Using Graph
sudip
Using Graph
Post by sudip »
I just wrote a program to show the output in graph (from the data generated from my good-old Clipper/xHarbour+gtwvw program!!!). So my clients can use it as an add-on. :) Here is the code for it.
I created two arrays aSer which is array of series, ay which contains y values.
I started to write the code from Graph_3 of samples folder. So, it's basically a modified demo. But, modification is so much that I want to share it with all of you.
Function GenerateGraph(aSer, ay, mGraphTitle)
	Define Window GraphTest ;
		At 0,0 ;
		Width 640 ;
		Height 480 ;
		Title "Graph" ;
		MODAL ;
		BackColor { 255 , 255 , 255 } ;
		On Init DrawGraph ( 1, aSer, ay, mGraphTitle )
		@ 415, 20 label lblGraphtype value "Graph Type:" TRANSPARENT
		@ 415, 120 combobox cboGraphtype ;
			items {"Bars", "Lines", "Points"} ;
			value 1 ;
			on change DrawGraph(this.value, aSer, ay, mGraphTitle)
		@ 415, 500 button cmdPrint caption "Print" ;
			Action PRINT GRAPH OF GraphTest PREVIEW DIALOG
	End Window
	GraphTest.Center
	Activate Window GraphTest
Procedure DrawGraph ( mGraphType, aSer, ay, mGraphTitle )
	ERASE WINDOW GraphTest
	if mGraphtype = 1
		DRAW GRAPH							;
			IN WINDOW GraphTest					;
			AT 20,20						;
			TO 400,610						;
			TITLE mGraphTitle				;
			TYPE BARS						;
			SERIES aSer					;
			YVALUES ay			;
			DEPTH 15						;
			BARWIDTH 15						;
			HVALUES 5						;
			SERIENAMES {"Sale"}		;
			COLORS { {128,128,255} }	;
			3DVIEW    						;
			SHOWGRID                        			;
			SHOWXVALUES                     			;
			SHOWYVALUES                     			;
			; //SHOWLEGENDS 						;
		NOBORDER
	elseif mGraphtype = 2
		DRAW GRAPH							;
			AT 20,20						;
			TO 400,610						;
			TITLE mGraphTitle				;
			TYPE LINES					;
			SERIES aSer					;
			YVALUES ay			;
			DEPTH 15						;
			BARWIDTH 15						;
			HVALUES 5						;
			3DVIEW    						;
			SHOWGRID                        			;
			SHOWXVALUES                     			;
			SHOWYVALUES                     			;
			; //SHOWLEGENDS 						;
			NOBORDER
			DRAW GRAPH							;
			AT 20,20						;
			TO 400,610						;
			TITLE mGraphTitle				;
			TYPE POINTS						;
			SERIES aSer					;
			YVALUES ay			;
			DEPTH 15						;
			BARWIDTH 15						;
			HVALUES 5						;
			3DVIEW    						;
			SHOWGRID                        			;
			SHOWXVALUES                     			;
			SHOWYVALUES                     			;
			; //SHOWLEGENDS 						;
			NOBORDER
One thing more. In HMG, if the values are larger than 999,999,99, SHOWXVALUES will show you "*"s. So, I just divided my values with 1000 :)
Please advise how to improve the graph generation software. :)
With best regards.
Re: Using Graph
Hi Sudip
Nice work, thanks to sharing.
sudip
Re: Using Graph
Post by sudip »
Hi Esgici,
Your words always inspire me to do a better job :)
Thanks a lot for reviewing a very basic program of a learner. :)
With best regards.
Re: Using Graph
Hi Sudip
Could you add "main" proc/func to your code, for making it a "working sample".
I want run and seeing while running samples instead of simply reading code.
sudip
Re: Using Graph
Post by sudip »
Hi Esgici,
Thank you for your interest! :)
I am sending a working sample for creating graph. Please compile and run :) (And please don't forget to send your advice) :)
#include "minigui.ch"
   Define Window frmsg ;
      at 0, 0 ;
      width 470 ;
      height 350 ;
      title "Sale Graph (Created with HMG)" ;
      main ;
      nomaximize
      @ 240, 350 button cmdRun caption "Generate Graph" ;
         action CalculateGraph()
   end window
   frmSG.center
   frmSG.activate
return nil
STATIC function CalculateGraph()
   local i, n, t, ax, ay, aSer, mGraphTitle, aMonth
   ax := {}
   ay := {}
   aMonth := {{"Apr", 0.00}, {"May", 0.00}, {"Jun", 0.00}, ;
      {"Jul", 0.00}, {"Aug", 0.00}, {"Sep", 0.00}, ;
      {"Oct", 0.00}, {"Nov", 0.00}, {"Dec", 0.00}, ;
      {"Jan", 0.00}, {"Feb", 0.00}, {"Mar", 0.00}}
   for i := 1 to len(aMonth)
      aMonth[i, 2] = random(99999.99)
   next
      aadd(ax, round(aMonth[i, 2], 2))
      aadd(ay, aMonth[i, 1])
   next
   aSer := {}
   aadd(aSer, ax)
   mGraphTitle := "Sale"
return nil
      At 0,0 ;
      Width 640 ;
      Height 480 ;
      Title "Graph with HMG" ;
      MODAL ;
         value 1 ;
   End Window
   GraphTest.Center
   if mGraphtype = 1
      DRAW GRAPH							;
         AT 20,20						;
         TO 400,610						;
         TITLE mGraphTitle				;
         TYPE BARS						;
         SERIES aSer					;
         YVALUES ay			;
         DEPTH 15						;
         BARWIDTH 15						;
         HVALUES 5						;
         SERIENAMES {""}		;
         3DVIEW    						;
         SHOWGRID                        			;
         SHOWXVALUES                     			;
         SHOWYVALUES                     			;
         ;                                          //SHOWLEGENDS 						;
         NOBORDER
      DRAW GRAPH							;
         AT 20,20						;
         TO 400,610						;
         TITLE mGraphTitle				;
         TYPE LINES					;
         SERIES aSer					;
         YVALUES ay			;
         DEPTH 15						;
         BARWIDTH 15						;
         HVALUES 5						;
         SERIENAMES {""}		;
         3DVIEW    						;
         SHOWGRID                        			;
         SHOWXVALUES                     			;
         SHOWYVALUES                     			;
         ;                                          //SHOWLEGENDS 						;
         NOBORDER
      DRAW GRAPH							;
         AT 20,20						;
         TO 400,610						;
         TITLE mGraphTitle				;
         TYPE POINTS						;
         SERIES aSer					;
         YVALUES ay			;
         DEPTH 15						;
         BARWIDTH 15						;
         HVALUES 5						;
         SERIENAMES {""}		;
         3DVIEW    						;
         SHOWGRID                        			;
         SHOWXVALUES                     			;
         SHOWYVALUES                     			;
         ;                                          //SHOWLEGENDS 						;
         NOBORDER
With best regards.
Re: Using Graph
Hi Sudip
Thanks a lot.
I had save it into my "Informal HMG Samples"
sudip wrote:
... don't forget to send your advice
You know, improvement is a very very long way :)
Only some random thoughts :
- You can eliminate unused main (frmsg) window, such as
   CalculateGraph()
return nil
( Don't forget changing MODAL property of GraphTest window to MAIN )
Or my be better, extract CalculateGraph() function and move its content to Main()
- You can acquire graph data from a table, instead of producing by code.
- You don't use SERIES possibility. You can use it f.e. by defining "Cost", "Sales", "Profits".
But don't expand it very much. Samples must be compact, simple and easy to understand as far as possible.
Best Regards
sudip
Re: Using Graph
Post by sudip »
Hi Esgici,
Thanks a lot for your interest about a very small project :)
I am honored! :)
I copied the code from one of my latest add-on project for good-old clipper (now xharbour+gtwvw) apps. Yesterday I started this project and as soon as I created my first graph, I wanted to share it with everybody and posted in the forum!
Mr. Grigory Filatov helped me in solving one problem in graph (value greater than 99999.99 shows "*"s). Thank you Grigory Filatov. :)
Today, I finished my small add-on project and it is created with HMG. It can create Bar, Line, Point graphs and Pie charts from tables of my old apps :)
With best regards.
Re: Using Graph
Nice presentation. Thank you Sudip.
sudip
Re: Using Graph
Post by sudip »
Now I shall create add-on for VFP apps. :)
This add-on include graph (without using MS-Graph), transfer to Excel etc.
BTW, is there any code available like Grid2Excel? If it's not there I shall create it :) I already had my own dbf2excel (created with xHarbour).
Hi Rathi, now I shall use your Grid2Print. Very soon I shall need your help for MySql. :)
Thanks a lot to you all. Again, I am feeling fun in programming :)
Regards.
nguyenchiduc
Re: Using Graph
Post by nguyenchiduc »
I think if we can draw each point. HMG graphics can help us draw diagrams, data analysis, time series. Mathematical statistics
if the precision is not important, it is only for illustration
function main
	define window mathematica at 0,0 ;
		width 800 ;
		height 600 ;
		title "Shapes Demo" ;
		main on init drawshapes()
    @ 10, 410 LABEL LABEL_function_1 Value "y = x*x/30" font '.vntime' size 17 bold
    @ 300, 600 LABEL LABEL_function_2 Value "y = x" font '.vntime' size 17 bold
    @ 370, 650 LABEL LABEL_function_3 Value "x = y*y/25" font '.vntime' size 17 bold
    @ 460, 650 LABEL LABEL_function_4 Value "y = 10*sin(x)" width 150 font '.vntime' size 17 bold
	end window
	mathematica.center
	mathematica.activate
return nil
function drawshapes
   LOCAL x1 := 0 , y1:= 0 , x2 := 0 , y2:= 0
   draw line in window mathematica at 500,0 to 500,800 pencolor {0,0,0} penwidth 1
   draw line in window mathematica at 0,400 to 600,400 pencolor {0,0,0} penwidth 1
   FOR i := -200 to 200
      x1 := i - 1
      y1 := (i - 1)*(i - 1)/30
      x2 := i
      y2 := i*i/30
      draw line in window mathematica at 500-y1,400+x1 to 500-y2,400+x2 pencolor {255,0,0} penwidth 2
   ENDFOR
   FOR i := 0 to 400
      x1 := i - 1
      y1 := sqrt(i - 1)*5
      x2 := i
      y2 := sqrt(i)*5
      draw line in window mathematica at 500-y1,400+x1 to 500-y2,400+x2 pencolor {0,0,255} penwidth 2
   ENDFOR
   FOR i := -100 to 100
      x1 := 10*(i - 1)
      y1 := 10*sin(i - 1)
      x2 := 10*i
      y2 := 10*sin(i)
   ENDFOR
   FOR i := 0 to 400
      x1 := i - 1
      y1 := i - 1
      x2 := i
      y2 := i
      draw line in window mathematica at 500-y1,400+x1 to 500-y2,400+x2 pencolor {255,113,255} penwidth 2
   ENDFOR
return nil
