of close and release events. I hope Mauricio reads this thread and can get some ideas from your code.
please note that in similar cases the method was called DoOnXXXX instead of onXXXXProcess
Why did you pass the event type ? who also can call that method ? perhaps all these helper methods should be turned private....
Thanks and welcome
Thanks and welcome
Hi friends, I do a new commit with the second part of my job.
I compile and check other demo (winmain, winmodal and resource folders): all work well. I have been able to verify the compatibility of previous programs.
Note: I change bOnRelease value from empty block to NIL. I think this is the right way.
On the other hand, you can look inside window.prg: I've fixed a lot of code when value must be assigned adding check of VALTYPE. I think this must be a must in every source.
IMHO I think it's better to reord source code: please take a look at hmgapp.prg.
Now I want change method to have THISWINDOW and remove "MEMVAR __cActiveWindow". Why? First: I think this is a dangerous method (MEMVAR). Second: I have found some problems somewhere with this. I've already do an experiment with my fork and work well.
Then, I want rewrite menu manager. Also this, to remove use of many vars (see GetPopupVarName). I've already do an experiment with my fork and work well.
Please: use /w3 option during compilation. I have found demo with errors This is another reason to change use of MEMVAR...
Best regards
To show new usage of HMGAPP class, I create "samples/agoodstart" folder. Here you can look the new implementation; a special look to "Localized" method.+ samples/agoodstart
+ samples/agoodstart/build.bat
+ samples/agoodstart/demo_1.hbp
+ samples/agoodstart/demo_1.prg
+ samples/agoodstart/demo_1.qrc
+ samples/agoodstart/demo_2.hbp
+ samples/agoodstart/demo_2.prg
+ samples/agoodstart/demo_2.qrc
+ samples/agoodstart/hbmk.hbm
+ samples/agoodstart/other_res1.qrc
+ samples/agoodstart/other_res2.qrc
+ samples/agoodstart/other_res3.qrc
+ samples/agoodstart/other_res4.qrc
+ samples/agoodstart/qt.conf
+ samples/agoodstart/resource
+ samples/agoodstart/resource/exit.png
+ samples/agoodstart/resource/find.png
+ samples/agoodstart/resource/hmg.png
+ samples/agoodstart/resource/print.png
+ samples/agoodstart/resource/save.png
* to show usage of new hmgapp class and methods
! source/window.prg
* change default value of bOnrelease from {||.T.} to NIL
empty block by default
* change OnRelease and Create methods in according with new hmgapp class
to handle hmgapp():Quit() method
* clean code
! fixed check valtype in every method setget before assign
; TODO: in every source we must do this work!
! source/basic.prg
! source/window.prg
+ inside New method check "s_lQtStarted" status;
if false call HMGAPP():Start()
* include/hmg.ch
* command SET RESOURCE TO changed in according with new hmgapp():Resources()
+ command SET QTLOCALE TO in according with new hmgapp():Localized()
+ translate QTLANGUAGE in according with new hmgapp():Language()
+ translate QTCOUNTRY in according with new hmgapp():Country()
+ command STARTUP in according with new hmgapp():Start()
+ command SHUTDOWN in according with new hmgapp():Quit()
+ command ADDQTRESOURCE in according with new hmgapp():RegisterResource()
+ command SET ONSHUTDOWN TO in according with new hmgapp():OnShutDown()
+ command SET ONSTARTUP TO in according with new hmgapp():OnStartUp()
! fixed some Xbase command to respect rule
- removed New method. unusefull here, see new hmgapp class
- removed HMG4_Reset() function. see hmgapp class, Reset() method
+ add shared vars: s_nCountry, s_nLanguage, s_bOnShutDown, s_bOnStartUp,
s_cPlugInDir, s_oQtLocale, s_lQtStarted
+ include/hmg_qtimage.ch
+ include/hmg_qtlocale.ch
* These sources contain definitions used by QT library. At this moment the
are not present in HbQt library.
; hmg_qtimage: to manage image with QPainter
; hmg_qtlocale: to manage language and country
; TODO These files can be removed when library "HbQT" will contain that
* hmg.hbp
+ hmgapp.prg
- resource.prg
- source/resource.prg
* unused. see new hmgapp class and methods
+ source/hmgapp.prg
* add hmgapp class and methods
* changelog
* fixed wrong data of my previous 652 commit
Best regards
Luigi from Italy
www.L3W.it
www.L3W.it
